CUBAC 8.6.2.11 one way audio with specific carrier
Hi, i am wondering if anyone has seen this issue before and might be able to point me in the correct direction of what setting i might need to change.  So what happens is that when a caller from a specific company using L3 SIP Trunk calls into my main number with (Sprint SIP Trunk) the main number is being handled by CUBAC, so it looks we responds with a 200 ok and requests G711. The far end ACKS it. Immediately, we sends a reinvite, setting the call to inactive, which the far end says ok.then we sends a reinvite and to start again and the far end says ok, set to send/recv and we sends an ack and says set to send only, then we sends a reinvite that sets it to inactive again. It seems to do that over and over.
So the flow would be, the call hits the CUBE gateway, then CM, then CM points the number to Unity and Unity passes it to CUBAC, then the operator
This only happens when the call is routed to our CUBAC, if the same compnay calls the direct number (bypassing CUBAC) the call would connect fine.
I dont have this issue with anyone else calling our main number (or at least not aware of it) so i am kinda lost here.
Allan
Hi Allan,
Could you please post your protocol flow from your ITSP till CUBAC.
A reinvite is only send before session expire time (default 180 sec) when there is change in characteristics of the media session. If you could capture sip message and send across , we would like to see media in first invite and also in re-invite and its expire timer.
One more thing , have you checked this on CUBE -
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_proto/configuration/15-2mt/cube-midcall-reinvite.html
i have this ladder diagram captured from our provider to my CUBE.
Can you add this command and check.
Router(config)# voice service voip Router(config-voi-serv)# sip Router(config-serv-sip)# midcall-signaling passthru media-change
Manish
hi Manish,
Thank you for helping me look into this issue
currently i am running IOS 15.1(3)T3 on a 2811 router.  i currently have "midcall-signaling passthru" enable, but do not have the option for "media-change"
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  h225 timeout ntf 5000
  h225 display-ie ccm-compatible
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 600 min 60
  asserted-id pai
  privacy pstn
Re: CUBAC 8.6.2.11 one way audio with specific carrier
That will work , actually 15.2(1)T or a later release supports the whole command.
Can you please capture sip messages ( debug ccsip all) and attach it here , that will help in finding the reinvite sdp details.
here is the debug:
4254624012 is calling into 7143682300 (L3 to Sprint SIP Trunk)
COLO-2811-VG#term mon
COLO-2811-VG#deb ccsip all
This may severely impact system performance. Continue? [confirm]yAll SIP Call tracing is enabled
COLO-2811-VG#
1183645: Dec 19 16:55:10.650: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1183646: Dec 19 16:55:10.650: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1183647: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1183648: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2587143682300@10.97.1.150:5060;dtg=printronixtg1 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKvi4kt2106o0hf12lf721.1
From: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
To: "7143682300 7143682300"<2587143682300>
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
CSeq: 98836990 INVITE
Contact: <4254624012>
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept: application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 68
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 286
v=0
o=BroadWorks 86091758 1 IN IP4 208.29.69.22
s=-
c=IN IP4 208.29.69.22
t=0 0
m=audio 64744 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1183649: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1183650: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F449C60) with key=[1850247] to table
1183651: Dec 19 16:55:10.654: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1183652: Dec 19 16:55:10.654: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1183653: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1183654: Dec 19 16:55:10.654: //-1/000000000000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1183655: Dec 19 16:55:10.654: //-1/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
1183656: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1183657: Dec 19 16:55:10.654: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1183658: Dec 19 16:55:10.658: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1183659: Dec 19 16:55:10.658: //-1/28013998B3FF/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1183660: Dec 19 16:55:10.658: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x482797C4) found for sip_user: 2587143682300
1183661: Dec 19 16:55:10.658: //-1/28013998B3FF/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1183662: Dec 19 16:55:10.658: //-1/28013998B3FF/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1183663: Dec 19 16:55:10.658: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1183664: Dec 19 16:55:10.662: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
1183665: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
1183666: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4F449C60 key=SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g002587143682300
1183667: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
1183668: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 2587143682300
1183669: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 4254624012
1183670: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name 4254624012 4254624012, number 4254624012, Calling oct3 0x00, oct_3a 0x80, Called number 2587143682300
1183671: Dec 19 16:55:10.662: //-1/28013998B3FF/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:208.29.69.6:5060, Host:208.29.69.6
1183672: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 4254624012
1183673: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
1183674: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
1183675: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
1183676: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Peer tag 2584 matched for incoming call
1183677: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1183678: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1183679: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1183680: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
1183681: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
1183682: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
1183683: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
1183684: Dec 19 16:55:10.666: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
1183685: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1183686: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
1183687: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1183688: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
1183689: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1183690: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
1183691: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
1183692: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIContinueNewMsgInvite: Calling name 4254624012 4254624012, number 4254624012, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 2587143682300, oct3 0x00
1183693: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
1183694: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
1183695: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIValidateRequestUri: Not Enabled
1183696: Dec 19 16:55:10.670: //-1/28013998B3FF/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
1183697: Dec 19 16:55:10.670: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
1183698: Dec 19 16:55:10.670: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1183699: Dec 19 16:55:10.670: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7A6EA0
1183700: Dec 19 16:55:10.670: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1183701: Dec 19 16:55:10.670: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
1183702: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
1183703: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
1183704: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1183705: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
1183706: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
1183707: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1183708: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 64744
SIP: (2509931) Attribute mid, level 1 instance 1 not found.
1183709: Dec 19 16:55:10.674: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1183710: Dec 19 16:55:10.674: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
1183711: Dec 19 16:55:10.674: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1183712: Dec 19 16:55:10.674: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1183713: Dec 19 16:55:10.674: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1183714: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1183715: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1183716: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1183717: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1183718: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1183719: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1183720: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1183721: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1183722: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1183723: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1183724: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1183725: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1183726: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1183727: Dec 19 16:55:10.678: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1183728: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1183729: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1183730: Dec 19 16:55:10.678: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=208.29.69.22, dest_port=64744
1183731: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1183732: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
1183733: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1183734: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1183735: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 peer 0 flags 0x201 state STATE_IDLE
1183736: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1183737: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1183738: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509931, Peer CallID 0, sdp 0x48F8921C channels 0x4F44B1FC
1183739: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/copy_channels:
callId 2509931 size 0 ptr 0x4F57FACC)
1183740: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1183741: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1183742: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509931
1183743: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1183744: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1183745: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1183746: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 5
1183747: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1183748: Dec 19 16:55:10.682: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1183749: Dec 19 16:55:10.682: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1183750: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1183751: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
1183752: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 208.29.69.22:64744
1183753: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 8 mline 1
1183754: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
1183755: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 6
1183756: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/codec_found: No match for the codecs found..
1183757: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 18 mline 1
1183758: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
1183759: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8
1183760: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 16
1183761: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 16 & codec = 16 are same..
1183762: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 16
SIP: (2509931) Attribute ptime, level 1 instance 1 not found.
1183763: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
1183764: Dec 19 16:55:10.686: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 ptime :0, codecbytes: 0
1183765: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 20
1183766: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1183767: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 16 ptype 18 time 0, bytes 20  as channel 1 mline 1 ss 1 208.29.69.22:64744
1183768: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1183769: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509931, dtmf = 6
1183770: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1183771: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 16
1183772: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1183773: Dec 19 16:55:10.686: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 flags 0x10000100 state STATE_IDLE
1183774: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
1183775: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x804000C, ccb->pld.flags_ipip 0x201
1183776: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/copy_channels:
callId 2509931 size 468 ptr 0x48E00CCC)
1183777: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
CCSIP: Unable to report channel ind
1183778: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7419: Posting Remote SRTP caps to other callleg.
1183779: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1183780: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Stream address type    : 1
          Callid                 : 2509931
          Negotiated Codec       : g711ulaw, bytes :160
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:0
          Media Dest Addr/Port   : [208.29.69.22]:64744
1183781: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 6
Preferred and Negotiated NTE payloads: 101 101
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated V150.1 Modem Passthrough: 0 0
Preferred and Negotiated V150.1 Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
1183782: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1183783: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1183784: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
1183785: Dec 19 16:55:10.690: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17172 for stream 1
1183786: Dec 19 16:55:10.690: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17172
1183787: Dec 19 16:55:10.694: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1183788: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1183789: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1183790: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1183791: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
1183792: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
1183793: Dec 19 16:55:10.694: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
1183794: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
1183795: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1183796: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1183797: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1183798: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1183799: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
1183800: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/ccsip_api_call_setup_ind: Set Protocol information
1183801: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1183802: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1183803: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
1183804: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_store_channel_info: dtmf negotiation done, storing negotiated dtmf = 6,
1183805: Dec 19 16:55:10.694: //2509931/28013998B3FF/SIP/Info/sipSPIShrlCall: Check peer: 2584 for Shared-Line call, callid: 2509931
1183806: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Info/ccsip_set_bearer_capability:
   Bearer Capability: Speech (0x00)
1183807: Dec 19 16:55:10.698: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1183808: Dec 19 16:55:10.698: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1183809: Dec 19 16:55:10.698: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
1183810: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
1183811: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 264C6B to table
1183812: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1183813: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7A1E88
1183814: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1183815: Dec 19 16:55:10.698: //2509931/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7A1E88 to Invite Response 100
1183816: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FB1B3B8, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1183817: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1183818: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1183819: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FB1B3B8 to default port=5060
1183820: Dec 19 16:55:10.702: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1183821: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FB1B3B8
1183822: Dec 19 16:55:10.702: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FB1B3B8, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1183823: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
1183824: Dec 19 16:55:10.702: //2509931/28013998B3FF/SIP/Info/sipSPIProcessContactInfo: Previous Hop 208.29.69.6:5060
1183825: Dec 19 16:55:10.706: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
1183826: Dec 19 16:55:10.710: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F439508) with key=[1850248] to table
1183827: Dec 19 16:55:10.710: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1183828: Dec 19 16:55:10.710: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1183829: Dec 19 16:55:10.710: //2509932/000000000000/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
1183830: Dec 19 16:55:10.710: //2509932/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
1183831: Dec 19 16:55:10.710: //2509932/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
1183832: Dec 19 16:55:10.710: //2509932/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 0, codec 5 channel 64744, ip 208.29.69.22:64744  params 0x4F7E8A84 caps 0x4FD32038
1183833: Dec 19 16:55:10.714: //2509932/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 1, codec 16 channel 64744, ip 208.29.69.22:64744  params 0x4F7E8A84 caps 0x4FD32038
1183834: Dec 19 16:55:10.714: //2509932/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
1183835: Dec 19 16:55:10.714: //2509932/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
1183836: Dec 19 16:55:10.714: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 10.96.3.1 target_port : 5060
1183837: Dec 19 16:55:10.714: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
1183838: Dec 19 16:55:10.714: //2509932/28013998B3FF/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [4] in dial-peer [2581]
1183839: Dec 19 16:55:10.714: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 171)
1183840: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509932 chans 0x490E2848 event 171 flags 0x844001C 0x10000100 0x601 data 0x490E2848
1183841: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 2509932 chans 0x490E2848 event 171 flags 0x844001C 0x10000100 0x603 data 0x490E2848, type = 1
1183842: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler: Current mode is SIP-TDM
1183843: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
1183844: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SET_MODE
1183845: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
1183846: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
Changing the flow mode due to SET_MODE
1183847: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/sipSPIHandleMediaFlowModeChange:
1183848: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/sipSPIHandleMediaFlowModeChange: current media flow mode is 1, desired media flow mode is 1
1183849: Dec 19 16:55:10.714: //2509931/28013998B3FF/SIP/Info/sipSPIHandleMediaFlowModeChange: current flow mode is same as desired flow mode
1183850: Dec 19 16:55:10.714: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1183851: Dec 19 16:55:10.714: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
1183852: Dec 19 16:55:10.718: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
1183853: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 264C6C to table
1183854: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
1183855: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1183856: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
1183857: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
1183858: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
1183859: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
1183860: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
1183861: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
1183862: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1183863: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1183864: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1183865: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
1183866: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1183867: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
1183868: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
1183869: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
1183870: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
1183871: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: Valid peer channels available!!
1183872: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: No video caps posted by peer
1183873: Dec 19 16:55:10.718: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509932, channels 0x4FD0BC00 caps 0x4FD32038
1183874: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509932, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1183875: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPIDtmfTranscoder: Return upon SCCP version 0
1183876: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1183877: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder:  Entry..
1183878: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: AudioLevelAdjustment do not need xcoder
1183879: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1183880: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPICodecTranscoder: No body else needs xcoder. OFFER_ALL is intact
1183881: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckVoiceClassCodecConfiguration: Either one of the call leg supports Voice Class Codec..
1183882: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Check between Equalset & Subset..
1183883: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/codec_found:
1183884: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1183885: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found.. continue for next codec..
1183886: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/codec_found:
1183887: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 16 & codec = 16 are same..
1183888: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found.. continue for next codec..
1183889: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: This is Equal set
1183890: Dec 19 16:55:10.722: //2509932/28013998B3FF/SIP/Info/sipSPICodecTranscoder: Static codec or Equalset or Subset w/o offer-all. For DO call, offer-all is NO-OP..
1184378: Dec 19 16:55:10.926: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509932  chans 0x4FA5B45C event 165 flags 0x8C4401C 0x10000100 0x400403 data 0x4FA5B45C
1184379: Dec 19 16:55:10.930: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1184380: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509932 chans 0x4FA5B45C event 165 flags 0x8C4401C 0x10000100 0x400403 data 0x4FA5B45C Media Trigger 0
1184381: Dec 19 16:55:10.930: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1184382: Dec 19 16:55:10.930: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1184383: Dec 19 16:55:10.930: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1184384: Dec 19 16:55:10.930: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1184385: Dec 19 16:55:10.930: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509931, srcCallID=2509932,
                         peer_ccb->call_info.currentLocalName=4254624012 4254624012,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=,
1184386: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x0
1184387: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x2246
1184388: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1184389: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1184390: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1184391: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1184392: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1184393: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1184394: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1184395: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1184396: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1184397: Dec 19 16:55:10.930: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1184398: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1184399: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1184400: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
1184401: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1184402: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1184403: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1184404: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1184405: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400403
1184406: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1184407: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1184408: Dec 19 16:55:10.934: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1184409: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1184410: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          State                  : STREAM_ACTIVE (5)
          Callid                 : 2509932
          Media Srce Addr/Port   : [10.97.1.150]:18742
          Media Dest Addr/Port   : [0.0.0.0]:17760
1184411: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Info/is_call_held: Remote media IP addr: 0.0.0.0
1184412: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Media/ccsip_api_request_offer: Call has been put on hold
1184413: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1184414: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
1184415: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=18742
1184416: Dec 19 16:55:10.934: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1184417: Dec 19 16:55:10.934: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 18742
1184418: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
1184419: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Media/sipSPIAddSDPMediaPayload: DTMF relay will be added in the caller. Skipping it
1184420: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Add Media payload attributes for
                                    preferred codec's
1184421: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1184422: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1184423: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Deffering QoS reservation for MID-CALL Invite
1184424: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
1184425: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
1184426: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1184427: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7ADCF8
1184428: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1184429: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1184430: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184431: Dec 19 16:55:10.938: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184432: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7ADCF8 to Invite Response 100
1184433: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4F94E6C0, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1184434: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1184435: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1184436: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4F94E6C0 to default port=5060
1184437: Dec 19 16:55:10.942: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1184438: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4F94E6C0
1184439: Dec 19 16:55:10.942: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4F94E6C0, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1184440: Dec 19 16:55:10.942: //2509932/28013998B3FF/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.96.3.1:5060
1184441: Dec 19 16:55:10.942: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1184442: Dec 19 16:55:10.942: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
1184443: Dec 19 16:55:10.942: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
1184444: Dec 19 16:55:10.942: //2509931/28013998B3FF/SIP/Info/sipSPIBufferCurrentEvent: Enqueueing event SIPSPI_EV_CC_NEW_MEDIA as Acknowledgment is not yet received..
1184445: Dec 19 16:55:10.942: //2509931/28013998B3FF/SIP/Info/sipSPIEnqueueBufferEvent: Event SIPSPI_EV_CC_NEW_MEDIA queued on buffer queue.
