Critical/high priority process VTSP may not dismiss
Hi!
On the router Cisco 3825 approximately each 2-3 minutes I have a message: "CAS: %SCHED-2-EDISMSCRIT: Critical/high priority process VTSP may not dismiss."
Does anybody know what does it mean?
The router has IOS (C3825-ADVIPSERVICESK9-M), Version 12.4(20)T1 and also CCME is running - Version 7.0(0)
Thank for your replies!
Ruslan
Re: Critical/high priority process VTSP may not dismiss
This message probably shows up along with a series of hexadecimal text and a TRACEBACK message.
Most likely cause is Cisco bug ID CSCsy18099. This problem has been fixed in IOS version 12.4.22T2. Please give this code a try and see if the problem has been resolved.
Thanks very much!
I'll try IOS You recommended.
KravetsRM, did the IOS updgrade solved your issue?
1175
