CTI Route Point
Is there a step to register the CTI route point with the server after you define it?
1 ACCEPTED SOLUTION
Re: CTI Route Point
All CTI Rp's dont register to the Callmanager unless an application using CTI is associated with that RP. If you are using the following apps, the RP will register.
a. IPMA
b. IPCC/ICM Route points associated with applications
c. Mobility Manager
d. Attendant console pilot point is a route point in CM 5.x. This RP will show registered in CM.
Sankar.
PS: please remember to rate posts!
Hall of Fame Super Red
Re: CTI Route Point
Hi Jeff,
After you Insert the CTI RP and add the DN you will use Update/Reset. It make take a few moments to register with Callmanager (are you having problems getting it to register?).
Cisco CallManager Administration Guide, Release 4.1(3)
CTI Route Point Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed6d3.html#wp1122418
Hope this helps!
Rob
Re: CTI Route Point
Yes, I reset it 2 or 3 times and still cannot get it to regisiter with CM
Re: CTI Route Point
a. IPMA
c. Mobility Manager
Sankar.
944