1184446: Dec 19 16:55:10.966: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cc94fd11d3c
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Date: Thu, 19 Dec 2013 16:55:10 GMT
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
1184447: Dec 19 16:55:10.970: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1184448: Dec 19 16:55:10.970: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1184449: Dec 19 16:55:10.970: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1184450: Dec 19 16:55:10.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:7950@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKcrq5th30aov08lchh2u0.1
To: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
CSeq: 98836991 PRACK
RAck: 736 98836990 INVITE
Max-Forwards: 68
Content-Length: 0
1184451: Dec 19 16:55:10.970: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1184452: Dec 19 16:55:10.970: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1184453: Dec 19 16:55:10.974: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1184454: Dec 19 16:55:10.974: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1184455: Dec 19 16:55:10.974: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1184456: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Info/act_recdinvite_new_message_request: Transaction Complete. Lock on Facilities released.
1184457: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Transport/sipSPISendPrackResponse: Sending PRACK Response to the transport layer
1184458: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4F94E6C0, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1184459: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1184460: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1184461: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4F94E6C0 to default port=5060
1184462: Dec 19 16:55:10.974: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1184463: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4F94E6C0
1184464: Dec 19 16:55:10.974: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4F94E6C0, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1184465: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
1184466: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Info/ccsip_offer_ans_handle_update_allowed:
1184467: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Info/force_internal_queue_lookup: There are 3 events on the internal queue
1184468: Dec 19 16:55:10.974: //2509931/28013998B3FF/SIP/Info/force_internal_queue_lookup: Dequeued event SIPSPI_EV_CC_NEW_MEDIA from internal buffer queue
1184469: Dec 19 16:55:10.974: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1184470: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 10.95.3.6:17760, codec 5
1184471: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_SENT_ALERTING
1184472: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1184473: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1184474: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509931, channels 0x4FA7EC2C caps 0x4F418850
1184475: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509931, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1184476: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
1184477: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 16
1184478: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/codec_found:
1184479: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1184480: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1184481: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
1184482: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 12
1184483: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Reset IS_FAX_TO_VOICE_SWITCH
1184484: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x400403
1184485: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
1184486: Dec 19 16:55:10.978: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1184487: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1184488: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: Build a line num_elements=1
1184489: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1184490: Dec 19 16:55:10.978: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1184491: Dec 19 16:55:10.982: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1184492: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: NTE max_event 15
1184493: Dec 19 16:55:10.982: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1184494: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1184495: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1184496: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17172, raddr = 208.29.69.22, rport=64744, do_rtcp=TRUE
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = SENDRECV
        media_ip_addr = 208.29.69.22, vrf tableid = 0 media_addr_type = 1
1184497: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1184498: Dec 19 16:55:10.982: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184499: Dec 19 16:55:10.982: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184500: Dec 19 16:55:10.982: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184501: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1184502: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184503: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184504: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB13C4
1184505: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1184506: Dec 19 16:55:10.982: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1184507: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1184508: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
1184509: Dec 19 16:55:10.982: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1184510: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1184511: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/force_internal_queue_lookup: There are 2 events on the internal queue
1184512: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/force_internal_queue_lookup: Dequeued event SIPSPI_EV_CC_CALL_CONNECT from internal buffer queue
1184513: Dec 19 16:55:10.986: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
1184514: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
1184515: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
1184516: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/sipSPIQoSRevertBW: Entry
1184517: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/preprocessConnect: Write sdp_info into msg_body
1184518: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1184519: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:4F7A4AE0
1184520: Dec 19 16:55:10.986: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
1184521: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uac, Min-SE Value:1800, flags:2801
1184522: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1184523: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1184524: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1184525: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184526: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184527: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509931
1184528: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Transaction active. Facilities will be queued.
SIP: (2509931) Group (a= group line) attribute, level 65535 instance 1 not found.
1184529: Dec 19 16:55:10.990: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1184530: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7A4AE0 to Invite Response 200
1184531: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
1184532: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FD36C08, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD6B68
1184533: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1184534: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1184535: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FD36C08 to default port=5060
1184536: Dec 19 16:55:10.994: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1184537: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FD36C08
1184538: Dec 19 16:55:10.994: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FD36C08, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1184539: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
1184540: Dec 19 16:55:10.994: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
1184541: Dec 19 16:55:10.994: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE)  to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
1184542: Dec 19 16:55:10.998: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Content-Length: 0
1184543: Dec 19 16:55:10.998: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1293 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 17172 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
1184544: Dec 19 16:55:11.126: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1184545: Dec 19 16:55:11.126: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1184546: Dec 19 16:55:11.126: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1184547: Dec 19 16:55:11.126: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKjr2tjk20dofh81amk050.1
CSeq: 98836990 ACK
Max-Forwards: 68
Content-Length: 0
1184548: Dec 19 16:55:11.126: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1184549: Dec 19 16:55:11.130: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1184550: Dec 19 16:55:11.130: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1184551: Dec 19 16:55:11.130: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1184552: Dec 19 16:55:11.130: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1184553: Dec 19 16:55:11.130: //2509931/28013998B3FF/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
1184554: Dec 19 16:55:11.130: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1184555: Dec 19 16:55:11.130: //2509931/28013998B3FF/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4F449C60
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 4254624012
Called Number            : 2587143682300
Source IP Address (Sig  ): 10.97.1.150
Destn SIP Req Addr:Port  : 208.29.69.6:5060
Destn SIP Resp Addr:Port : 208.29.69.6:5060
Destination Name         : 208.29.69.6
1184556: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.97.1.150
Source IP Port    (Media): 17172
Destn  IP Address (Media): 208.29.69.22
Destn  IP Port    (Media): 64744
Orig Destn IP Address:Port (Media): [ - ]:0
1184557: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1184558: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 208.29.69.22, RTCP Type 3
1184559: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1184560: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/ccsip_api_update_allowed: UPDATE(2) allowed
1184561: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/ccsip_offer_ans_handle_update_allowed:
1184562: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/force_internal_queue_lookup: There are 1 events on the internal queue
1184563: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/force_internal_queue_lookup: Dequeued event SIPSPI_EV_CC_NEW_MEDIA from internal buffer queue
1184564: Dec 19 16:55:11.134: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1184565: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 0.0.0.0:17760, codec 5
1184566: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_ACTIVE
1184567: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1184568: Dec 19 16:55:11.134: //2509931/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1184569: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1184570: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1184571: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1184572: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1184573: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1184574: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1184575: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1184576: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1184577: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1184578: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1184579: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1184580: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1184581: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1184582: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509931, channels 0x4FA5B45C caps 0x4F3F10C4
1184583: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509931, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1184584: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPIDtmfTranscoder: Return upon SCCP version 0
1184585: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1184586: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder:  Entry..
1184587: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: AudioLevelAdjustment do not need xcoder
1184588: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1184589: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPICodecTranscoder: No body else needs xcoder. OFFER_ALL is intact
1184590: Dec 19 16:55:11.138: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckVoiceClassCodecConfiguration: Either one of the call leg supports Voice Class Codec..
1184591: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Check between Equalset & Subset..
1184592: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/codec_found:
1184593: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1184594: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found.. continue for next codec..
1184595: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: This is Subset
1184596: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPICodecTranscoder: Static codec or Equalset or Subset w/o offer-all. For DO call, offer-all is NO-OP..
1184597: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/codec_found:
1184598: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1184599: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1184600: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPICheckAndReserveTranscoder: Xcoder is not needed
1184601: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1184602: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1184603: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Call hold using connection mute
1184604: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/sipSPIHoldMediaStream: Muting Stream 1
1184605: Dec 19 16:55:11.142: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184606: Dec 19 16:55:11.142: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184607: Dec 19 16:55:11.142: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184608: Dec 19 16:55:11.142: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1184609: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184610: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184611: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB13C4
1184612: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: Build a line num_elements=1
1184613: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1184614: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1184615: Dec 19 16:55:11.146: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1184616: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: NTE max_event 15
1184617: Dec 19 16:55:11.146: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1184618: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1184619: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1184620: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = INACTIVE
1184621: Dec 19 16:55:11.146: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1184622: Dec 19 16:55:11.146: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184623: Dec 19 16:55:11.150: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184624: Dec 19 16:55:11.150: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184625: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1184626: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184627: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184628: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB13C4
1184629: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1184630: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931: flags=147079196, flags2=268435712
1184631: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: CALL_HELD=0 Send Mid-call invite based on peer info
1184632: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=17172
1184633: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Error/sipSPIUpdateSrcSdpFixedPart:  owner_sessionid is already their OR src_sdp
                        is corrupted
1184634: Dec 19 16:55:11.150: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1184635: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1184636: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
1184637: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Media/sipSPIAddSDPMediaPayload: DTMF relay will be added in the caller. Skipping it
1184638: Dec 19 16:55:11.150: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1184639: Dec 19 16:55:11.150: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Add Media payload attributes for
                                    preferred codec's
1184640: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1184641: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1184642: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: Update QoS again before sending reInvite
1184643: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1184644: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 5 a-line(s) found for stream 1
1184645: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: No video stream when sending out reInvite.
1184646: Dec 19 16:55:11.154: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 244, curr send SDP size =
                      256
1184647: Dec 19 16:55:11.154: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
                          is not same.. so no comparision is done..
1184648: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 1293,
                         new version id = 1294
1184649: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)
1184650: Dec 19 16:55:11.154: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1184651: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: Transaction active. Facilities will be queued.
1184652: Dec 19 16:55:11.158: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1184653: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1184654: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4F7AAEE8
1184655: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1184656: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_INVALID_PEER_EVENT, SE Value:0, SE Refresher:none, Min-SE Value:0, flags:2801
1184657: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1184658: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1184659: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:21C0, posted event:E_STSL_INVALID_PEER_EVENT, reason:3
        Configured SE:1800, Configured Min-SE:1800
1184660: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
1184661: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184662: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184663: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1184664: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: not adding diversion headers for UAS re-INVITE
1184665: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: Associated container=0x4F7AAEE8 to Invite
1184666: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
1184667: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1184668: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x54C9E620, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD58D8
1184669: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1184670: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1184671: Dec 19 16:55:11.162: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1184672: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x54C9E620
1184673: Dec 19 16:55:11.162: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x54C9E620, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1184674: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Info/sentInviteRequest: Sent Invite in state STATE_SEND_MIDCALL_INVITE_PENDING
1184675: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
1184676: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Setting re_invite_init_flag
1184677: Dec 19 16:55:11.166: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679E854F
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Date: Thu, 19 Dec 2013 16:55:11 GMT
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0671168920-174516
1184745: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1184746: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184747: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184748: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB13C4
1184749: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold activated for stream 1
1184750: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1184751: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
1184752: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPIRSVPCompareSDP: Media Offer Changed
1184753: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1184754: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1184755: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1184756: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : Yes
1184757: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1184758: Dec 19 16:55:12.594: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1184759: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 peer 2509932 flags 0x404087 state STATE_SENT_MIDCALL_INVITE
1184760: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1184761: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1184762: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1184763: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1184764: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509931, Peer CallID 2509932, sdp 0x48F39E4C channels 0x4F44B1FC
1184765: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/copy_channels:
callId 2509931 size 240 ptr 0x4FA7EC2C)
1184766: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1184767: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1184768: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509931
1184769: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1184770: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1184771: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509931
1184772: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1184773: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509931 context 0x4FD9F6E0
1184774: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1184775: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1184776: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1184777: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 5
1184778: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1184779: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1184780: Dec 19 16:55:12.598: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1184781: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1184782: Dec 19 16:55:12.598: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 0.0.0.0:64744
1184783: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1184784: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509931, dtmf = 6
1184785: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1184786: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1184787: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1184788: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 flags 0x10000100 state STATE_SENT_MIDCALL_INVITE
1184789: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x8C0401C, ccb->pld.flags_ipip 0x404087
1184790: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Repoort 200OK to reINVITE
1184791: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Reset IS_FAX_TO_VOICE_SWITCH
1184792: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/copy_channels:
1184793: Dec 19 16:55:12.602: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 166)
1184794: Dec 19 16:55:12.602: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509931 chans 0x4FA7EC2C event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA7EC2C
1184795: Dec 19 16:55:12.602: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_ACK: peer ID 2509931 chans 0x4FA7EC2C event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA7EC2C
1184796: Dec 19 16:55:12.602: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1184797: Dec 19 16:55:12.602: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
                                         SIPSPI_EV_CC_NEW_MEDIA for CC_EV_H245_OPEN_CHANNEL_ACK!: peer ID 2509931 chans 0x4FA7EC2C event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA7EC2C
1184798: Dec 19 16:55:12.602: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1184799: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1184800: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1184801: Dec 19 16:55:12.602: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1184802: Dec 19 16:55:12.606: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509932, srcCallID=2509931,
                         peer_ccb->call_info.currentLocalName=,
1184803: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0xD79
1184804: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1ECE
1184805: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1184806: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1184807: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1184808: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1184809: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1184810: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1184811: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1184812: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1184813: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1184814: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1184815: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1184816: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1184817: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1184818: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1184819: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1184820: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1184821: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400005
1184822: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1184823: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1184824: Dec 19 16:55:12.606: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1184825: Dec 19 16:55:12.606: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1184826: Dec 19 16:55:12.606: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_CHANGING (4)
          Stream address type    : 1
          Callid                 : 2509931
          Negotiated Codec       : g711ulaw, bytes :160
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:17172
          Media Dest Addr/Port   : [0.0.0.0]:64744
1184827: Dec 19 16:55:12.606: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1184828: Dec 19 16:55:12.606: //2509931/28013998B3FF/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
1184829: Dec 19 16:55:12.606: //2509931/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:4FCC94A4
1184830: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509931) to the VOIP RTP library
1184831: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1184832: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1184833: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1184834: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        media_ip_addr = 0.0.0.0, vrf tableid = 0 media_addr_type = 1
1184835: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1184836: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Info/sipSPICreateRtpSession: sess: 4F952BB0 do_rtcp:1
1184837: Dec 19 16:55:12.610: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184838: Dec 19 16:55:12.610: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184839: Dec 19 16:55:12.610: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184840: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184841: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184842: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184843: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPICreateRtpSession: stun is disabled
1184844: Dec 19 16:55:12.610: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = INACTIVE
        Present Local Media Direction = SENDRECV
        New Local Media Direction = INACTIVE
        retVal = 1
1184845: Dec 19 16:55:12.610: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1184846: Dec 19 16:55:12.610: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184847: Dec 19 16:55:12.610: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184848: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184849: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184850: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184851: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184852: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1184853: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509931)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
1184854: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1184855: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
1184856: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1184857: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184858: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184859: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184860: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184861: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184862: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184863: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1184864: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 1
1184865: Dec 19 16:55:12.614: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1184866: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184867: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184868: Dec 19 16:55:12.614: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184869: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184870: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184871: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184872: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1184873: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
1184874: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/ccsip_get_channel_info_count:  : 1
1184875: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x2246
1184876: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x14B7
1184877: Dec 19 16:55:12.614: //2509931/28013998B3FF/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: g711ulaw, Bytes=160
1184878: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1184879: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1184880: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1184881: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1184882: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1184883: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1184884: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1184885: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1184886: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1184887: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1184888: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1184889: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1184890: Dec 19 16:55:12.618: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1184891: Dec 19 16:55:12.618: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=4254624012 4254624012,
1184892: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1ECE
1184893: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1ECE
1184894: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1184895: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1184896: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1184897: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1184898: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1184899: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1184900: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1184901: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1184902: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1184903: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1184904: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1184905: Dec 19 16:55:12.618: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
1184906: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1184907: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1184908: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1184909: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1184910: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400005
1184911: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1184912: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1184913: Dec 19 16:55:12.622: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1184914: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1184915: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/ccsip_api_response_answer: Modified QoS params INVITE
1184916: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/sact_sent_mid_invite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
1184917: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
1184918: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184919: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184920: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7A6EA0 to Ack
1184921: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1184922: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1184923: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F5EF08, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD7968
1184924: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1184925: Dec 19 16:55:12.622: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1184926: Dec 19 16:55:12.626: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1184927: Dec 19 16:55:12.626: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F5EF08
1184928: Dec 19 16:55:12.626: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F5EF08, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1184929: Dec 19 16:55:12.626: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1184930: Dec 19 16:55:12.626: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1184931: Dec 19 16:55:12.626: //2509931/28013998B3FF/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
1184932: Dec 19 16:55:12.626: //2509931/28013998B3FF/SIP/Call/sipSPICallInfo:
1184933: Dec 19 16:55:12.626: //2509931/28013998B3FF/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Destn  IP Address (Media): 0.0.0.0
1184934: Dec 19 16:55:12.626: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1184935: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509932 ft: 1, inc 0, 0.0.0.0:64744, codec 5
1184936: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509932 state STATE_MIDCALL_LOCAL_RESP_PENDING
1184937: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1184938: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1184939: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509932, channels 0x4FA7EC2C caps 0x4F2E2980
1184940: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509932, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1184941: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
1184942: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/codec_found:
1184943: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1184944: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1184945: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
1184946: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
1184947: Dec 19 16:55:12.626: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Reset IS_FAX_TO_VOICE_SWITCH
1184948: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x400005
1184949: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
1184950: Dec 19 16:55:12.630: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1184951: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1184952: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Call hold using connection mute
1184953: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPIHoldMediaStream: Muting Stream 1
1184954: Dec 19 16:55:12.630: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184955: Dec 19 16:55:12.630: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184956: Dec 19 16:55:12.630: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184957: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1184958: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184959: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184960: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F61EB8
1184961: Dec 19 16:55:12.630: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1184962: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 18742
1184963: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1184964: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1184965: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1184966: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1184967: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1184968: Dec 19 16:55:12.630: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 0.0.0.0, lport = 18742, raddr = 10.95.3.6, rport=17760, do_rtcp=FALSE
        src_callid = 2509932, dest_callid = 2509931, stream type = voice+dtmf, stream direction = INACTIVE
1184969: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1184970: Dec 19 16:55:12.634: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1184971: Dec 19 16:55:12.634: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184972: Dec 19 16:55:12.634: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184973: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1184974: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1184975: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1184976: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F61EB8
1184977: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1184978: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 5 a-line(s) found for stream 1
1184979: Dec 19 16:55:12.634: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 279, curr send SDP size =
                      248
1184980: Dec 19 16:55:12.634: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
1184981: Dec 19 16:55:12.634: //2509932/28013998B3FF/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 1207,
                         new version id = 1208
1184982: Dec 19 16:55:12.634: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1184983: Dec 19 16:55:12.634: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1184984: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/act_handle_app_media_event: method = 102 state = 16
1184985: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
1184986: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 0.0.0.0, RTCP Type 4
1184987: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPISetHoldTimer: Starting hold timer at 2880 minutes
1184988: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1184989: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:4F7AA390
1184990: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_RESP
1184991: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_INVALID_PEER_EVENT, SE Value:0, SE Refresher:none, Min-SE Value:0, flags:100
1184992: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 1800;refresher:uac peer refresher:none, flags:801, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1184993: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1184994: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184995: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1184996: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 2509932
1184997: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 2509932
1184998: Dec 19 16:55:12.638: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Transaction active. Facilities will be queued.
