11-29-2007 10:30 PM - edited 03-15-2019 07:30 AM
I would like to ask whether is it possible to fwd call No Answer or Call Fwd All to Hunt Pilot Number as a redudant link when call manager lose connection to IPCC completely?
CCM version 4.2(3)
11-30-2007 05:03 AM
Yes - you can set the Cfwd No Answer, Busy and failure to on the CTI Route Point to point to your hunt group pilot.
Aaron
Please rate helpful posts...
11-30-2007 07:00 AM
You can do it as someone else mentioned, but be careful you may experience any latency then the call will go that route.
Thanks.
