05-12-2014 09:33 PM - edited 03-16-2019 10:46 PM
05-12-2014 10:25 PM
CTI Ports
CTI ports as virtual devices can have one or more virtual lines, and software-based Cisco Unified Communications Manager applications such as Cisco IP Softphone, Cisco Unified Communications Manager Auto-Attendant, and Cisco Unified IP Interactive Voice Response (IVR) use them. You configure CTI ports by using the same Cisco Unified Communications Manager Administration windows as you use to configure phones. For first-party call control, you must add a CTI port for each active voice line.
For CER, check this
https://supportforums.cisco.com/discussion/11619156/cti-ports-emergency-responder-cer
Manish
05-13-2014 12:06 AM
[+5] to Manish .
You can also refer the discussion on CTI Ports/RP
https://supportforums.cisco.com/discussion/11982191/what-cti-route-point?tstart=0&viewcondensed=
regds,
aman
05-13-2014 06:33 AM
Horacio, you keep opening new posts with the same question without closing or asking for additional comments on the existing posts. Please keep the questions on same thread and don't forget to rate all answers.
Chris