SIP: (2509932) Group (a= group line) attribute, level 65535 instance 1 not found.
1184999: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1185000: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AA390 to Invite Response 200
1185001: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
1185002: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4B37501C, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD7450
1185003: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1185004: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1185005: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4B37501C to default port=5060
1185006: Dec 19 16:55:12.642: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1185007: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4B37501C
1185008: Dec 19 16:55:12.642: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4B37501C, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1185009: Dec 19 16:55:12.642: //2509932/28013998B3FF/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
1185010: Dec 19 16:55:12.682: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679E919C4
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
1185011: Dec 19 16:55:12.682: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cc94fd11d3c
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Date: Thu, 19 Dec 2013 16:55:10 GMT
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
CSeq: 101 INVITE
Contact: <4254624012>
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Supported: timer
Content-Type: application/sdp
Content-Length: 248
v=0
o=CiscoSystemsSIP-GW-UserAgent 8988 1208 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 18742 RTP/AVP 0 101
c=IN IP4 0.0.0.0
a=inactive
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
1185012: Dec 19 16:55:12.686: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1185013: Dec 19 16:55:12.686: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1185014: Dec 19 16:55:12.686: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1185015: Dec 19 16:55:12.686: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1185016: Dec 19 16:55:12.686: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1185017: Dec 19 16:55:12.686: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Timestamp: 1387472111
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Supported:
Accept: application/media_control+xml,application/sdp,multipart/mixed
Content-Disposition: session;handling=required
Content-Length: 210
v=0
o=BroadWorks 86091758 2 IN IP4 208.29.69.22
s=-
c=IN IP4 0.0.0.0
t=0 0
m=audio 64744 RTP/AVP 0 101
a=fmtp:101 0-15
a=inactive
a=maxptime:20
1185018: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1185019: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7A6EA0 to Ack
1185020: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1185021: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1185022: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F5EF08, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1185023: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1185024: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1185025: Dec 19 16:55:12.690: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1185026: Dec 19 16:55:12.690: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F5EF08
1185027: Dec 19 16:55:12.690: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F5EF08, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1185028: Dec 19 16:55:12.714: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
1185029: Dec 19 16:55:12.714: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1185030: Dec 19 16:55:12.714: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1185031: Dec 19 16:55:12.746: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1185032: Dec 19 16:55:12.746: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1185033: Dec 19 16:55:12.746: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cca375f7d52
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: presence
Content-Length: 0
1185034: Dec 19 16:55:12.750: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1185035: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1185036: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1185037: Dec 19 16:55:12.750: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1185038: Dec 19 16:55:12.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1185039: Dec 19 16:55:12.750: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1185040: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
1185041: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1185042: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: Transaction Complete. Lock on Facilities released..
1185043: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: stream->rtcp_session->type:4
1185044: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: check for HA checkpoint trigger case; state:7, flags:0xC04018, flags2:0x10010120, platform_flags2:0x1004600, flags_ipip:0x400005, srcCcCallID:0x264C6C, destCcCallID:0x264C6B, confID:0x6ECB7
1185045: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start hold completet notifivation
1185046: Dec 19 16:55:12.750: //2509932/28013998B3FF/SIP/Info/sipSPIHoldCompleteNotificationRequest: sipSPIHoldCompleteNotificationRequest: Hold Type=Unknown
1185047: Dec 19 16:55:12.754: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
1185048: Dec 19 16:55:12.754: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
1185049: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1185050: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1185051: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ccb140fa59e
Date: Thu, 19 Dec 2013 16:55:12 GMT
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 0671168920-1745162723-3019877092-2825493512
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "VoiceMail" <7400>
Remote-Party-ID: "VoiceMail" <7400>;party=calling;screen=yes;privacy=off
Contact: <4254624012>;isFocus
Content-Length: 0
1185052: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1185053: Dec 19 16:55:12.754: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1185054: Dec 19 16:55:12.754: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1185055: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1185056: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1185057: Dec 19 16:55:12.754: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1185058: Dec 19 16:55:12.754: //2509932/28013998B3FF/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
1185059: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: Delayed Media in MidCall Invite
1185060: Dec 19 16:55:12.758: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1185061: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1185062: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1185063: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1185064: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1185065: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1185066: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1185067: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1185068: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1185069: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1185070: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1185071: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1185072: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1185073: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1185074: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1185075: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1185076: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1185077: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1185078: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1185079: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1185080: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1185081: Dec 19 16:55:12.758: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7A1C20
1185082: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1185083: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
1185084: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1185085: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1185086: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1185087: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2801
1185088: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2801, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1185089: Dec 19 16:55:12.762: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
1185593: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=17760 new=4000
1185594: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDONLY
        New Local Media Direction = RECVONLY
        retVal = 1
1185595: Dec 19 16:55:14.238: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1185596: Dec 19 16:55:14.238: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185597: Dec 19 16:55:14.238: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185598: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185599: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185600: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185601: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F61EB8
1185602: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: negotiated dtmf relay changed from rtp-nte to inband-voice
1185603: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=Yes RSVP_MEDIA_CHANGE=No
1185604: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
1185605: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1185606: Dec 19 16:55:14.238: //2509932/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1185607: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1185608: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : Yes
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : Yes
1185609: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1185610: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1185611: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 peer 2509931 flags 0x404005 state STATE_ACTIVE
1185612: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1185613: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1185614: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1185615: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1185616: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509932, Peer CallID 2509931, sdp 0x4FA9500C channels 0x4F43AAA4
1185617: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 468 ptr 0x48DED77C)
1185618: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1185619: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1185620: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1185621: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1185622: Dec 19 16:55:14.242: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1185623: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509932
1185624: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1185625: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509932 context 0x4FA5D5A0
1185626: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1185627: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1185628: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1185629: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/codec_found:
1185630: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1185631: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1185632: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1185633: Dec 19 16:55:14.246: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1185634: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1185635: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 10.96.3.1:4000
1185636: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1185637: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1185638: Dec 19 16:55:14.246: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1185639: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 flags 0x10010120 state STATE_ACTIVE
1185640: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC06018, ccb->pld.flags_ipip 0x404005
1185641: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report reINVITE  delayed media & mid_call_invite
1185642: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 240 ptr 0x4FA5B45C)
1185643: Dec 19 16:55:14.250: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1185644: Dec 19 16:55:14.250: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509932 chans 0x4FA5B45C event 165 flags 0x8C0601C 0x10400120 0x400087 data 0x4FA5B45C
1185645: Dec 19 16:55:14.250: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509932  chans 0x4FA5B45C event 165 flags 0x8C0601C 0x10400120 0x400087 data 0x4FA5B45C
1185646: Dec 19 16:55:14.250: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1185647: Dec 19 16:55:14.250: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509932 chans 0x4FA5B45C event 165 flags 0x8C0601C 0x10400120 0x400087 data 0x4FA5B45C Media Trigger 0
1185648: Dec 19 16:55:14.250: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1185649: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1185650: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1185651: Dec 19 16:55:14.250: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1185652: Dec 19 16:55:14.250: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509931, srcCallID=2509932,
                         peer_ccb->call_info.currentLocalName=4254624012 4254624012,
1185653: Dec 19 16:55:14.250: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x14B7
1185654: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x14B7
1185655: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1185656: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1185657: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1185658: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1185659: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1185660: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1185661: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1185662: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1185663: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1185664: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1185665: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1185666: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1185667: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1185668: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1185669: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1185670: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1185671: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1185672: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400087
1185673: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1185674: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1185675: Dec 19 16:55:14.254: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1185676: Dec 19 16:55:14.254: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1185677: Dec 19 16:55:14.254: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice-only
          Media line             : 1
          Callid                 : 2509932
          Negotiated DTMF relay  : inband-voice
          Negotiated NTE payload : 0 (tx), 0 (rx)
          Media Srce Addr/Port   : [10.97.1.150]:18742
          Media Dest Addr/Port   : [10.96.3.1]:4000
1185678: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/is_call_held: Remote media IP addr: 10.96.3.1
1185679: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/is_call_held: Media IP Addr 0.0.0.0, RTCP Type 2
1185680: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1185681: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
1185682: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:4FCC94A4
1185683: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 2509932) to the VOIP RTP library
1185684: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1185685: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1185686: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1185687: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 18742, raddr = 10.96.3.1, rport=4000, do_rtcp=FALSE
        src_callid = 2509932, dest_callid = 2509931, stream type = voice-only, stream direction = RECVONLY
        media_ip_addr = 10.96.3.1, vrf tableid = 0 media_addr_type = 1
1185688: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1185689: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/sipSPICreateRtpSession: sess: 48F6B838 do_rtcp:0
1185690: Dec 19 16:55:14.258: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1185691: Dec 19 16:55:14.258: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185692: Dec 19 16:55:14.258: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185693: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185694: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185695: Dec 19 16:55:14.258: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185696: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPICreateRtpSession: stun is disabled
1185697: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 1
1185698: Dec 19 16:55:14.262: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction RECVONLY for stream 1
1185699: Dec 19 16:55:14.262: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1185700: Dec 19 16:55:14.262: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185701: Dec 19 16:55:14.262: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185702: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185703: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185704: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185705: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1185706: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509932)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
1185707: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1185708: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
1185709: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1185710: Dec 19 16:55:14.262: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1185711: Dec 19 16:55:14.262: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185712: Dec 19 16:55:14.262: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185713: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185714: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185715: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185716: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1185717: Dec 19 16:55:14.262: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 1
1185718: Dec 19 16:55:14.266: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction RECVONLY for stream 1
1185719: Dec 19 16:55:14.266: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1185720: Dec 19 16:55:14.266: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185721: Dec 19 16:55:14.266: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185722: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185723: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185724: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185725: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1185726: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
1185727: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/ccsip_get_channel_info_count:  : 1
1185728: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1ECE
1185729: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1185730: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: g711ulaw, Bytes=160
1185731: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1185732: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
1185733: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x1, caps.stream_list.xmitFunc=
1185734: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1185735: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1185736: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
1185737: Dec 19 16:55:14.266: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1185738: Dec 19 16:55:14.270: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1185739: Dec 19 16:55:14.270: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1185740: Dec 19 16:55:14.270: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1185741: Dec 19 16:55:14.270: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1185742: Dec 19 16:55:14.270: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1185743: Dec 19 16:55:14.270: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
                         ccb->call_info.currentLocalName=,
1185744: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x14B7
1185745: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x14B7
1185746: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1185747: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1185748: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1185749: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1185750: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1185751: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1185752: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1185753: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1185754: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1185755: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1185756: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1185757: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1185758: Dec 19 16:55:14.270: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1185759: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1185760: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1185761: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1185762: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1185763: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400087
1185764: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1185765: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1185766: Dec 19 16:55:14.274: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1185767: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1185768: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Error/sipSPIProcessAckMedia: Could not modify QoS params for midcall INVITE
1185769: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPIQoSRevertBW: Entry
1185770: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1185771: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1185772: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1185773: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1185774: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1185775: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_answer: Could not add hdrs for ev:1
1185776: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_answer: ACK handling retval: SIP_SUCCESS
1185777: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_request_answer returned: SIP_SUCCESS
1185778: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: stream->rtcp_session->type:2
1185779: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: check for HA checkpoint trigger case; state:7, flags:0xC04018, flags2:0x10010120, platform_flags2:0x4600, flags_ipip:0x400005, srcCcCallID:0x264C6C, destCcCallID:0x264C6B, confID:0x6ECB7
1185780: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start hold completet notifivation
1185781: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPIHoldCompleteNotificationRequest: sipSPIHoldCompleteNotificationRequest: Hold Type=Unknown
1185782: Dec 19 16:55:14.274: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
1185783: Dec 19 16:55:14.278: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1185784: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
1185785: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
1185786: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 10.96.3.1:4000, codec 5
1185787: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_SENT_MIDCALL_INVITE
1185788: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1185789: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1185790: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509931, channels 0x4FA5B45C caps 0x4F3C6A70
1185791: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509931, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1185792: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
1185793: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 16
1185794: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 5
1185795: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1185796: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1185797: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
1185798: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 12
1185799: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Reset IS_FAX_TO_VOICE_SWITCH
1185800: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x400087
1185801: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
1185802: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
retreive codec 5 ptype 0 time 0 bytes 160
1185803: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
stream negotiated codec retreive codec 5
1185804: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1185805: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1185806: Dec 19 16:55:14.278: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1185807: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17172, raddr = 208.29.69.22, rport=64744, do_rtcp=TRUE
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = SENDONLY
        media_ip_addr = 208.29.69.22, vrf tableid = 0 media_addr_type = 1
1185808: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1185809: Dec 19 16:55:14.282: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185810: Dec 19 16:55:14.282: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185811: Dec 19 16:55:14.282: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185812: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185813: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185814: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185815: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F44A60
1185816: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1185817: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: CCSIP: sending Delay media ACK
1185818: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1185819: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1185820: Dec 19 16:55:14.282: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDONLY for stream 1
1185821: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1185822: Dec 19 16:55:14.282: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
1185823: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1185824: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1185825: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateQoSAttributesNewSDP: Entry
1185826: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 4 a-line(s) found for stream 1
1185827: Dec 19 16:55:14.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 256, curr send SDP size =
                      244
1185828: Dec 19 16:55:14.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
                          is not same.. so no comparision is done..
