Community Member
CSS in Extension Mobility
Dear All Expert,
System:
1 - CUCM 7.1.3
2 - voice gateway (as MGCP)
i need to seprate a device profile partition and phone set partition both has the same extension number but different partation, is this possible.
here is the senario and both has the same extension number.
Phone A (Normal DN ) has partition Local
Phone A (Extension Mobility i mean device profile ) has partition national.
this is look like lock/unlock the set. i need the user  to login when he leave his office he will  logout so the phoneset will be as default which is local access, when they login  device profile throu extension mobility he will have the national asscess.
if any one has guide for ccm and Active Directory please send.
Red
Re: CSS in Extension Mobility
Yes, you can do that.  Actually, you should configure "local" CSS on the device (phone) level and "national" on the EM DN level.
So when EM was not logged in, the effective CSS would be "local".  If EM was logged in, the effective CSS would be "national" because line level CSS always supersede the device level CSS.
Michael
http://htluo.blogspot.com
Just to add something, read this and you'll get a better understanding of how to do this and how it works
Building Classes of Service for Unified CM with the Line/Device Approach
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/dialplan.html#wp1150997
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Thanks for your reply,
I will try to do that again i check, but i have other issue when i logon to EM the phoneset will reset completely and the same when i logout.
thanks
276
