CTI RP GETTING UNREGISTERED FREQUENTLY
Hi All,
Facing issues with the CTI RP getting unregistered frequently,
The PG is communicating with the Call Manager Publisher and its working in simplex mode.Also no redundancy configured on PG.
We have receintly observed below logs on PG:
**********Logs snippet from the PG: ********** Events from December 30, 2011:
11:20:17:268 pg7A-jgw1 Trace: CiscoAddrOutOfServiceEv Addr: 12854 Cause: CTIMANAGER_FAILURE
11:20:17:268 pg7A-jgw1 Trace: LastAddrOOSTime - CrrentTimeMillis > 300000
11:20:17:268 pg7A-jgw1 Trace:   MsgEMSEventReport:  MessageId: 2706702338 Arg1: 0 Arg2: 0 Arg3:  Arg4:  Arg5:
11:20:17:268 pg7A-jgw1 Trace:   MsgAddressOutOfService:  Addr: 12854 Cause: 1007
11:20:17:268 pg7A-jgw1 Trace: CiscoAddrOutOfServiceEv Addr: 70070 Cause: CTIMANAGER_FAILURE
11:20:17:268 pg7A-pim1 JTAPIGW received a message from CM that an address is out of service due to CTI Manager or CM failure.
11:20:17:268 pg7A-pim1 Trace: [  6244]AddressOutOfService: Address=12854 Cause=1007
11:20:17:268 pg7A-pim1 Trace: [  6244]RecvAddressOutOfService: Couldn't find client stack for device target device string 12854
We have checked the call manager punblisher logs and below are the observation:
CCM LOGS: (from CCM PUB as PG is communicating with pub)
12/30/2011 11:19:38.926 CCM|DeviceManager::star_DMPropagateUnRegister - DeviceName=14972 Cepn={65652BC8-4C35-41C0-8C68-614247CFB4B7}|<CLID::SMDUCMPUSMXW01-Cluster><NID::10.1.24.10><CT::0,0,0,0.0><IP::><DEV::>
12/30/2011 11:19:38.926 CCM|DeviceManager::removeRemoteInfo - Name=14972 Key={65652BC8-4C35-41C0-8C68-614247CFB4B7} Pid=(5,125,50858)|<CLID::SMDUCMPUSMXW01-Cluster><NID::10.1.24.10><CT::0,0,0,0.0><IP::><DEV::>
CTI LOGS:(from CCM PUB as PG is communicating with pub))
12/30/2011 11:20:01.224 CTI|CTIManager: MYTCPMSG_MSGAVAILABLE TCPHandle=0x50c523c message length=0x18|<CLID::SMDUCMPUSMXW01-Cluster><NID::10.1.24.10><CT::1,200,10,1.30626><IP::><DEV::>
12/30/2011 11:20:15.334 CTI|CMProcMon - ERROR  !!!!!!!! SDL Router Services Dead: timeBeforeSleep: 1232034359, currentMontiorTime: 1232055218, deltaTime: 20859, LoopCount= 16|<CLID::SMDUCMPUSMXW01-Cluster><NID::10.1.24.10>
12/30/2011 11:20:15.881 CTI|CMProcMon - ERROR  Call Manager SdlState Changed - Abnormal Exit - Reason: [SDL Router Services declared dead.]|<CLID::SMDUCMPUSMXW01-Cluster><NID::10.1.24.10>
12/30/2011 11:21:36.151 CTI|CTIManager is starting.|<CLID::SMDUCMPUSMXW01-Cluster><NID::10.1.24.10>
Can you please help here understand is this a call manager issue or is this with the PG side.
Everyone's tags (1)
Hall of Fame Super Silver
This defintely looks like the issue is on the CUCM CTI Manager side, what version of CUCM are you running?
Chris
Its CCM 4.2
could this be a bug as we are facing this issue very frequenly. Is there any perment fix as its 4.2 and end of support.
Maybe, unfortunatelly CUCM 4.2 is no longer supported so you will not get a fix, any reason you have not upgraded to more recent versions?
Chris
Hi.
Which SR are you running.
Please also tell us whic ICM version an jtapi client you ha installed.
I had a similar issue to one of my customers and I solved uprgrading ICM and installing the latest CUCM SR.
Carlo
Please rate all helpful posts "The more you help the more you learn"
1063