1185829: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 1294,
                         new version id = 1295
1185830: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
1185831: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1185832: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1185833: Dec 19 16:55:14.286: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1185834: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7A1C20 to Ack
1185835: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1185836: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1185837: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F476FC, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD7968
1185838: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1185839: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1185840: Dec 19 16:55:14.290: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1185841: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F476FC
1185842: Dec 19 16:55:14.290: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F476FC, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1185843: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1185844: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1185845: Dec 19 16:55:14.290: //2509931/28013998B3FF/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
1185846: Dec 19 16:55:14.338: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 291
v=0
o=CiscoSystemsSIP-GW-UserAgent 8988 1209 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 18742 RTP/AVP 0 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
1185847: Dec 19 16:55:14.338: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679EB1C6D
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Date: Thu, 19 Dec 2013 16:55:13 GMT
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1295 IN IP4 10.97.1.150
s=SIP Call
t=0 0
m=audio 17172 RTP/AVP 0 101
a=sendonly
a=fmtp:101 0-15
1185848: Dec 19 16:55:14.342: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1185849: Dec 19 16:55:14.342: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1185850: Dec 19 16:55:14.342: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1185851: Dec 19 16:55:14.342: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1185852: Dec 19 16:55:14.342: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1185853: Dec 19 16:55:14.346: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1185854: Dec 19 16:55:14.346: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1185855: Dec 19 16:55:14.346: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679EA234B
CSeq: 102 INVITE
Timestamp: 1387472112
Supported:
Content-Length: 286
v=0
o=BroadWorks 86091758 3 IN IP4 208.29.69.22
s=-
c=IN IP4 208.29.69.22
t=0 0
m=audio 64744 RTP/AVP 0 8 18 101
a=rtpmap:8 PCMA/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1185856: Dec 19 16:55:14.346: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1185857: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7A1C20 to Ack
1185858: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1185859: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1185860: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48E0838C, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1185861: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1185862: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1185863: Dec 19 16:55:14.350: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1185864: Dec 19 16:55:14.350: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48E0838C
1185865: Dec 19 16:55:14.350: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48E0838C, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1185866: Dec 19 16:55:14.350: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1185867: Dec 19 16:55:14.350: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1185868: Dec 19 16:55:14.350: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ccd3bde9217
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 183
v=0
o=CiscoSystemsCCM-SIP 496442 4 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 4000 RTP/AVP 0
a=X-cisco-media:umoh
a=ptime:20
a=inactive
1185869: Dec 19 16:55:14.350: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1185870: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1185871: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1185872: Dec 19 16:55:14.354: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1185873: Dec 19 16:55:14.354: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1185874: Dec 19 16:55:14.354: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1185875: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
1185876: Dec 19 16:55:14.354: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1185877: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1185878: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1185879: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1185880: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1185881: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1185882: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1185883: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1185884: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1185885: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1185886: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1185887: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1185888: Dec 19 16:55:14.354: //2509932/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1185889: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1185890: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1185891: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1185892: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1185893: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1185894: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1185895: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1185896: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1185897: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7AAEE8
1185898: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1185899: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
1185900: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1185901: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1185902: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1185903: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMidDialogSRReqWithOutSEPeerEventGen: session timer already turned off on this leg
1185904: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2841
1185905: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2841, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1185906: Dec 19 16:55:14.358: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
1185907: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
SIP: Warning: Unrecognized attribute (X-cisco-media)
1185908: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1185909: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 4000
SIP: Attribute mid, level 1 instance 1 not found.
1185910: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1185911: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1185912: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1185913: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
1185914: Dec 19 16:55:14.362: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
1185915: Dec 19 16:55:14.362: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1185916: Dec 19 16:55:14.362: //2509932/28013998B3FF/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
1185917: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1185918: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1185919: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY option(s) not found in Preferred DTMF-RELAY option list!
1185920: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sipSPIStreamTypeAndDtmfRelay: DTMF Relay mode: Inband Voice
1185921: Dec 19 16:55:14.366: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1185922: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1185923: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1185924: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=inband-voice
        stream_type=voice-only (0), dest_ip_address=0.0.0.0, dest_port=4000
1185925: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1185926: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=4000 new=4000
1185927: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = INACTIVE
        Present Local Media Direction = RECVONLY
        New Local Media Direction = INACTIVE
        retVal = 1
1185928: Dec 19 16:55:14.366: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185929: Dec 19 16:55:14.366: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185930: Dec 19 16:55:14.366: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185931: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185932: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185933: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185934: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1185935: Dec 19 16:55:14.366: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185936: Dec 19 16:55:14.366: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185937: Dec 19 16:55:14.366: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185938: Dec 19 16:55:14.366: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1185939: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1185940: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1185941: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FCC94A4
1185942: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold activated for stream 1
1185943: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1185944: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
1185945: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Media Changes : 128:
1185946: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1185947: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1185948: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1185949: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : No
        DSP DNLD Reqd          : No
1185950: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1185951: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1185952: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 peer 2509931 flags 0x400005 state STATE_ACTIVE
1185953: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1185954: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1185955: Dec 19 16:55:14.370: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1185956: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1185957: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509932, Peer CallID 2509931, sdp 0x48F39E4C channels 0x4F43AAA4
1185958: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/copy_channels:
1185959: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1185960: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1185961: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1185962: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1185963: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1185964: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
1185965: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1185966: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
1185967: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1185968: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1185969: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1185970: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/codec_found:
1185971: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1185972: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1185973: Dec 19 16:55:14.374: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1185974: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1185975: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 0.0.0.0:4000
1185976: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1185977: Dec 19 16:55:14.374: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1186612: Dec 19 16:55:15.170: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1186613: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1186614: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1186615: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Info/sipSPISendUpdateResponse: Associated container=0x4F7AAEE8 to Update Response
1186616: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Transport/sipSPISendUpdateResponse: Sending UPDATE Response to the transport layer
1186617: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FB1B3B8, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1186618: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1186619: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1186620: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FB1B3B8 to default port=5060
1186621: Dec 19 16:55:15.174: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1186622: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FB1B3B8
1186623: Dec 19 16:55:15.174: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FB1B3B8, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1186624: Dec 19 16:55:15.174: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1186625: Dec 19 16:55:15.178: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg: ccb NULL, unable to update the callinfo ui parameters
1186626: Dec 19 16:55:15.178: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1186627: Dec 19 16:55:15.190: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ccf2a37a32a
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Date: Thu, 19 Dec 2013 16:55:15 GMT
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 104 UPDATE
Allow-Events: telephone-event
Contact: <4254624012>
Supported: timer
Content-Length: 0
1186628: Dec 19 16:55:15.190: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1186629: Dec 19 16:55:15.190: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPreProcessCallerIDMediaEvent: Updated Connected Party Name: OPERATOR Updated Connected Party Number: 202300 Updated Connected Party Oct3a: 0xFFFFFF81
1186630: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/act_handle_app_media_event: method = 109 state = 7
1186631: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_OFFER
1186632: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
1186633: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sact_app_media_event_send_request: Transaction active. CCAPI events will be queued.
1186634: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1186635: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:0, container:4F7A6EA0
1186636: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1186637: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_INVALID_PEER_EVENT, SE Value:0, SE Refresher:none, Min-SE Value:0, flags:841
1186638: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1186639: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1186640: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:1C0, posted event:E_STSL_INVALID_PEER_EVENT, reason:3
1186641: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 6 event
1186642: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1186643: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1186644: Dec 19 16:55:15.194: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
SIP: (2509931) Group (a= group line) attribute, level 65535 instance 1 not found.
1186645: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1186646: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509931
1186647: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Info/sipSPISendUpdate: Associated container=0x4F7A6EA0 to Update
1186648: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Transport/sipSPISendUpdate: Sending UPDATE to the transport layer
1186649: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1186650: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48EEA580, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD774C
1186651: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1186652: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1186653: Dec 19 16:55:15.198: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1186654: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48EEA580
1186655: Dec 19 16:55:15.198: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48EEA580, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1186656: Dec 19 16:55:15.198: //2509931/28013998B3FF/SIP/Info/sentUpdate: Sent Update Request, starting UpdateTimer
1186657: Dec 19 16:55:15.202: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679EE3DE
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Timestamp: 1387472115
CSeq: 104 UPDATE
Contact: <2587143682300>
Min-SE:  1800
Content-Length: 0
1186658: Dec 19 16:55:15.202: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1186659: Dec 19 16:55:15.202: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1186660: Dec 19 16:55:15.206: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1186661: Dec 19 16:55:15.206: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1186662: Dec 19 16:55:15.206: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1186663: Dec 19 16:55:15.206: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1186664: Dec 19 16:55:15.206: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679EC1B28
CSeq: 103 INVITE
Timestamp: 1387472114
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Supported:
Accept: application/media_control+xml,application/sdp,multipart/mixed
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 210
v=0
o=BroadWorks 86091758 4 IN IP4 208.29.69.22
s=-
c=IN IP4 0.0.0.0
t=0 0
m=audio 64744 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=inactive
a=maxptime:20
1186665: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1186666: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7ADEB0 to Ack
1186667: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1186668: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1186669: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48EEA580, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1186670: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1186671: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1186672: Dec 19 16:55:15.210: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1186673: Dec 19 16:55:15.210: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48EEA580
1186674: Dec 19 16:55:15.210: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48EEA580, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1186675: Dec 19 16:55:15.210: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1186676: Dec 19 16:55:15.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1186677: Dec 19 16:55:15.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cd0f6c5cf7
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 0671168920-1745162723-3019877092-2825493512
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 105 INVITE
Max-Forwards: 70
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "OPERATOR" <202300>
Remote-Party-ID: "OPERATOR" <202300>;party=calling;screen=yes;privacy=off
Content-Length: 0
1186678: Dec 19 16:55:15.214: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1186679: Dec 19 16:55:15.214: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1186680: Dec 19 16:55:15.214: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1186681: Dec 19 16:55:15.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1186682: Dec 19 16:55:15.214: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1186683: Dec 19 16:55:15.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1186684: Dec 19 16:55:15.214: //2509932/28013998B3FF/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
1186685: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: Delayed Media in MidCall Invite
1186686: Dec 19 16:55:15.218: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1186687: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1186688: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1186689: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1186690: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1186691: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1186692: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1186693: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1186694: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1186695: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1186696: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1186697: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1186698: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1186699: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1186700: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1186701: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1186702: Dec 19 16:55:15.218: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1186703: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1186704: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1186705: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1186706: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1186707: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7AADE0
1186708: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1186709: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
1186710: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1186711: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1186712: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1186713: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMidDialogSRReqWithOutSEPeerEventGen: session timer already turned off on this leg
1186714: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2841
1186715: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
1186716: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
1186717: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithNoMediaLine: Local Precondition: 1, Remote Precondition: 1
1186718: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
1186719: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
1186720: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sipSPIAddSDPPayloadAttributes:
max_event 15
1186721: Dec 19 16:55:15.222: //2509932/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1186722: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1186723: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 5 a-line(s) found for stream 1
1186724: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
1186725: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1186726: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1186727: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1186728: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1186729: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1186730: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 240 ptr 0x4FA7EC2C)
1186731: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1186732: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1186733: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1186734: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1186735: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1186736: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509932
1186737: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1186738: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509932 context 0x4FA5D5A0
1186739: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1186740: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1186741: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1186742: Dec 19 16:55:15.226: //2509932/28013998B3FF/SIP/Info/codec_found:
1186743: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1186744: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1186745: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1186746: Dec 19 16:55:15.230: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1186747: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1186748: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1186749: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1186750: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1186751: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1186752: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 flags 0x10010120 state STATE_ACTIVE
1186753: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC06018, ccb->pld.flags_ipip 0x400005
1186754: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report reINVITE  delayed media & mid_call_invite
1186755: Dec 19 16:55:15.230: //2509932/28013998B3FF/SIP/Info/copy_channels:
1186756: Dec 19 16:55:15.230: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1186757: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509932 chans 0x4FA7EC2C event 165 flags 0x8C0401C 0x10000100 0x400007 data 0x4FA7EC2C
1186758: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509932  chans 0x4FA7EC2C event 165 flags 0x8C0401C 0x10000100 0x400007 data 0x4FA7EC2C
1186759: Dec 19 16:55:15.234: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1186760: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509932 chans 0x4FA7EC2C event 165 flags 0x8C0401C 0x10000100 0x400007 data 0x4FA7EC2C Media Trigger 0
1186761: Dec 19 16:55:15.234: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1186762: Dec 19 16:55:15.234: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: not sendig Video chan ind for DO Invite case
1186763: Dec 19 16:55:15.234: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1186764: Dec 19 16:55:15.234: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1186765: Dec 19 16:55:15.234: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1186766: Dec 19 16:55:15.234: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509931, srcCallID=2509932,
                         peer_ccb->call_info.currentLocalName=4254624012 4254624012,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=OPERATOR,
1186767: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x1079
1186768: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x1079
1186769: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec:  Mid-call OFFER is pending
1186770: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1186771: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1186772: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1186773: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1186774: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1186775: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1186776: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1186777: Dec 19 16:55:15.234: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1186778: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1186779: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1186780: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1186781: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
1186782: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1186783: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1186784: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1186785: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1186786: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400007
1186787: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1186788: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1186789: Dec 19 16:55:15.238: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1186790: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1186791: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
1186792: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS_DELAYED_MEDIA
1186793: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1186794: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7AAEE8
1186795: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1186796: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1186797: Dec 19 16:55:15.238: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD ContainerSIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679EF1F89
CSeq: 105 INVITE
Timestamp: 1387472116
Supported:
Content-Length: 286
v=0
o=BroadWorks 86091758 5 IN IP4 208.29.69.22
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1187474: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1187475: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7AADE0 to Ack
1187476: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1187477: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1187478: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48EEA580, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1187479: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1187480: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1187481: Dec 19 16:55:17.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1187482: Dec 19 16:55:17.022: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48EEA580
1187483: Dec 19 16:55:17.022: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48EEA580, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1187484: Dec 19 16:55:17.026: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F02A4
Date: Thu, 19 Dec 2013 16:55:16 GMT
Max-Forwards: 70
CSeq: 105 ACK
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1297 IN IP4 10.97.1.150
s=SIP Call
t=0 0
a=sendonly
a=fmtp:101 0-15
1187485: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C68
1187486: Dec 19 16:55:18.098: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850244] removed.
1187487: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
1187488: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F4B7800 key=SDupen901-156b0057282416d7e216076441763858-v300g00
1187489: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
1187490: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1187491: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1187492: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/ccsip_offer_ans_delete:
1187493: Dec 19 16:55:18.098: //2509928/193C0A24B3F7/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F4B7800
1187494: Dec 19 16:55:18.790: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1187495: Dec 19 16:55:18.790: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1187496: Dec 19 16:55:18.790: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1187497: Dec 19 16:55:18.790: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:5202492879@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cd21579d764
From: <202911>;tag=496441~918169ec-01b0-412c-a6fb-1b14e25860d5-31543761
To: "PRINTRONIX" <5202492879>;tag=6170EAEC-1CFF
Date: Thu, 19 Dec 2013 16:55:02 GMT
Call-ID: 2301E97F-680511E3-B3FEAAE4-A8699C08@10.97.1.150
Max-Forwards: 70
CSeq: 101 UPDATE
P-Asserted-Identity: <7400>
Remote-Party-ID: <7400>;party=calling;screen=yes;privacy=off
Contact: <5202492879>;isFocus
Content-Length: 0
1187498: Dec 19 16:55:18.794: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1187499: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F42E578
1187500: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1187501: Dec 19 16:55:18.794: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1187502: Dec 19 16:55:18.794: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1187503: Dec 19 16:55:18.794: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1187504: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1187505: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/ccsipEarlyDialogUpdateParams:  Entry..
1187506: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/ccsip_api_request_offer: prev_send_sdp_buf is not allocated
1187507: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1187508: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1187509: Dec 19 16:55:18.794: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1187510: Dec 19 16:55:18.798: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1187511: Dec 19 16:55:18.798: //2509930/22FDA3CEB3F8/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1187512: Dec 19 16:55:18.798: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F4B7800) with key=[1850250] to table
1187513: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1187514: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1187515: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: , current remote number: 7400
1187516: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
1187517: Dec 19 16:55:18.798: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850250] removed.
