CSA available for cisco unified operations/services manager ?
I cannot find any info on this, so, I suppose that there is no CSA foreseen for the cisco unified operations manager software ?
Many Thanks
Dirk
1 REPLY
Silver
Re: CSA available for cisco unified operations/services manager
Cisco Security Agent provides intrusion detection and prevention for the Cisco Unified CallManager cluster. Cisco Systems provides it free of charge as a standalone security agent for use with servers in the Cisco Unified CallManager voice cluster. The agent provides platform security that is based on a tested security rules set (policy), which has rigorous levels of host intrusion detection and prevention. The agent controls system operations by using a policy that allows or denies specific system actions before system resources are accessed.
This URL should help you:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a0080667814.html
102
