Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
csim star
When I enter the command csim star number, example, csim star 2000, my ephone don't ring, WHY? (the calls between phones are successfull).
Hall of Fame Super Red
Re: csim star
Hi Ricardo,
Hope all is well :) It must be entered this way;
csim start
Note: start not star
Hope this helps!
Rob
Re: csim star
Rob, I enter:
Router#csim start
Re: csim star
example:
csim start 918005464454
/endexample
Use the above only input your own information.
Note: This can only be used with H323 gateways and then only if you have your dial-peers configured correctly.
MC
Re: csim star
I enter the command but the phone don't ring.
The dial-peer is configured in the Gateway.
The phone is registered in the Call Manager Express.
And this message is show:
Router#csim start 2001
csim err:csim_do_test invalid major major(16) minor(0)
Re: csim star
Is the DN you are trying to call part of your ephone configuration? I am not sure if you can use the csim start command to call an ephone vs a regular analog line or PRI. I could be wrong. Paulo or Rob may know though.
Re: csim star
Is a Call Manager Express version 4.1 in a Router 2800, and this have the dial-peer configured.
667