1187518: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1187519: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1187520: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/ccsip_offer_ans_delete:
1187521: Dec 19 16:55:18.798: //-1/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F4B7800
1187522: Dec 19 16:55:18.798: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1187523: Dec 19 16:55:18.798: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:109, resp_code:0, container:4F7AF038
1187524: Dec 19 16:55:18.798: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1187525: Dec 19 16:55:18.802: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1187526: Dec 19 16:55:18.802: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleNewEarlyDialogOffer: ccsip_api_request_offer return val:SIP_SUCCESS
1187527: Dec 19 16:55:18.802: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1187528: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/act_handle_app_media_event: method = 109 state = 4
1187529: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
1187530: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1187531: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:200, container:4F7A8E98
1187532: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1187533: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1187534: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1187535: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1187536: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Info/sipSPISendUpdateResponse: Associated container=0x4F7A8E98 to Update Response
1187537: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPISendUpdateResponse: Sending UPDATE Response to the transport layer
1187538: Dec 19 16:55:18.802: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA52F78, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1187539: Dec 19 16:55:18.806: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1187540: Dec 19 16:55:18.806: //2509930/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1187541: Dec 19 16:55:18.806: //2509930/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FA52F78 to default port=5060
1187542: Dec 19 16:55:18.806: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1187543: Dec 19 16:55:18.806: //2509930/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FA52F78
1187544: Dec 19 16:55:18.806: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA52F78, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1187545: Dec 19 16:55:18.806: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg: ccb NULL, unable to update the callinfo ui parameters
1187546: Dec 19 16:55:18.806: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1187547: Dec 19 16:55:18.806: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1187548: Dec 19 16:55:18.810: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPreProcessCallerIDMediaEvent: Updated Connected Party Name:  Updated Connected Party Number: 7400 Updated Connected Party Oct3a: 0xFFFFFF81
1187549: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/act_handle_app_media_event: method = 109 state = 14
1187550: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_OFFER
1187551: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
1187552: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/sact_app_media_event_send_request: Transaction active. CCAPI events will be queued.
1187553: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1187554: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:0, container:4F7A8E98
1187555: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1187556: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 6 event
1187557: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1187558: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1187559: Dec 19 16:55:18.810: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1187560: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509929
1187561: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Info/sipSPISendUpdate: Associated container=0x4F7A8E98 to Update
1187562: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPISendUpdate: Sending UPDATE to the transport layer
1187563: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1187564: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: msg=0x4FD30FC8, addr=208.29.69.38, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD774C
1187565: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1187566: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1187567: Dec 19 16:55:18.814: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.38, rport:5060 with laddr:10.97.1.150
1187568: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FD30FC8
1187569: Dec 19 16:55:18.814: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FD30FC8, addr=208.29.69.38, port=5060, local_addr=10.97.1.150, connId=4 for UDP
1187570: Dec 19 16:55:18.814: //2509929/22FDA3CEB3F8/SIP/Info/sentUpdate: Sent Update Request, starting UpdateTimer
1187571: Dec 19 16:55:18.826: //2509930/22FDA3CEB3F8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 19 Dec 2013 16:55:18 GMT
CSeq: 101 UPDATE
Content-Length: 0
1187572: Dec 19 16:55:18.830: //2509929/22FDA3CEB3F8/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:5202492879@208.29.69.38:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F1F3
From: "7143682911 7143682911"<2587143682911>;tag=6170EB04-F37
To: "PRINTRONIX"<5202492879>;tag=SD0dsrd01-1465180822-1387472102195-
Call-ID: SD0dsrd01-c64e5874f3025ec1c90ef3402f710bc6-v300g00
Max-Forwards: 70
Timestamp: 1387472118
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 UPDATE
Contact: <2587143682911>
Min-SE:  1800
Content-Length: 0
1187573: Dec 19 16:55:18.850: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1187574: Dec 19 16:55:18.850: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1187575: Dec 19 16:55:18.850: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1187576: Dec 19 16:55:18.850: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1187577: Dec 19 16:55:18.850: //2509930/22FDA3CEB3F8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679E41385
To: <202911>;tag=496441~918169ec-01b0-412c-a6fb-1b14e25860d5-31543761
CSeq: 101 INVITE
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
P-Asserted-Identity: "VoiceMail" <7400>
Remote-Party-ID: "VoiceMail" <7400>;party=called;screen=yes;privacy=off
Contact: <202911>;isFocus
Content-Length: 231
v=0
o=CiscoSystemsCCM-SIP 496441 1 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 10.96.3.2
b=TIAS:64000
b=AS:64
t=0 0
m=audio 20814 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
1187578: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1187579: Dec 19 16:55:18.854: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1187580: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
1187581: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
1187582: Dec 19 16:55:18.854: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 2509929/2509930
1187583: Dec 19 16:55:18.854: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=2509929, new streamcallid=2509929
1187584: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
1187585: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1187586: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:4F7A42A0
1187587: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: uas
1187588: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
1187589: Dec 19 16:55:18.854: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLProcessLegByLegPeerEvent: session expires received in response so starting session timer
1187590: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLStartSessionTimer: Started Session Expiry Timer with duration:1768000
1187591: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
1187592: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 1800;refresher:uas peer refresher:none, flags:801, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
1187593: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1187594: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1187595: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1187596: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1187597: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1187598: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/ccsip_api_call_connect_media:  Unable to add headers into container
1187599: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
1187600: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1187601: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 20814
1187602: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1187603: Dec 19 16:55:18.858: //2509930/22FDA3CEB3F8/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1187604: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
1187605: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1187606: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1187607: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1187608: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1187609: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1187610: Dec 19 16:55:18.858: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1187611: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1187612: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
1187613: Dec 19 16:55:18.862: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
1187614: Dec 19 16:55:18.862: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1187615: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
1187616: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1187617: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1187618: Dec 19 16:55:18.862: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1187619: Dec 19 16:55:18.862: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1187620: Dec 19 16:55:18.862: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1187621: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1187622: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1187623: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1187624: Dec 19 16:55:18.862: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1187625: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1187626: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1187627: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=10.96.3.2, dest_port=20814
1187628: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1187629: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1187630: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
1187631: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1187632: Dec 19 16:55:18.862: //2509930/22FDA3CEB3F8/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1187633: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509930 peer 2509929 flags 0x400005 state STATE_RECD_PROCEEDING
1187634: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1187635: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1187636: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1187637: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1187638: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509930, Peer CallID 2509929, sdp 0x4FA9500C channels 0x4F42FB14
1187639: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/copy_channels:
callId 2509930 size 468 ptr 0x4F920B9C)
1187640: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1187641: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1187642: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509930
1187643: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1187644: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1187645: Dec 19 16:55:18.866: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1187900: Dec 19 16:55:24.230: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1187901: Dec 19 16:55:24.230: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1187902: Dec 19 16:55:24.230: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1187903: Dec 19 16:55:24.230: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cd34d00c3d5
Date: Thu, 19 Dec 2013 16:55:24 GMT
Min-SE:  1800
CSeq: 106 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 183
v=0
o=CiscoSystemsCCM-SIP 496442 6 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 4000 RTP/AVP 0
a=X-cisco-media:umoh
a=ptime:20
a=inactive
1187904: Dec 19 16:55:24.234: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1187905: Dec 19 16:55:24.234: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1187906: Dec 19 16:55:24.234: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1187907: Dec 19 16:55:24.234: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1187908: Dec 19 16:55:24.234: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1187909: Dec 19 16:55:24.234: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1187910: Dec 19 16:55:24.234: //2509932/28013998B3FF/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
1187911: Dec 19 16:55:24.238: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1187912: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1187913: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1187914: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1187915: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1187916: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1187917: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1187918: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1187919: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1187920: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1187921: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1187922: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1187923: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1187924: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1187925: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1187926: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1187927: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1187928: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1187929: Dec 19 16:55:24.238: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1187930: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1187931: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1187932: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7AF038
1187933: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1187934: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
1187935: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1187936: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1187937: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1187938: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMidDialogSRReqWithOutSEPeerEventGen: session timer already turned off on this leg
1187939: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2841
1187940: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2841, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1187941: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
1187942: Dec 19 16:55:24.242: //2509932/28013998B3FF/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
SIP: Warning: Unrecognized attribute (X-cisco-media)
1187943: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1187944: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 4000
SIP: Attribute mid, level 1 instance 1 not found.
1187945: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1187946: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1187947: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1187948: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
1187949: Dec 19 16:55:24.246: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
1187950: Dec 19 16:55:24.246: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1187951: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
1187952: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1187953: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1187954: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY option(s) not found in Preferred DTMF-RELAY option list!
1187955: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIStreamTypeAndDtmfRelay: DTMF Relay mode: Inband Voice
1187956: Dec 19 16:55:24.246: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1187957: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1187958: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1187959: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=inband-voice
        stream_type=voice-only (0), dest_ip_address=0.0.0.0, dest_port=4000
1187960: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1187961: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=4000 new=4000
1187962: Dec 19 16:55:24.246: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = INACTIVE
        Present Local Media Direction = RECVONLY
        New Local Media Direction = INACTIVE
        retVal = 1
1187963: Dec 19 16:55:24.246: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1187964: Dec 19 16:55:24.250: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1187965: Dec 19 16:55:24.250: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1187966: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1187967: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1187968: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1187969: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1187970: Dec 19 16:55:24.250: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1187971: Dec 19 16:55:24.250: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1187972: Dec 19 16:55:24.250: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1187973: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1187974: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1187975: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1187976: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1187977: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold activated for stream 1
1187978: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1187979: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
1187980: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Media Changes : 128:
1187981: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1187982: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1187983: Dec 19 16:55:24.250: //2509932/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1187984: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : No
        DSP DNLD Reqd          : No
1187985: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1187986: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1187987: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 peer 2509931 flags 0x400005 state STATE_ACTIVE
1187988: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1187989: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1187990: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1187991: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1187992: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509932, Peer CallID 2509931, sdp 0x4F91E80C channels 0x4F43AAA4
1187993: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/copy_channels:
1187994: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1187995: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1187996: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1187997: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1187998: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1187999: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
1188000: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1188001: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
1188002: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1188003: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1188004: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1188005: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 5
1188006: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1188007: Dec 19 16:55:24.254: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1188008: Dec 19 16:55:24.254: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1188009: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1188010: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 0.0.0.0:4000
1188011: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1188012: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1188013: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1188014: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
1188015: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC04018, ccb->pld.flags_ipip 0x400005
1188016: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report RE-INVITE media
1188017: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/copy_channels:
1188018: Dec 19 16:55:24.258: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1188019: Dec 19 16:55:24.258: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
1188020: Dec 19 16:55:24.258: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
1188021: Dec 19 16:55:24.258: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1188022: Dec 19 16:55:24.258: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
1188023: Dec 19 16:55:24.258: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1188024: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1188025: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1188026: Dec 19 16:55:24.258: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1188027: Dec 19 16:55:24.258: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
1188028: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x1079
1188029: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x1079
1188030: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec:  Mid-call OFFER is pending
1188031: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1188032: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1188033: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1188034: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1188035: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1188036: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1188037: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1188038: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1188039: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1188040: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1188041: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1188042: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1188043: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x1, caps.stream_list.xmitFunc=
1188044: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1188045: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1188046: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1188047: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400007
1188048: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1188049: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1188050: Dec 19 16:55:24.262: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1188051: Dec 19 16:55:24.262: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1188052: Dec 19 16:55:24.262: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice-only
          Media line             : 1
          State                  : STREAM_ACTIVE (5)
          Stream address type    : 1
          Callid                 : 2509932
          Negotiated Codec       : g711ulaw, bytes :160
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : inband-voice
          Negotiated NTE payload : 0 (tx), 0 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:18742
          Media Dest Addr/Port   : [0.0.0.0]:4000
1188053: Dec 19 16:55:24.262: //2509932/28013998B3FF/SIP/Info/is_call_held: Remote media IP addr: 0.0.0.0
1188054: Dec 19 16:55:24.262: //2509932/28013998B3FF/SIP/Media/ccsip_api_request_offer: Call has been put on hold
1188055: Dec 19 16:55:24.262: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1188056: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
1188057: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=18742
1188058: Dec 19 16:55:24.266: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1188059: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 18742
1188060: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1188061: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
1188062: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIAddSDPPayloadAttributes:
max_event 15
1188063: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Add Media payload attributes for
                                    preferred codec's
1188064: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: Deffering QoS reservation for MID-CALL Invite
1188065: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
1188066: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
1188067: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1188068: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7A9100
1188069: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1188070: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1188071: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1188072: Dec 19 16:55:24.266: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1188073: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
1188074: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7A9100 to Invite Response 100
1188075: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F476FC, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1188076: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1188077: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1188078: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48F476FC to default port=5060
1188079: Dec 19 16:55:24.270: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1188080: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48F476FC
1188081: Dec 19 16:55:24.270: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F476FC, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1188082: Dec 19 16:55:24.270: //2509932/28013998B3FF/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.96.3.1:5060
1188083: Dec 19 16:55:24.270: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1188084: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 0.0.0.0:4000, codec 5
1188085: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_ACTIVE
1188086: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1188087: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1188088: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1188089: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1188090: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1188091: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1188092: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1188093: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1188094: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1188095: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1188096: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1188097: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1188098: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1188099: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1188100: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1188101: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509931, channels 0x4FA7EC2C caps 0x4F381F14
1188102: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509931, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1188103: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPIDtmfTranscoder: Return upon SCCP version 0
1188104: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1188105: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder:  Entry..
1188106: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: AudioLevelAdjustment do not need xcoder
1188107: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1188108: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPICodecTranscoder: No body else needs xcoder. OFFER_ALL is intact
1188109: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckVoiceClassCodecConfiguration: Either one of the call leg supports Voice Class Codec..
1188110: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Check between Equalset & Subset..
1188111: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/codec_found:
1188112: Dec 19 16:55:24.274: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1188113: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found.. continue for next codec..
1188114: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: This is Subset
1188115: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPICodecTranscoder: Static codec or Equalset or Subset w/o offer-all. For DO call, offer-all is NO-OP..
1188116: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/codec_found:
1188117: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1188118: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1188119: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPICheckAndReserveTranscoder: Xcoder is not needed
1188120: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1188121: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1188122: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Call hold using connection mute
1188123: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPIHoldMediaStream: Muting Stream 1
1188124: Dec 19 16:55:24.278: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188125: Dec 19 16:55:24.278: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188126: Dec 19 16:55:24.278: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188127: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188128: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188129: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188130: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F61EB8
1188131: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: Build a line num_elements=1
1188132: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1188133: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1188134: Dec 19 16:55:24.278: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1188135: Dec 19 16:55:24.278: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: NTE max_event 15
1188136: Dec 19 16:55:24.278: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1188137: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1188138: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1188139: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17172, raddr = 208.29.69.22, rport=64744, do_rtcp=TRUE
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = INACTIVE
        media_ip_addr = 208.29.69.22, vrf tableid = 0 media_addr_type = 1
1188140: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1188141: Dec 19 16:55:24.282: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188142: Dec 19 16:55:24.282: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188143: Dec 19 16:55:24.282: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188144: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188145: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188146: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188147: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F61EB8
1188148: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1188149: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931: flags=146817052, flags2=268435712
1188150: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: CALL_HELD=0 Send Mid-call invite based on peer info
1188151: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=17172
1188152: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Error/sipSPIUpdateSrcSdpFixedPart:  owner_sessionid is already their OR src_sdp
                        is corrupted
1188153: Dec 19 16:55:24.282: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1188154: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1188155: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
1188156: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Media/sipSPIAddSDPMediaPayload: DTMF relay will be added in the caller. Skipping it
1188157: Dec 19 16:55:24.282: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1188158: Dec 19 16:55:24.282: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Add Media payload attributes for
                                    preferred codec's
1188159: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1188160: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1188161: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: Update QoS again before sending reInvite
1188162: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1188163: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 5 a-line(s) found for stream 1
1188164: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: No video stream when sending out reInvite.
1188165: Dec 19 16:55:24.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 244, curr send SDP size =
                      256
1188166: Dec 19 16:55:24.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
                          is not same.. so no comparision is done..
