CTI Route Point & Call Forward all
I have a CTI Route point set up to forward to a Call Handler in Unity. If you dial the extension (1234) it will forward right away to unity and play the call handler. However, if I press the CFwdAll softkey on a phone to forward my calls to this CTI Route Point (1234) it shows the phone as forwarded, but when someone calls that phone, it plays the owner of the phonce voicemail greeting and not the call handler (1234). Can you even do a call forward all on a CTI route point??
Scott
Bronze
Re: CTI Route Point & Call Forward all
The redirecting number is coming from the first redirecting phone, which will not be the cti rp but the phone you set for cfa.
In oder to overcome create another voicemail profile and set the mask to be 1234, then you will hit the correct call handler.
HTH, Avner.
unity takes the original called number as the number it uses to look for a mailbox. this is working as designed
if you want to reach a particular call handler create a call routing rule for forwarded calls in which the calls that come from that CTI route point reach the specific call handler you need
you can use the call viewer to see the call coming in and use the calling number parameter for the rule
java
if this helps, please rate
www.cisco.com/go/pdi
I am having this same issue. Can you be more specific in the steps to do as I am new to all this. Thanks.
Download the latest advanced settings tool form here.
http://www.ciscounitytools.com/App_AdvancedSettingsTool.htm
Change this setting
Conversation - Route by last redirecting ID
By default Unity routes forwarded calls based on the first redirecting Id. Setting this value to "1" will force Unity to, instead, use the last redirecting ID.
NOTE: Not all integrations provide both first or last redirecting Ids. If Unity is configured to route on one and it is not provided but the other is, Unity will instead route by the number provided.
If the value is 0 or missing, Unity routes by the first redirecting ID
If the value is 1, Unity routes by the last redirecting ID.
1436
