Community Member
CRS and CCX 5 text to speech.
I am writing custom scripts and need to change Cisco girl with our voice wavs for time speech, when she reads "5" minutes for example, but I don't see anywhere to change the default directory to use for the number wav files when converting integers to speech.
P[] + waitTime + P[int\9811] + P[int\9801].
Any modification to waitTime causes a failure.
Thank You for any help.
Silver
Re: CRS and CCX 5 text to speech.
The Cisco CRS system uses the MRCP (Text-to-Speech) subsystem to convert plain text into spoken words in order to provide a user with information or to prompt a user to respond to an action. You can use the following document for writing the script:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_5_0/programming/script_devp/gs_with_scripts/crs501gs.pdf
Community Member
I guess my question was not clear enough, I have scripts with prompts all set up with a guy here at the company speaking, when he says ( P[estimated wait time is] + waitTime + P[minutes]) the number within waitTime is the female voice from cisco. I need to change it to his voice, but the script isn't reading it as a prompt, its mearly changing the variable waitTime which is an integer to the corresponding wav file \C:\Program Files\wfavvid\Prompts\system\G711_ULAW\en_US\gen\number\2.wav, the path is not defined within the script it appears hardcoded by Cisco, is that correct? so without messing with the default installation files is there anyway to do this so the waitTime variable continues to function the way it should etc.?
Community Member
Can I use Text to speech TTS feature without MRCP like Nuance??
321