1188167: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 1297,
                         new version id = 1298
1188168: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)
1188169: Dec 19 16:55:24.286: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1188170: Dec 19 16:55:24.286: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: Transaction active. Facilities will be queued.
1188171: Dec 19 16:55:24.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1188172: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1188173: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4F7A9A48
1188174: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1188175: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2841
1188176: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1188177: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1188178: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1188179: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1188180: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
1188181: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1188182: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1188183: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
SIP: (2509931) Group (a= group line) attribute, level 65535 instance 1 not found.
1188184: Dec 19 16:55:24.290: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1188185: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: not adding diversion headers for UAS re-INVITE
1188186: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: Associated container=0x4F7A9A48 to Invite
1188187: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
1188188: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1188189: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F352DC, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD58D8
1188190: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1188191: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1188192: Dec 19 16:55:24.294: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1188193: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F352DC
1188194: Dec 19 16:55:24.294: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F352DC, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1188195: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Info/sentInviteRequest: Sent Invite in state STATE_SEND_MIDCALL_INVITE_PENDING
1188196: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
1188197: Dec 19 16:55:24.294: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Setting re_invite_init_flag
1188198: Dec 19 16:55:24.298: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
CSeq: 106 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
1188199: Dec 19 16:55:24.298: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F31A19
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0671168920-1745162723-3019877092-2825493512
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 106 INVITE
Max-Forwards: 70
Timestamp: 1387472124
Contact: <2587143682300>
Expires: 180
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 256
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1298 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 17172 RTP/AVP 0 101
a=inactive
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
1188200: Dec 19 16:55:24.810: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1188201: Dec 19 16:55:24.810: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1188202: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1188203: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: not adding diversion headers for UAS re-INVITE
1188204: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: Associated container=0x4F7A9A48 to Invite
1188205: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
1188206: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1188207: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F476FC, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1188208: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1188209: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1188210: Dec 19 16:55:24.814: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1188211: Dec 19 16:55:24.814: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F476FC
1188212: Dec 19 16:55:24.814: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F476FC, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1188213: Dec 19 16:55:24.818: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1188214: Dec 19 16:55:24.818: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1188215: Dec 19 16:55:24.818: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1188216: Dec 19 16:55:24.818: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1188217: Dec 19 16:55:24.818: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 INVITE
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Supported:
Accept: application/media_control+xml,application/sdp,multipart/mixed
Contact: <4254624012>
Content-Length: 210
v=0
o=BroadWorks 86091758 6 IN IP4 208.29.69.22
s=-
c=IN IP4 0.0.0.0
t=0 0
m=audio 64744 RTP/AVP 0 101
a=fmtp:101 0-15
a=inactive
a=maxptime:20
1188218: Dec 19 16:55:24.818: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1188219: Dec 19 16:55:24.818: //2509931/28013998B3FF/SIP/Info/ccsip_api_response_answer: ccsip_api_response_answer.
1188220: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1188221: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:4F7A8188
1188222: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1188223: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_RESP
1188224: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1188225: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:140
1188226: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1188227: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1188228: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1188229: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1188230: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1188231: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Error/ccsip_api_response_answer: Unable to add
                                           passthru headers to container
1188232: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1188233: Dec 19 16:55:24.822: //2509931/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 64744
1188234: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1188235: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1188236: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1188237: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1188238: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1188239: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1188240: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
1188241: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1188242: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1188243: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1188244: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1188245: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1188246: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1188247: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1188248: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1188249: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1188250: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1188251: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1188252: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1188253: Dec 19 16:55:24.826: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1188254: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1188255: Dec 19 16:55:24.826: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1188256: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1188257: Dec 19 16:55:24.830: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1188258: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1188259: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1188260: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        stream_type=voice+dtmf (1), dest_ip_address=0.0.0.0, dest_port=64744
1188261: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1188262: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=64744 new=64744
1188263: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        Present Local Media Direction = INACTIVE
        retVal = 0
1188264: Dec 19 16:55:24.830: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188265: Dec 19 16:55:24.830: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188266: Dec 19 16:55:24.830: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188267: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188268: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188269: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188270: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F61EB8
1188271: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold activated for stream 1
1188272: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1188273: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
1188274: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Media/sipSPIRSVPCompareSDP: Media Offer Changed
1188275: Dec 19 16:55:24.830: //2509931/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1188276: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1188277: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1188278: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : Yes
1188279: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1188280: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1188281: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 peer 2509932 flags 0x404087 state STATE_SENT_MIDCALL_INVITE
1188282: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1188283: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1188284: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1188285: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1188286: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509931, Peer CallID 2509932, sdp 0x48E3BA8C channels 0x4F44B1FC
1188287: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/copy_channels:
callId 2509931 size 240 ptr 0x4FA9FAA0)
1188288: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1188289: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1188290: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509931
1188291: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1188292: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1188293: Dec 19 16:55:24.834: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509931
1188294: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1188295: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509931 context 0x4FD9F6E0
1188296: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1188297: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1188298: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1188299: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/codec_found:
1188300: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1188301: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1188302: Dec 19 16:55:24.838: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1188303: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1188304: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 0.0.0.0:64744
1188305: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1188306: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509931, dtmf = 6
1188307: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1188308: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1188309: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1188310: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 flags 0x10000100 state STATE_SENT_MIDCALL_INVITE
1188311: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x8C0401C, ccb->pld.flags_ipip 0x404087
1188312: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Repoort 200OK to reINVITE
1188313: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Reset IS_FAX_TO_VOICE_SWITCH
1188314: Dec 19 16:55:24.838: //2509931/28013998B3FF/SIP/Info/copy_channels:
1188315: Dec 19 16:55:24.838: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 166)
1188316: Dec 19 16:55:24.838: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509931 chans 0x4FA9FAA0 event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA9FAA0
1188317: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_ACK: peer ID 2509931 chans 0x4FA9FAA0 event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA9FAA0
1188318: Dec 19 16:55:24.842: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1188319: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type =
                                         SIPSPI_EV_CC_NEW_MEDIA for CC_EV_H245_OPEN_CHANNEL_ACK!: peer ID 2509931 chans 0x4FA9FAA0 event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA9FAA0
1188320: Dec 19 16:55:24.842: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1188321: Dec 19 16:55:24.842: //2509931/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1188322: Dec 19 16:55:24.842: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1188323: Dec 19 16:55:24.842: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1188324: Dec 19 16:55:24.842: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509932, srcCallID=2509931,
                         peer_ccb->call_info.currentLocalName=OPERATOR,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=4254624012 4254624012,
1188325: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1188326: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1188327: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1188328: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1188329: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1188330: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
1188331: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1188332: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1188333: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1188334: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1188335: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1188336: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1188337: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1188338: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
line 1 codec g711ulaw
1188339: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1188340: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1188341: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1188342: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1188343: Dec 19 16:55:24.842: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400005
1188344: Dec 19 16:55:24.846: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1188345: Dec 19 16:55:24.846: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1188346: Dec 19 16:55:24.846: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1188347: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1188348: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_CHANGING (4)
          Callid                 : 2509931
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Media Srce Addr/Port   : [10.97.1.150]:17172
          Media Dest Addr/Port   : [0.0.0.0]:64744
1188349: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1188350: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
1188351: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:4F92EEE4
1188352: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509931) to the VOIP RTP library
1188353: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1188354: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1188355: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1188356: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        media_ip_addr = 0.0.0.0, vrf tableid = 0 media_addr_type = 1
1188357: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1188358: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Info/sipSPICreateRtpSession: sess: 4F952BB0 do_rtcp:1
1188359: Dec 19 16:55:24.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188360: Dec 19 16:55:24.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188361: Dec 19 16:55:24.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188362: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1188363: Dec 19 16:55:24.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188364: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188365: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPICreateRtpSession: stun is disabled
1188366: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        Present Local Media Direction = SENDRECV
        retVal = 1
1188367: Dec 19 16:55:24.850: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1188368: Dec 19 16:55:24.850: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188369: Dec 19 16:55:24.850: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188370: Dec 19 16:55:24.850: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188371: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1188372: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188373: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188374: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1188375: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509931)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
1188376: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1188377: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
1188378: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1188379: Dec 19 16:55:24.850: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188380: Dec 19 16:55:24.850: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188381: Dec 19 16:55:24.850: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188382: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1188383: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188384: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188385: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1188386: Dec 19 16:55:24.850: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 1
1188387: Dec 19 16:55:24.850: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1188388: Dec 19 16:55:24.854: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188389: Dec 19 16:55:24.854: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188390: Dec 19 16:55:24.854: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188391: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1188392: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188393: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188394: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1188395: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
1188396: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/ccsip_get_channel_info_count:  : 1
1188397: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x1079
1188398: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x26F7
1188399: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: g711ulaw, Bytes=160
1188400: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1188401: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1188402: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1188403: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1188404: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1188405: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1188406: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1188407: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1188408: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1188409: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1188410: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1188411: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1188412: Dec 19 16:55:24.854: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1188413: Dec 19 16:55:24.854: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
1188414: Dec 19 16:55:24.854: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1188415: Dec 19 16:55:24.854: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1188416: Dec 19 16:55:24.854: //2509932/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1188417: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1188418: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1188419: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
1188420: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1188421: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1188422: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1188423: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1188424: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1188425: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1188426: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1188427: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
1188428: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1188429: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1188430: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1188431: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1188432: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400005
1188433: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1188434: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1188435: Dec 19 16:55:24.858: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1188436: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1188437: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/ccsip_api_response_answer: Modified QoS params INVITE
1188438: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/sact_sent_mid_invite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
1188439: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
1188440: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1188441: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1188442: Dec 19 16:55:24.858: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1188443: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7ADCF8 to Ack
1188444: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1188445: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1188446: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4F91A16C, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD7968
1188447: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1188448: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1188449: Dec 19 16:55:24.862: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1188450: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4F91A16C
1188451: Dec 19 16:55:24.862: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4F91A16C, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1188452: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1188453: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1188454: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
1188455: Dec 19 16:55:24.862: //2509931/28013998B3FF/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4F449C60
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 4254624012
Called Number            : 2587143682300
Source IP Address (Sig  ): 10.97.1.150
Destn SIP Req Addr:Port  : 208.29.69.6:5060
Destn SIP Resp Addr:Port : 208.29.69.6:5060
Destination Name         : 208.29.69.6
1188963: Dec 19 16:55:25.926: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1188964: Dec 19 16:55:25.926: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1188965: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1188966: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1188967: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1188968: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1188969: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1188970: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1188971: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
1188972: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/State/sipSPIChangeState: 0x4F496950 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1188973: Dec 19 16:55:25.926: //2509930/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1188974: Dec 19 16:55:25.926: //2509930/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188975: Dec 19 16:55:25.926: //2509930/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188976: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188977: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188978: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188979: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4904A5D0
1188980: Dec 19 16:55:25.926: //2509929/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1188981: Dec 19 16:55:25.930: //2509929/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188982: Dec 19 16:55:25.930: //2509929/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188983: Dec 19 16:55:25.930: //2509930/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1188984: Dec 19 16:55:25.930: //2509930/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1188985: Dec 19 16:55:25.930: //2509930/22FDA3CEB3F8/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1188986: Dec 19 16:55:25.930: //2509930/22FDA3CEB3F8/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB1F60
1188987: Dec 19 16:55:25.934: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1188988: Dec 19 16:55:25.934: //2509929/22FDA3CEB3F8/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1188989: Dec 19 16:55:25.934: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1188990: Dec 19 16:55:25.934: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1188991: Dec 19 16:55:25.934: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1188992: Dec 19 16:55:25.934: //2509930/22FDA3CEB3F8/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1188993: Dec 19 16:55:25.934: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1188994: Dec 19 16:55:25.934: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1188995: Dec 19 16:55:25.934: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1188996: Dec 19 16:55:25.934: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1188997: Dec 19 16:55:25.938: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1188998: Dec 19 16:55:25.938: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1188999: Dec 19 16:55:25.938: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F522FA
CSeq: 107 UPDATE
Supported:
Content-Length: 0
1189000: Dec 19 16:55:25.938: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
1189001: Dec 19 16:55:25.938: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1189002: Dec 19 16:55:25.938: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1189003: Dec 19 16:55:25.938: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1189004: Dec 19 16:55:25.938: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1189005: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Info/sipSPISendByeResponse: Associated container=0x4F7A3900 to Bye Response
1189006: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
1189007: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: msg=0x48F476FC, addr=208.29.69.38, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD734C
1189008: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1189009: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1189010: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48F476FC to default port=5060
1189011: Dec 19 16:55:25.942: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.38, rport:5060 with laddr:10.97.1.150
1189012: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48F476FC
1189013: Dec 19 16:55:25.942: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F476FC, addr=208.29.69.38, port=5060, local_addr=10.97.1.150, connId=4 for UDP
1189014: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
1189015: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:-1984002269 ConnTime -1984002971
1189016: Dec 19 16:55:25.942: //2509929/22FDA3CEB3F8/SIP/Media/sipSPIDestroyRtpSession: stream:4904A5D0
1189017: Dec 19 16:55:25.946: //2509929/22FDA3CEB3F8/SIP/State/sipSPIChangeState: 0x4F496950 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1189018: Dec 19 16:55:25.946: //2509929/22FDA3CEB3F8/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4F496950
State of The Call        : STATE_DEAD
Calling Number           : 5202492879
Called Number            : 2587143682911
Destn SIP Req Addr:Port  : 208.29.69.38:5060
Destn SIP Resp Addr:Port : 208.29.69.38:5060
Destination Name         : 208.29.69.38
1189019: Dec 19 16:55:25.946: //2509929/22FDA3CEB3F8/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.97.1.150
Source IP Port    (Media): 17052
Destn  IP Address (Media): 208.29.69.54
Destn  IP Port    (Media): 53408
Orig Destn IP Address:Port (Media): [ - ]:0
1189020: Dec 19 16:55:25.946: //2509929/22FDA3CEB3F8/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
1189021: Dec 19 16:55:25.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C69
1189022: Dec 19 16:55:25.946: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1189023: Dec 19 16:55:25.946: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1189024: Dec 19 16:55:25.946: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1189025: Dec 19 16:55:25.946: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1189026: Dec 19 16:55:25.946: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1189027: Dec 19 16:55:25.946: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1189028: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Info/sipSPISendBye: Associated container=0x4F7A8A78 to Bye
1189029: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
1189030: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1189031: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA5D854, addr=10.96.3.1, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD6EEC
1189032: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1189033: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1189034: Dec 19 16:55:25.950: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1189035: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FA5D854
1189036: Dec 19 16:55:25.950: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA5D854, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1189037: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
1189038: Dec 19 16:55:25.950: //2509930/22FDA3CEB3F8/SIP/State/sipSPIChangeState: 0x4F42E578 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1189039: Dec 19 16:55:25.954: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 208.29.69.38:5060;branch=z9hG4bK60svbu005040u8qat5v0cd50p31e2.1
From: "PRINTRONIX"<5202492879>;tag=SD0dsrd01-1465180822-1387472102195-
To: "7143682911 7143682911"<2587143682911>;tag=6170EB04-F37
Date: Thu, 19 Dec 2013 16:55:25 GMT
Call-ID: SD0dsrd01-c64e5874f3025ec1c90ef3402f710bc6-v300g00
CSeq: 98832796 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=352,OS=56320,PR=342,OR=54720,PL=0,JI=0,LA=0,DU=7
Content-Length: 0
1189040: Dec 19 16:55:25.954: //2509930/22FDA3CEB3F8/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:202911@10.96.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F71E19
To: <202911>;tag=496441~918169ec-01b0-412c-a6fb-1b14e25860d5-31543761
Date: Thu, 19 Dec 2013 16:55:18 GMT
Call-ID: 2301E97F-680511E3-B3FEAAE4-A8699C08@10.97.1.150
Max-Forwards: 70
P-Asserted-Identity: "PRINTRONIX" <5202492879>
Timestamp: 1387472125
CSeq: 102 BYE
P-RTP-Stat: PS=342,OS=54720,PR=354,OR=56640,PL=0,JI=0,LA=0,DU=7
Content-Length: 0
1189041: Dec 19 16:55:25.958: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1189042: Dec 19 16:55:25.958: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1189043: Dec 19 16:55:25.962: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1189044: Dec 19 16:55:25.962: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1189045: Dec 19 16:55:25.962: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK1679F71E19 from via branch list
1189046: Dec 19 16:55:25.962: //2509930/22FDA3CEB3F8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
1189047: Dec 19 16:55:25.962: //2509930/22FDA3CEB3F8/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
1189048: Dec 19 16:55:25.962: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:-1984002267 ConnTime -1984002975
1189049: Dec 19 16:55:25.962: //2509930/22FDA3CEB3F8/SIP/Media/sipSPIDestroyRtpSession: stream:4FAB1F60
1189050: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/State/sipSPIChangeState: 0x4F42E578 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1189051: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4F42E578
Called Number            : 202911
Destn SIP Req Addr:Port  : 10.96.3.1:5060
Destn SIP Resp Addr:Port : 10.96.3.1:5060
Destination Name         : 10.96.3.1
1189052: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 18946
Destn  IP Address (Media): 10.96.3.2
Destn  IP Port    (Media): 20814
1189053: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Call/sipSPICallInfo:
1189054: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C6A
1189055: Dec 19 16:55:25.966: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850246] removed.
