CSCee20237 - Unknown Alarm DaTimeout in 3.3(5)sr2
Bug toolkit CSCee20237 saids found in 3.3(4) and resolved in 4.3 but does not give much info. Is this cosmetic, does it cause a problem? What is fix other then to go to CCM 4.3 (win2003) when available or do we just ignore it? It usually happens in the wee hours during nightly jobs, etc on the server (Backups, etc).
Thanks, Erick
1 REPLY
Gold
Re: CSCee20237 - Unknown Alarm DaTimeout in 3.3(5)sr2
Yes, it does look like a cosmetic bug. It should not cause any problem in the system and that could be one of the reasons the bug was not fixed in an earlier version. You can ignore the error as long as you can live with it. This should not break anything on the system.
As this is fixed in CM 4.3(1) which is already available, you can upgrade to that version.
Hope that helps.
167
