CTI Route Point
I have installed the CCM 4.x on which i have installed the CRA 4.0. I am having problem with CTI Route point. I have add two CTI route Point but both status is unknow. I have restart the call manager so many times but still the problem is there.
Because of this problem I am not able to configure JTAPI Trigger.
I am getting following
Could not create CTI Route Point and corresponding Line on CallManager.
Please help me out.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: CTI Route Point
wasiim,
You do not need to create cti rp in call manager. Just add the jtapi trigger in crs and it will automatically create the cti rp in callmanager and associate the cti rp with the jtapi usser.
Lets backoff a little and do basic troubleshooting.
Are your cti ports (call controll ports) registerd in callmanager ?
Can you check this?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
Re: CTI Route Point
Did you create this RP in CRA or CM? You need to create it in CRA, also the error most likely indicates that you are adding a device with a DN which aleady existis, run dial-plan report to ensure there is no conflict.
Look into MIVR logs for more details.
HTH,
Chris
Re: CTI Route Point
I have created the CTI RP on call manager and i have provided the correct ip address in CRA. I dont have LDAP, i m using Callmanger database.
I got error when i try to add the JTAPI trigger. There is no DN conflict. I am using entirely different range.
Please see attachement for MIVR logs. I did the following steps.
1. install the CM.
add devices, users and do the basic internal IPT Calls.
2. Then install the CRA on the same callmanger machine.
3. I add the JTAPI user and CTI RP IN CM
4. Then make the JTAPI Provider in CRA and gave the IP of CM there.
5. Then creat the JTAPI Call control group, and make 100 CTI ports.
6. After all this when i go for the JTAPI trigger it gave me error.
VIP Super Bronze
Re: CTI Route Point
wasiim,
Can you check this?
Re: CTI Route Point
I have removed the users, cti ports everthing that i configured in CRA,
I followed your pattern and it is working fine for me. Thanks for the support, but now when i dial the 777 from IP phone that is route pattern,
i got nothing, please tell me what to do next.
VIP Super Bronze
Re: CTI Route Point
wasiim,
what do you want to happen when you dial the CTI RP.
CTI RP or Jtapi triggers are used in CRS to invoke scripts/application already written to do certain things...
Do you have your trigger pointing to an application in crs?
Re: CTI Route Point
I want that when user dial 7777 they will hear a recorded prompt like
What we need is very simple:
- Callers should hear a welcome prompt
- press 1 to hear message #1
- press 2 to hear message #2
- press 3 to hear message #3
- press 0 to go to operator
I am using default values for langauge and application is test script.
any link and related document will be highly appreciated.
VIP Super Bronze
Re: CTI Route Point
Wassim,
Before you create Jtapi Triggers, you need to confgiure
1. Your CRS server
2. Your crs cluster.
For your crs server, you need to check that you have configured your Jtapi provider and your RM jtapi provider.
2. On your CRS cluster, you need to set up your LDAp server information.
Let me know if you have done all these
Re: CTI Route Point
are those CTI RP attached to the JTAPI user???
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Super Bronze
Re: CTI Route Point
Jamie,
He is unable to create the CTI RP. Usually when you create the triggers in CRS, it automatically creates the CTI RP in CCM and associates them with the jtapi user
285
