CSIM START
We have 5 ISDN interfcae and all the Dial-peer has .T which is mapped to all the five Interfaces.
We just want to check O/B call specific to one interface without any change in destination-pattern or Prefernece.
Is there any command to check in VG, Even i checked with CSIM START but i couldn't find any command to check for particular interface.
Please suggest.
SIVANESAN R
SIVANESAN R
Hall of Fame Super Gold
CSIM START
You can try "show dialplan  number xxx timout". However, it doesn't work for all cases, and you will need to genererate real test calls.
CSIM START
Paolo - I just want to make O/B call from VG by using one particular interface, Is there any command to check.
SIVANESAN R
SIVANESAN R
CSIM START
Answered above.
Re: CSIM START
Csim start and the number. E.g
Csim start xxxxxxx
Debug isdn q.931 (if using isdn)
Term mon
If you have multiple T1 / E1's and you want to test calls out of a particular trunk, create a specific test dial peer, something 56.t and specify the voice port you want the call to go out of.
E.g
Dial peer voice 5600 pots
Destination-pattern 56.t
Port 0/0/0:23
Or port 0/0/0:30 if using E1.
732
