CSA agent on Call Manager with NIC teaming
Has anyone install CSA agent on Call Manager with NIC teaming? Do I need to remove the NIC teaming, install CSA agent then put back NIC teaming. Do I select network SHIM during installation ?
1 REPLY
Hall of Fame Super Silver
Re: CSA agent on Call Manager with NIC teaming
I've done it several times, it does not matter when you install CSA. Yes, select shim as that should be your only availabe selection.
Chris
109