1189056: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
1189057: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F42E578 key=2301E97F-680511E3-B3FEAAE4-A8699C08@10.97.1.150
1189058: Dec 19 16:55:25.966: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1189059: Dec 19 16:55:25.970: //2509930/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1189060: Dec 19 16:55:25.970: //2509930/22FDA3CEB3F8/SIP/Info/ccsip_offer_ans_delete:
1189061: Dec 19 16:55:25.970: //2509930/22FDA3CEB3F8/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F42E578
1189062: Dec 19 16:55:25.970: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1850246]
1189063: Dec 19 16:55:25.974: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1189064: Dec 19 16:55:25.978: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1189065: Dec 19 16:55:25.978: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1189066: Dec 19 16:55:25.978: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1189067: Dec 19 16:55:25.978: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1189068: Dec 19 16:55:25.978: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F6E4
CSeq: 108 INVITE
Supported:
Content-Length: 286
v=0
o=BroadWorks 86091758 7 IN IP4 208.29.69.22
s=-
c=IN IP4 208.29.69.22
t=0 0
m=audio 64744 RTP/AVP 0 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1189069: Dec 19 16:55:25.978: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1189070: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/ccsip_api_response_answer: ccsip_api_response_answer.
1189071: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1189072: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:4F7AC750
1189073: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1189074: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_RESP
1189075: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1189076: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:140
1189077: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        Configured SE:1800, Configured Min-SE:1800
1189078: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1189079: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1189080: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1189081: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1189082: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Error/ccsip_api_response_answer: Unable to add
1189083: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1189084: Dec 19 16:55:25.982: //2509931/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 64744
SIP: Attribute mid, level 1 instance 1 not found.
1189085: Dec 19 16:55:25.986: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1189086: Dec 19 16:55:25.986: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1189087: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1189088: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1189089: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1189090: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1189091: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
1189092: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1189093: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1189094: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1189095: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1189096: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1189097: Dec 19 16:55:25.986: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1189098: Dec 19 16:55:25.986: //2509931/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1189099: Dec 19 16:55:25.986: //2509931/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1189100: Dec 19 16:55:25.986: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1189101: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1189102: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1189103: Dec 19 16:55:25.986: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1189104: Dec 19 16:55:25.990: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1189105: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1189106: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1189107: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1189108: Dec 19 16:55:25.990: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1189109: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1189110: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1189111: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=208.29.69.22, dest_port=64744
1189112: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1189113: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=64744 new=64744
1189114: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDRECV
        New Local Media Direction = SENDRECV
        retVal = 1
1189115: Dec 19 16:55:25.990: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1189116: Dec 19 16:55:25.990: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1189117: Dec 19 16:55:25.990: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1189118: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1189119: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1189120: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1189121: Dec 19 16:55:25.990: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1189122: Dec 19 16:55:25.994: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1189123: Dec 19 16:55:25.994: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1189124: Dec 19 16:55:25.994: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1189125: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1189126: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1189127: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1189128: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F92EEE4
1189129: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1189130: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold deactivated for stream 1
1189131: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1189132: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
1189133: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPIRSVPCompareSDP: Media Offer Changed
1189134: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1189135: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1189136: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1189137: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : Yes
        Bridge Done            : Yes
        New Media              : No
        DSP DNLD Reqd          : No
1189138: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1189139: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1189140: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 peer 2509932 flags 0x400087 state STATE_SENT_MIDCALL_INVITE
1189141: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1189142: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1189143: Dec 19 16:55:25.994: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1189144: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1189145: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509931, Peer CallID 2509932, sdp 0x4FA9500C channels 0x4F44B1FC
1189146: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/copy_channels:
callId 2509931 size 240 ptr 0x4FA7EC2C)
1189147: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1189148: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1189149: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509931
1189150: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1189151: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1189152: Dec 19 16:55:25.998: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509931h: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1299 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 17172 RTP/AVP 0 101
a=sendonly
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
1189872: Dec 19 16:55:26.178: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679F979
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Date: Thu, 19 Dec 2013 16:55:26 GMT
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0671168920-1745162723-3019877092-2825493512
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 109 INVITE
Max-Forwards: 70
Timestamp: 1387472126
Contact: <2587143682300>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 256
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1300 IN IP4 10.97.1.150
s=SIP Call
t=0 0
a=inactive
a=ptime:20
a=fmtp:101 0-15
1189873: Dec 19 16:55:26.614: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1189874: Dec 19 16:55:26.614: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1189875: Dec 19 16:55:26.614: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1189876: Dec 19 16:55:26.614: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1189877: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1189878: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 109 INVITE
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Supported:
Accept: application/media_control+xml,application/sdp,multipart/mixed
Contact: <4254624012>
Content-Length: 210
v=0
o=BroadWorks 86091758 8 IN IP4 208.29.69.22
s=-
c=IN IP4 0.0.0.0
t=0 0
m=audio 64744 RTP/AVP 0 101
a=fmtp:101 0-15
a=inactive
a=maxptime:20
1189879: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1189880: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Info/ccsip_api_response_answer: ccsip_api_response_answer.
1189881: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1189882: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:4F7A8188
1189883: Dec 19 16:55:26.618: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1189884: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_RESP
1189885: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1189886: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:140
1189887: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1189888: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1189889: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1189890: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1189891: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1189892: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Error/ccsip_api_response_answer: Unable to add
                                           passthru headers to container
1189893: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1189894: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 64744
1189895: Dec 19 16:55:26.622: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1189896: Dec 19 16:55:26.626: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1189897: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1189898: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1189899: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1189900: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1189901: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
1189902: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1189903: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1189904: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1189905: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1189906: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1189907: Dec 19 16:55:26.626: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1189908: Dec 19 16:55:26.626: //2509931/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1189909: Dec 19 16:55:26.626: //2509931/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1189910: Dec 19 16:55:26.626: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1189911: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1189912: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1189913: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1189914: Dec 19 16:55:26.626: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1189915: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1189916: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1189917: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1189918: Dec 19 16:55:26.630: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1189919: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1189920: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1189921: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        stream_type=voice+dtmf (1), dest_ip_address=0.0.0.0, dest_port=64744
1189922: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1189923: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=64744 new=64744
1189924: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = INACTIVE
        Present Local Media Direction = INACTIVE
        New Local Media Direction = INACTIVE
        retVal = 0
1189925: Dec 19 16:55:26.630: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1189926: Dec 19 16:55:26.630: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1189927: Dec 19 16:55:26.630: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1189928: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1189929: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1189930: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1189931: Dec 19 16:55:26.630: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB1F60
1189932: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold activated for stream 1
1189933: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1189934: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
1189935: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPIRSVPCompareSDP: Media Offer Changed
1189936: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1189937: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1189938: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1189939: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : Yes
1189940: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1189941: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1189942: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 peer 2509932 flags 0x404087 state STATE_SENT_MIDCALL_INVITE
1189943: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1189944: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1189945: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1189946: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1189947: Dec 19 16:55:26.634: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509931, Peer CallID 2509932, sdp 0x48F39E4C channels 0x4F44B1FC
1189948: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/copy_channels:
1189949: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1189950: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1189951: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509931
1189952: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1189953: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1189954: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
1189955: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1189956: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509931 context 0x4FD9F6E0
1189957: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1189958: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1189959: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1189960: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 5
1189961: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1189962: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1189963: Dec 19 16:55:26.638: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1189964: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1189965: Dec 19 16:55:26.638: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 0.0.0.0:64744
1189966: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1189967: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509931, dtmf = 6
1189968: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1189969: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1189970: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1189971: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509931 flags 0x10000100 state STATE_SENT_MIDCALL_INVITE
1189972: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x8C0401C, ccb->pld.flags_ipip 0x404087
1189973: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Repoort 200OK to reINVITE
1189974: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Reset IS_FAX_TO_VOICE_SWITCH
1189975: Dec 19 16:55:26.642: //2509931/28013998B3FF/SIP/Info/copy_channels:
1189976: Dec 19 16:55:26.642: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 166)
1189977: Dec 19 16:55:26.642: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509931 chans 0x4FA7EC2C event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA7EC2C
1189978: Dec 19 16:55:26.642: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_ACK: peer ID 2509931 chans 0x4FA7EC2C event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA7EC2C
1189979: Dec 19 16:55:26.642: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1189980: Dec 19 16:55:26.642: //2509932/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type =
                                         SIPSPI_EV_CC_NEW_MEDIA for CC_EV_H245_OPEN_CHANNEL_ACK!: peer ID 2509931 chans 0x4FA7EC2C event 166 flags 0xC04018 0x10010120 0x400005 data 0x4FA7EC2C
1189981: Dec 19 16:55:26.642: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1189982: Dec 19 16:55:26.646: //2509931/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1189983: Dec 19 16:55:26.646: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1189984: Dec 19 16:55:26.646: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1189985: Dec 19 16:55:26.646: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509932, srcCallID=2509931,
                         peer_ccb->call_info.currentLocalName=CUBAC CTI,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=4254624012 4254624012,
1189986: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1189987: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1189988: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1189989: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1189990: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1189991: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
1189992: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1189993: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1189994: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1189995: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1189996: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1189997: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1189998: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1189999: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
line 1 codec g711ulaw
1190000: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x1, caps.stream_list.xmitFunc=
1190001: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1190002: Dec 19 16:55:26.646: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1190003: Dec 19 16:55:26.650: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1190004: Dec 19 16:55:26.650: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400005
1190005: Dec 19 16:55:26.650: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1190006: Dec 19 16:55:26.650: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1190007: Dec 19 16:55:26.650: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1190008: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1190009: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_CHANGING (4)
          Stream address type    : 1
          Callid                 : 2509931
          Negotiated Codec       : g711ulaw, bytes :160
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:17172
          Media Dest Addr/Port   : [0.0.0.0]:64744
1190010: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1190011: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
1190012: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:48EF9F88
1190013: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509931) to the VOIP RTP library
1190014: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1190015: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1190016: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1190017: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17172, raddr = 208.29.69.22, rport=64744, do_rtcp=TRUE
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = INACTIVE
        media_ip_addr = 0.0.0.0, vrf tableid = 0 media_addr_type = 1
1190018: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1190019: Dec 19 16:55:26.650: //2509931/28013998B3FF/SIP/Info/sipSPICreateRtpSession: sess: 4F952BB0 do_rtcp:1
1190020: Dec 19 16:55:26.650: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190021: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190022: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190023: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190024: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190025: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190026: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Media/sipSPICreateRtpSession: stun is disabled
1190027: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        Present Local Media Direction = SENDRECV
        retVal = 1
1190028: Dec 19 16:55:26.654: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1190029: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190030: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190031: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190032: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190033: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190034: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190035: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48EF9F88
1190036: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509931)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
1190037: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1190038: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
1190039: Dec 19 16:55:26.654: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1190040: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190041: Dec 19 16:55:26.654: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190042: Dec 19 16:55:26.658: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190043: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190044: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190045: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190046: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48EF9F88
1190047: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 1
1190048: Dec 19 16:55:26.658: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1190049: Dec 19 16:55:26.658: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190050: Dec 19 16:55:26.658: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190051: Dec 19 16:55:26.658: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190052: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190053: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190054: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190055: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48EF9F88
1190056: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
1190057: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/ccsip_get_channel_info_count:  : 1
1190058: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x26F7
1190059: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x2276
1190060: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: g711ulaw, Bytes=160
1190061: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1190062: Dec 19 16:55:26.658: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1190063: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1190064: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1190065: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1190066: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1190067: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1190068: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1190069: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1190070: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1190071: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1190072: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1190073: Dec 19 16:55:26.662: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1190074: Dec 19 16:55:26.662: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
1190075: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1190076: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1190077: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1190078: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1190079: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1190080: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
1190081: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1190082: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1190083: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1190084: Dec 19 16:55:26.662: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1190085: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1190086: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1190087: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1190088: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
1190089: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1190090: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1190091: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1190092: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1190093: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400005
1190094: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1190095: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1190096: Dec 19 16:55:26.666: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1190097: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1190098: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/ccsip_api_response_answer: Modified QoS params INVITE
1190099: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/sact_sent_mid_invite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
1190100: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
1190101: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190102: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190103: Dec 19 16:55:26.666: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1190104: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7AD5C0 to Ack
1190105: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1190106: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1190107: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA5D854, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD7968
1190108: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1190109: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1190110: Dec 19 16:55:26.670: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1190111: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FA5D854
1190112: Dec 19 16:55:26.670: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA5D854, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1190113: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1190114: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1190115: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
1190116: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4F449C60
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 4254624012
Called Number            : 2587143682300
Source IP Address (Sig  ): 10.97.1.150
Destn SIP Req Addr:Port  : 208.29.69.6:5060
Destn SIP Resp Addr:Port : 208.29.69.6:5060
Destination Name         : 208.29.69.6
1190117: Dec 19 16:55:26.670: //2509931/28013998B3FF/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17172
Destn  IP Address (Media): 0.0.0.0
Destn  IP Port    (Media): 64744
1190118: Dec 19 16:55:26.674: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1190119: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509932 ft: 1, inc 0, 0.0.0.0:64744, codec 5
1190120: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509932 state STATE_MIDCALL_LOCAL_RESP_PENDING
1190121: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1190122: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1190123: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509932, channels 0x4FA7EC2C caps 0x4F3B97EC
1190124: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509932, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1190125: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
1190126: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/codec_found:
1190127: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1190128: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1190129: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
1190130: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 12
1190131: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Reset IS_FAX_TO_VOICE_SWITCH
1190132: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x400005
1190133: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
1190134: Dec 19 16:55:26.674: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1190135: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1190136: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Call hold using connection mute
1190137: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/sipSPIHoldMediaStream: Muting Stream 1
1190138: Dec 19 16:55:26.674: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190139: Dec 19 16:55:26.674: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190140: Dec 19 16:55:26.674: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190141: Dec 19 16:55:26.674: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190142: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190143: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190144: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F44A60
1190145: Dec 19 16:55:26.678: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1190146: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 18742
1190147: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1190148: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1190149: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1190150: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 0.0.0.0, lport = 18742, raddr = 10.96.3.1, rport=4000, do_rtcp=FALSE
        src_callid = 2509932, dest_callid = 2509931, stream type = voice-only, stream direction = INACTIVE
1190151: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1190152: Dec 19 16:55:26.678: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190153: Dec 19 16:55:26.678: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190154: Dec 19 16:55:26.678: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190155: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190156: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190157: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190158: Dec 19 16:55:26.678: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F44A60
1190159: Dec 19 16:55:26.682: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1190160: Dec 19 16:55:26.682: //2509932/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 3 a-line(s) found for stream 1
1190161: Dec 19 16:55:26.682: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 291, curr send SDP size =
                      192
1190162: Dec 19 16:55:26.682: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
                          is not same.. so no comparision is done..
