04-21-2009 08:47 PM - edited 03-15-2019 05:35 PM
Can we use csim start <Mobile nukmber> command to check the voice call connection for PRI lines.Because for few service provider the calls are not established.when checked with debug we have found an error "**ERROR**: isdnAsn1Component: ERROR" & "**ERROR**: process_facility_supp_services: Decode of facility IE operation failed"
Pls help..
04-21-2009 10:30 PM
any comments ?
04-21-2009 11:14 PM
yes u can try, but whats the call flow...?
Can you use an IP communicator? or hard phone?
can you post the debugs here?
04-22-2009 01:23 AM
Hi gogasca,
Thanks for your response.
I am not using any ip phones or communicator as of now.Just i am using csim start from router to my mobile number. Router has two pri lines from different service providers.when i dial with 1st SP the call is connecting perfectly but when i go for the second pri the call is disconnecting.I have done the same configuration for the both lines.also attached the failed call logs.
