CTL security token for CUCM 6.1
mohdashraq
I am planning to install and configure Cisco CTL client and two tokens are required as a pre-requisite. I need to know whether these token has to be purchased from Cisco and if there is a prt number for these tokens,or the Communications Manager itself can generate the token.
Mohammad
Ishan Sambhi
Hi mohammad,
The  Cisco Security Administrator Security Token (SAST) is hardware device that needs to be purchased from cisco. The call manager cannot generate it. For more information refer  the following :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/csa_token_ids/sec_tkn.html
The part number for the device is KEY-CCM-ADMIN-K9= .
Ishan
PS rate useful posts
Ishan Sambhi
Hi mohammad,
Ishan
