CSA on ccm 4.2/ipcc
Folks,
I have callmanager running 4.2 and ipcc 4.x on the same box, can i install csa on it? does anyone know what version?
Re: CSA on ccm 4.2/ipcc
CSA versions 2.0(x), x=1,3,4,5 seems to work fine with CCM 4.2(3). according to this link
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
And the same CSA versions seem to work just fine with CRS 4.0(5) as well.
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/crscomtx.pdf
HTh
Sankar
PS: please remember to rate posts!
hi sankar,
our voice guys are working on the first tests for an upgrade to ccm 4.2.3.
further more we are planning to deploy csagents on the new systems. i would like to use the latest 5.1 version because i dont like vms.
now i followed the first link you provided and under CSA--Cisco Security Agent were listed the following versions:
1.1(10)
2.0(2)
2.0(3)
2.0(4)
2.0(5)
i dont really understand/know these versions - i am new to csa - but what are these versions? the standalone agents?
thanks for any hints
best regards,
juergen
108
