06-29-2014 12:54 AM - edited 03-16-2019 11:14 PM
We need to setup a simple AA in unity connection with a Route Point from CUCM pointing to unity connection.
We require one CTI RP with 10 CTI ports. We also need a call handler which play a welcome prompt and if key 2 is pressed it should reach an extn, if nothing is pressed it should go to defualt extn.
How to approach this setup.
Thanks & Regards,
06-29-2014 05:21 AM
Is this new installation ? If yes;
CUCM side:
Execute the Voice mail port wizard, it will assist you in integration.
Create CTI route point and set forward all calls to Voice mail pilot number.
CUC side:
Add a phone system and choose type SCCP and add port group and then port.
Create a system call handler and give the same number in "Extension" field as CTI route point and configure the transfer options and input option accordingly.
You can visit the integration guide, that will help you.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny/cucintcucmskinny050.html
Suresh
06-29-2014 06:07 AM
Dear Suresh,
Tnx for the reply...
CUCM is already installed and integrated with unity connection using SIP trunk with 200 ports.
How to configure in this scenario?
Thanks & Regard...
06-29-2014 09:23 AM
Dear,
Then you need to create a route pattern (use free DN) and point it to existing SIP trunk. CUC side configuration is same as described above.
Suresh
06-29-2014 10:41 AM
Hi Raffi,
you can also refer the link on Call Handlers.
http://www.ciscopress.com/articles/article.asp?p=2021962&seqNum=7
regds,
aman
06-30-2014 09:48 AM
Hi Aman,
Tnx for the link. In our scenario if the users press 2 then it should go to an extn, if no key is pressed then it should direct to another extn.
I have configured the call handler with a recording. After recording when key 2 is pressed then it forwards to an extn. If no key is pressed then it forwards to another call handler where it directs to another extn.
Thanks & Regards...
06-30-2014 09:43 AM
Dear Suresh,
The option of creating free DN pointing to SIP trunk is a good suggestion. In our scenario we have a physical extn and we are forwarding all calls to voice mail. The same extn is configured in unity as a call handler. In future we may remove this physical extn and configure route pattern as per your suggestion...
Thanks...
