Community Member
Critical Error - CUCM 8.6 on Vsphere 5.1
Hi voice team, a configured the vm using cucm 8.6 ova template, then i started the machine, put a lot information like, IP Address, NTP, DNS, but when the machine begin to install appears the error attached.
Everyone's tags (1)
1 ACCEPTED SOLUTION
I think Chris means the actual HW on which ESXi is installed, not the VM specs
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
I've seen this happen on a system that is slower than what is expected, what hardware are you running it on?
How many times do you attempt to install it? For me it installed on 3rd time.
HTH,
Chris
Community Member
The hardware is:
Red Hat Enterprise Linux 5 (32-bit)
4 gb memory
2 CPU´s 800 MHz
80GB hard disk
I try to install 4 times, but the same screen appears.
Thanks.
java
java
Community Member
That´s right, i move the vm host to another physical machine (supported) and works fine.
Thanks.
Yes, that is what I meant.
Chris
168
