Community Member
CSS for MGCP g/w in CM5 not being respected ?
I have setup a 2811 with a BRI card, as an MGCP voice gateway for my CM5, using BRI backhaul.
Incoming & Outgoing calls work fine on the BRI line!
However, in the incoming CSS associated with the MGCP endpoint, I have setup a CSS that does not have any devices in it.
However, calls still get routed.
I am trying to apply a translation pattern to incoming calls, so that I can prefix the numbers with a "9".
But it seems that the CSS is not being matched for incoming calls on the MGCP endpoint.
Any ideas ?
1 ACCEPTED SOLUTION
Community Member
Re: CSS for MGCP g/w in CM5 not being respected ?
You might have to reset the MGCP connection in order for your changes to take effect.
try issuing the commands:
no mgcp
mgcp
to the gateway.
I have recently had to to do this on MGCP gateways in order to get some configuration changes to take effect.
Community Member
no mgcp
mgcp
to the gateway.
Community Member
Thanks Tim !!
You are a star !!
I spent hours last night trying to get this to work, and this morning, after following your advise, its resolved in a few minutes !!
Thanks once again !!
Community Member
Glad I could help.
168
