CTI Route Point not registering
i am integrating CUCM 9 with Informacast 8.4. i did the basic setup and by registering the default Informacast CTI RP with all the other configurations.
however, when i create a new CTI RP to match a new DialCast in Informacast, it doesnt seem to register.
I've tried updating JTAPI a couple times, reset the CTI RP, upating my CUCM Cluster under Telephony in Informacast and Refreshing the Recipients list, but none seems to work.
please help!!!
Re: CTI Route Point not registering
Do you have the correct partition and calling search space assigned and have you restarted the cti service under servicability?
Voice CCIE #37771
hi ,
yes i believe my css and paritionnis correct. i also tried restarting the cti service but to no luck.
Hi Again,
after fiddling around, i realized i did not associate the CTI RP under the Application User setting.
Kinda basic step to miss ..
thanks for the help though..
Cheers.
112
