CTL not found when registered Cisco 8945 IP Phone
Hi All,
I found this error when i tried to register to my CUCM 10.X :
[20:50:57, 08/01/2013] TFTP error : download CTLSEP8478ACEC84D5.tlv fail
[20:50:57, 08/01/2013] CTLSEP8478ACEC84D5.tlv not found in 10.10.10.99
[20:50:57, 08/01/2013] ITLSEP8478ACEC84D5.tlv updating
[20:51:05, 08/01/2013] ITLSEP8478ACEC84D5.tlv (TFTP)
[20:51:05, 08/01/2013] ITLSEP8478ACEC84D5.tlv updated successfully
[20:51:05, 08/01/2013] ITL installed
[20:51:07, 08/01/2013] DNS Query [CUCM] : Response Error
[20:51:12, 08/01/2013] SEP8478ACEC84D5.cnf.xml.sgn (TFTP)
[20:51:15, 08/01/2013] DNS Query [CUCM] : Timeout
[20:51:17, 08/01/2013] DNS Query [CUCM] : Response Error
[20:51:27, 08/01/2013] DNS Query [CUCM] : Response Error
[20:51:30, 08/01/2013] tzdatacsv.csv.sgn (TFTP)
[20:51:37, 08/01/2013] DNS Query [CUCM] : Response Error
[20:51:47, 08/01/2013] DNS Query [CUCM] : Response Error
[20:51:57, 08/01/2013] DNS Query [CUCM] : Response Error
[20:52:07, 08/01/2013] DNS Query [CUCM] : Response Error
[20:52:17, 08/01/2013] DNS Query [CUCM] : Response Error
[20:52:27, 08/01/2013] DNS Query [CUCM] : Response Error
[20:52:37, 08/01/2013] DNS Query [CUCM] : Response Error
[20:52:47, 08/01/2013] DNS Query [CUCM] : Response Error
[20:52:57, 08/01/2013] DNS Query [CUCM] : Response Error
[20:53:07, 08/01/2013] DNS Query [CUCM] : Response Error
So what is it mean ? i triend to googling but i can't find the right answer.
Tks
Have you correctly configured
Have you correctly configured your forward and reverse DNS information for CUCM?
Is your CUCM deployment relying on DNS?
Not finding your CTL is not a big deal unless your cluster is in mixed-mode, is this secure deployment?
Yes, i already configure the
Yes, i already configure the DNS correctly, and i have configure the CIPC, and can running perfectly.
I combine CME and CUCM in this case, so i put 2 tftp server into my 150 option on my CME. i use same infrastructure, same switch same VLAN as well.
But only Phone that i purposes to register into CUCM that can't running.
Manually configure the 8945
Manually configure the 8945 for alt tftp using the IP address of the CUCM server.
The debugs you have above are from the CME router, correct?
I am a little hung up on your
I am a little hung up on your deployment model.  Can you elaborate on how you combined CME and CUCM?
Typically when you talk about combining CME and CUCM you are talking about SRST in CME mode. This means all phones register to call manager, but in the case of a server failure or network failure the phones re-register to their SRST reference defined in CUCM.
If have a ISR acting as CME handing out option 150 with the first address being the CME router, The phone will always try to pull its configuration from the CME router.
I use H.323 gateway to
I use H.323 gateway to connect CME and CUCM, and CME is my existing call Manager, and my boss buy BE6k to add new extensions number and video call as well. and i only put the cluster BE6k and connect them by H.323 gateway.
As i said before, i use CIPC and running perfectly, mean can make inbound and outbound.
Thank you
What happens when you got to
What happens when you got to http://10.10.10.99/SEP8478ACEC84D5.cnf.xml.sgn
This should return the xml
This should return the xml config file for the phone. The browser may try to render it so it might come back with errors. Mine works fine IE not in Chrome.
HTTP Status 404 -
HTTP Status 404 - /SEP8478ACEC84D5.cnf.xml.sgn
type: Status report
message: /SEP8478ACEC84D5.cnf.xml.sgn
description: The requested resource is not available.
hmm..what is it mean ?
Sorry forgot the port in the
Sorry forgot the port in the string
http://<CUCMip>:6970/SEP8478ACEC84D5.cnf.xml.sgn
Yes, I can download the file
Yes, I can download the file .cnf.xml.sgn. so what the problem really is ? could i configure manually for the VLAN ? because when i connected the phone it's automatically get VLAN 100 which is VLAN voice. Could I change it to VLAN 1 in example ?
Do you know what version of
Do you know what version of firmware the phone had on it? I recently ran into an issue on CUCM9.1.2 wherethe 8945's needed a stepped firmware upgrade from SCCP89XX9-2-1 to 9-3-4-17 then to 9-4-2. Not sure this would apply here, but thought I'd mention it just in case.
When this happened, 8945 phones were lockedup at 'Upgrade in process" screen and there was nothing we could do with the phones until we offered the 9-3-4-17 upgrade, and physically reset the port/phone.
Jonathan Beardsley CCNA Voice; MCITP Telecom & Network Administrator DECOSIMO
already do to manually but
already do to manually but the same problem still occurred. Nope, the debug comes from my IP phone.
Ok,What is the 10.10.10.99
Ok,
What is the 10.10.10.99 address? CUCM or CME?
CUCM
CUCM
 I think the best option is
I think the best option is try to span the port of your phone on the Switch and get a packet capture so we can analyze the bootup process of the phone step by step. If there's any failure at the DNS resolution phase or at the TFTP phase we can spot it.
I haven't seen a debug like this that I can relate in the past.
Thank you for join to helping
Thank you for join to helping me, it's  a little bit hard to do, because i have 4 levels switch, so to configure span it can be brother the running production, but i will do at the weekend. could i configure manually for the VLAN ? because when i connected the phone it's automatically get VLAN 100 which is VLAN voice. Could I change it to VLAN 1 in example ?
  The vlan is received via
The vlan is received via CDP from the configured voice vlan on the port.
1031
