Community Member
CTI Error Message in Application Log
On a CCM 4.2 I see the following error message in the application log:
Computer: HVF102
Source: Cisco CTIManager
Category: None
Type: Error
Event ID: 3
Description: Error: kCtiDeviceOpenFailure - Device Open failed
CTI Connection Id: 32
Device Name: PMO_910531
UNKNOWN_PARAMTYPE:ReasonCode: 2362179747
App ID: Cisco CTIManager
Cluster ID: CCMCL1
Node ID: 10.230.45.1
CTI Application ID: CiscoTSP001-138.191.82.95
Process ID: 1440
Process Name: CtiHandler
Explanation: Application is unable to open the device
Recommended Action: Check the reason code and correct the problem..
PMO_910531 is the blind device within the PMO application of Snapware.
Everything is working fine so far. So what's up with this message?
Cheers
Peter
1 REPLY
Bronze
Re: CTI Error Message in Application Log
Is this the only error message you see in application log related with call manager?
Have you done an upgrade on this call manager?
Also, have you tried registering IPC?
Try restart of CTI Manager,
If it is possible, try device name of CTI RP, reset RP and then associate.
Check with passwordutils if all passwords in sync.
Hope this should work
270
