CRS Historical Reports OLD Skills/Group
Hi everyone,
I have a little problem. I've change all Skills and Group name and the old name and skills are not configured on the IPCC, but they keep showing in the CRS Historical Reports as available in the filter. Any way I can update this?
Re: CRS Historical Reports OLD Skills/Group
I have the same problem here.
I try to find here HR save this, but I could not find.
VIP Super Bronze
Did you rename an existing skill or add new ones?
Deleted values from the UI are retained in the db_cra database. Deleting them would destroy the historical reporting database and make report generation from the timeline they were in use impossible.
Please remember to rate helpful responses and identify helpful or
I rename, delete and create new one.
So they will stay there for ever? Because I dont need reports older than 1 month ago. Because I have 70 schedules reports thats run every week and month saved on my servers
Another question I have, any way to change the name for a custom name in the scheduler? Because I run 5 reports, for 7 groups each weeks and months but in the Scheduler they all look the same. So every time I have to do change I need to delete all that have the same name and redo them.
133