1190163: Dec 19 16:55:26.682: //2509932/28013998B3FF/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 1213,
                         new version id = 1214
1190164: Dec 19 16:55:26.682: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1190165: Dec 19 16:55:26.682: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1190166: Dec 19 16:55:26.682: //2509932/28013998B3FF/SIP/Info/act_handle_app_media_event: method = 102 state = 16
1190167: Dec 19 16:55:26.682: //2509932/28013998B3FF/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
1190168: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 0.0.0.0, RTCP Type 4
1190169: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPISetHoldTimer: Starting hold timer at 2880 minutes
1190170: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1190171: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:4F7AA230
1190172: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_RESP
1190173: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:140
1190174: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1190175: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:841, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1190176: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1190177: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190178: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190179: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 2509932
1190180: Dec 19 16:55:26.686: //2509932/28013998B3FF/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
1190181: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 2509932
1190182: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Transaction active. Facilities will be queued.
SIP: (2509932) Group (a= group line) attribute, level 65535 instance 1 not found.
1190183: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1190184: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AA230 to Invite Response 200
1190185: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
1190186: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F3B860, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD7450
1190187: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1190188: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1190189: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48F3B860 to default port=5060
1190190: Dec 19 16:55:26.690: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1190191: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48F3B860
1190192: Dec 19 16:55:26.690: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F3B860, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1190193: Dec 19 16:55:26.690: //2509932/28013998B3FF/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
1190194: Dec 19 16:55:26.706: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679FA1175
Max-Forwards: 70
CSeq: 109 ACK
Content-Length: 0
1190195: Dec 19 16:55:26.710: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cd877de1e14
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
CSeq: 109 INVITE
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Supported: timer
Content-Length: 192
v=0
o=CiscoSystemsSIP-GW-UserAgent 8988 1214 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 18742 RTP/AVP 0
c=IN IP4 0.0.0.0
a=inactive
a=ptime:20
1190196: Dec 19 16:55:26.710: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1190197: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1190198: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1190199: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cd9a6b5dc3
Max-Forwards: 70
CSeq: 109 ACK
Allow-Events: presence
Content-Length: 0
1190200: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1190201: Dec 19 16:55:26.714: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1190202: Dec 19 16:55:26.714: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1190203: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190204: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1190205: Dec 19 16:55:26.714: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190206: Dec 19 16:55:26.714: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
1190207: Dec 19 16:55:26.714: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1190208: Dec 19 16:55:26.714: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: Transaction Complete. Lock on Facilities released..
1190209: Dec 19 16:55:26.718: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: stream->rtcp_session->type:4
1190210: Dec 19 16:55:26.718: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: check for HA checkpoint trigger case; state:7, flags:0xC04018, flags2:0x10010120, platform_flags2:0x1004600, flags_ipip:0x400005, srcCcCallID:0x264C6C, destCcCallID:0x264C6B, confID:0x6ECB7
1190211: Dec 19 16:55:26.718: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start hold completet notifivation
1190212: Dec 19 16:55:26.718: //2509932/28013998B3FF/SIP/Info/sipSPIHoldCompleteNotificationRequest: sipSPIHoldCompleteNotificationRequest: Hold Type=Unknown
1190213: Dec 19 16:55:26.718: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
1190214: Dec 19 16:55:26.718: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
1190215: Dec 19 16:55:26.734: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1190216: Dec 19 16:55:26.734: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1190217: Dec 19 16:55:26.734: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1190218: Dec 19 16:55:26.734: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cda12314cb7
User-Agent: Cisco-CUCM8.6
Max-Forwards: 70
Supported: timer,resource-priority,replaces
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 110 UPDATE
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "OPERATOR" <202300>
Remote-Party-ID: "OPERATOR" <202300>;party=calling;screen=yes;privacy=off
Content-Length: 0
1190219: Dec 19 16:55:26.734: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1190220: Dec 19 16:55:26.734: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1190221: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1190222: Dec 19 16:55:26.738: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190223: Dec 19 16:55:26.738: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1190224: Dec 19 16:55:26.738: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190225: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
1190226: Dec 19 16:55:26.738: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1190227: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1190228: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/ccsipEarlyDialogUpdateParams:  Entry..
1190229: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: prev_send_sdp_buf is not allocated
1190230: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1190231: Dec 19 16:55:26.738: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1190232: Dec 19 16:55:26.742: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1190233: Dec 19 16:55:26.742: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1190234: Dec 19 16:55:26.742: //2509932/28013998B3FF/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1190235: Dec 19 16:55:26.742: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F42E578) with key=[1850252] to table
1190236: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1190237: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1190238: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: OPERATOR, current remote number: 202300
1190239: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
1190240: Dec 19 16:55:26.742: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850252] removed.
1190241: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1190242: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1190243: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/ccsip_offer_ans_delete:
1190244: Dec 19 16:55:26.742: //-1/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F42E578
1190245: Dec 19 16:55:26.742: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1190246: Dec 19 16:55:26.742: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:109, resp_code:0, container:4F7AC750
1190247: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1190248: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1190249: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1190250: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1190251: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMidDialogSRReqWithOutSEPeerEventGen: session timer already turned off on this leg
1190252: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:841
1190253: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:841, posted event:E_STSL_LEG_BY_LEG, reason:4
        Configured SE:1800, Configured Min-SE:1800
1190254: Dec 19 16:55:26.746: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1190255: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
1190256: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
1190257: Dec 19 16:55:26.746: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1190258: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/act_handle_app_media_event: method = 109 state = 16
1190259: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
1190260: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 0.0.0.0, RTCP Type 4
1190261: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Info/sipSPISetHoldTimer: Starting hold timer at 2880 minutes
1190262: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1190263: Dec 19 16:55:26.746: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:200, container:4F7AA338
1190264: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_RESP
1190265: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_INVALID_PEER_EVENT, SE Value:0, SE Refresher:none, Min-SE Value:0, flags:140
1190266: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1190267: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
1190268: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1190269: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190270: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190271: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Info/sipSPISendUpdateResponse: Associated container=0x4F7AA338 to Update Response
1190272: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Transport/sipSPISendUpdateResponse: Sending UPDATE Response to the transport layer
1190273: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA52F78, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1190274: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1190275: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1190276: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FA52F78 to default port=5060
1190277: Dec 19 16:55:26.750: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1190278: Dec 19 16:55:26.750: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FA52F78
1190279: Dec 19 16:55:26.754: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA52F78, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1190280: Dec 19 16:55:26.754: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1190281: Dec 19 16:55:26.754: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg: ccb NULL, unable to update the callinfo ui parameters
1190282: Dec 19 16:55:26.754: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1190283: Dec 19 16:55:26.754: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 110 UPDATE
Supported: timer
Content-Length: 0
1190284: Dec 19 16:55:26.758: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1190285: Dec 19 16:55:26.758: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPreProcessCallerIDMediaEvent: Updated Connected Party Name: OPERATOR Updated Connected Party Number: 202300 Updated Connected Party Oct3a: 0xFFFFFF81
1190286: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/act_handle_app_media_event: method = 109 state = 7
1190287: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_OFFER
1190288: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
1190289: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/sact_app_media_event_send_request: Transaction active. CCAPI events will be queued.
1190290: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1190291: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:0, container:4F7A6088
1190292: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1190293: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_INVALID_PEER_EVENT, SE Value:0, SE Refresher:none, Min-SE Value:0, flags:841
1190294: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1190295: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1190296: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:1C0, posted event:E_STSL_INVALID_PEER_EVENT, reason:3
1190297: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 6 event
1190298: Dec 19 16:55:26.758: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190299: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1190300: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
SIP: (2509931) Group (a= group line) attribute, level 65535 instance 1 not found.
1190301: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1190302: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509931
1190303: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Info/sipSPISendUpdate: Associated container=0x4F7A6088 to Update
1190304: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Transport/sipSPISendUpdate: Sending UPDATE to the transport layer
1190305: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1190306: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA52F78, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD774C
1190307: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1190308: Dec 19 16:55:26.762: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1190309: Dec 19 16:55:26.762: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1190310: Dec 19 16:55:26.766: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FA52F78
1190311: Dec 19 16:55:26.766: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA52F78, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1190312: Dec 19 16:55:26.766: //2509931/28013998B3FF/SIP/Info/sentUpdate: Sent Update Request, starting UpdateTimer
1190313: Dec 19 16:55:26.766: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679FB4D
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Date: Thu, 19 Dec 2013 16:55:26 GMT
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Timestamp: 1387472126
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 110 UPDATE
Contact: <2587143682300>
Min-SE:  1800
Content-Length: 0
1190314: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1190315: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1190316: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1190317: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cdb7dc2c588
Min-SE:  1800
Cisco-Guid: 0671168920-1745162723-3019877092-2825493512
CSeq: 111 INVITE
Max-Forwards: 70
Expires: 180
Contact: <4254624012>
Content-Length: 0
1190318: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1190319: Dec 19 16:55:26.770: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1190320: Dec 19 16:55:26.770: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1190321: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190322: Dec 19 16:55:26.770: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1190323: Dec 19 16:55:26.774: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190324: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
1190325: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: Delayed Media in MidCall Invite
1190326: Dec 19 16:55:26.774: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1190327: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1190328: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1190329: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1190330: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1190331: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1190332: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1190333: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1190334: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1190335: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1190336: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1190337: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1190338: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1190339: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1190340: Dec 19 16:55:26.774: //2509932/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1190341: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1190342: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1190343: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1190344: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1190345: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1190346: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1190347: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7ADBF0
1190348: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1190349: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
1190350: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1190351: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1190352: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1190353: Dec 19 16:55:26.778: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMidDialogSRReqWithOutSEPeerEventGen: session timer already turned off on this legACK sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cdc7a51f81e
Max-Forwards: 70
CSeq: 111 ACK
Content-Type: application/sdp
Content-Length: 185
v=0
o=CiscoSystemsCCM-SIP 496442 9 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 10.96.3.1
t=0 0
m=audio 4000 RTP/AVP 0
a=X-cisco-media:umoh
a=rtpmap:0 PCMU/8000
a=ptime:20
a=sendonly
1190900: Dec 19 16:55:27.838: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1190901: Dec 19 16:55:27.838: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1190902: Dec 19 16:55:27.838: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1190903: Dec 19 16:55:27.838: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190904: Dec 19 16:55:27.838: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1190905: Dec 19 16:55:27.838: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1190906: Dec 19 16:55:27.838: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
1190907: Dec 19 16:55:27.838: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1190908: Dec 19 16:55:27.838: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: Transaction Complete. Lock on Facilities released..
SIP: Warning: Unrecognized attribute (X-cisco-media)
1190909: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Processing Unsolicited Notifyfrom ACK SDP even though Call-Info header not there in ACK
1190910: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1190911: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 4000
SIP: Attribute mid, level 1 instance 1 not found.
1190912: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1190913: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1190914: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1190915: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
1190916: Dec 19 16:55:27.842: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
1190917: Dec 19 16:55:27.842: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1190918: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
1190919: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1190920: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1190921: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY option(s) not found in Preferred DTMF-RELAY option list!
1190922: Dec 19 16:55:27.842: //2509932/28013998B3FF/SIP/Info/sipSPIStreamTypeAndDtmfRelay: DTMF Relay mode: Inband Voice
1190923: Dec 19 16:55:27.846: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1190924: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1190925: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1190926: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=inband-voice
        stream_type=voice-only (0), dest_ip_address=10.96.3.1, dest_port=4000
1190927: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1190928: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=4000 new=4000
1190929: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDONLY
        New Local Media Direction = RECVONLY
        retVal = 1
1190930: Dec 19 16:55:27.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190931: Dec 19 16:55:27.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190932: Dec 19 16:55:27.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190933: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190934: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190935: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190936: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F44A60
1190937: Dec 19 16:55:27.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1190938: Dec 19 16:55:27.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190939: Dec 19 16:55:27.846: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190940: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1190941: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1190942: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1190943: Dec 19 16:55:27.846: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F44A60
1190944: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1190945: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Media/sipSPICompareConnectionAddress: Call hold deactivated for stream 1
1190946: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
1190947: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=Yes IPIP_MEDIA=No
1190948: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1190949: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1190950: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1190951: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : Yes
        Bridge Done            : Yes
        New Media              : No
        DSP DNLD Reqd          : Yes
1190952: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1190953: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1190954: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 peer 2509931 flags 0x400005 state STATE_ACTIVE
1190955: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1190956: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1190957: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1190958: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1190959: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509932, Peer CallID 2509931, sdp 0x4FA9500C channels 0x4F43AAA4
1190960: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 468 ptr 0x4FB77510)
1190961: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1190962: Dec 19 16:55:27.850: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1190963: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1190964: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1190965: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1190966: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509932
1190967: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1190968: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509932 context 0x4FA5D5A0
1190969: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1190970: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1190971: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1190972: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/codec_found:
Codec to be matched: 5
1190973: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1190974: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1190975: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1190976: Dec 19 16:55:27.854: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1190977: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1190978: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 10.96.3.1:4000
1190979: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1190980: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1190981: Dec 19 16:55:27.854: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1190982: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 flags 0x10010120 state STATE_ACTIVE
1190983: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC06018, ccb->pld.flags_ipip 0x400005
1190984: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report reINVITE  delayed media & mid_call_invite
1190985: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 240 ptr 0x4F91F144)
1190986: Dec 19 16:55:27.858: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1190987: Dec 19 16:55:27.858: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509932 chans 0x4F91F144 event 165 flags 0x8C0601C 0x10400120 0x400087 data 0x4F91F144
1190988: Dec 19 16:55:27.858: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509932  chans 0x4F91F144 event 165 flags 0x8C0601C 0x10400120 0x400087 data 0x4F91F144
1190989: Dec 19 16:55:27.858: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1190990: Dec 19 16:55:27.858: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509932 chans 0x4F91F144 event 165 flags 0x8C0601C 0x10400120 0x400087 data 0x4F91F144 Media Trigger 0
1190991: Dec 19 16:55:27.858: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1190992: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1190993: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1190994: Dec 19 16:55:27.858: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1190995: Dec 19 16:55:27.858: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509931, srcCallID=2509932,
                         peer_ccb->call_info.currentLocalName=4254624012 4254624012,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=OPERATOR,
1190996: Dec 19 16:55:27.858: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x2276
1190997: Dec 19 16:55:27.858: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x2276
1190998: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1190999: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1191000: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1191001: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1191002: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1191003: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1191004: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1191005: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1191006: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1191007: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1191008: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1191009: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1191010: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
1191011: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1191012: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1191013: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1191014: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1191015: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400087
1191016: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1191017: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1191018: Dec 19 16:55:27.862: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1191019: Dec 19 16:55:27.862: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1191020: Dec 19 16:55:27.862: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice-only
          Media line             : 1
          State                  : STREAM_ACTIVE (5)
          Stream address type    : 1
          Callid                 : 2509932
          Negotiated Codec       : g711ulaw, bytes :160
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : inband-voice
          Negotiated NTE payload : 0 (tx), 0 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:18742
          Media Dest Addr/Port   : [10.96.3.1]:4000
1191021: Dec 19 16:55:27.862: //2509932/28013998B3FF/SIP/Info/is_call_held: Remote media IP addr: 10.96.3.1
1191022: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/is_call_held: Media IP Addr 10.96.3.1, RTCP Type 2
1191023: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1191024: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
1191025: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/ccsip_get_channel_info_count:  : 1
1191026: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1191027: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509932, current_seq_num=0x1BE8
1191028: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: g711ulaw, Bytes=160
1191029: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1191030: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice-only) from media
1191031: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x1, caps.stream_list.xmitFunc=
1191032: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1191033: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FA5D5A0 (gccb)
1191034: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
1191035: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1191036: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509931
1191037: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1191038: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1191039: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1191040: Dec 19 16:55:27.866: //2509932/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1191041: Dec 19 16:55:27.866: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
1191042: Dec 19 16:55:27.866: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x2276
1191043: Dec 19 16:55:27.866: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x2276
1191044: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1191045: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1191046: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1191047: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1191048: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1191049: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1191050: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1191051: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1191052: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1191053: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1191054: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1191055: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1191056: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1191057: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1191058: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1191059: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1191060: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1191061: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400087
1191062: Dec 19 16:55:27.870: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1191063: Dec 19 16:55:27.874: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1191064: Dec 19 16:55:27.874: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1191065: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1191066: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Error/sipSPIProcessAckMedia: Could not modify QoS params for midcall INVITE
1191067: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPIQoSRevertBW: Entry
1191068: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1191069: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1191070: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1191071: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1191072: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1191073: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_answer: Could not add hdrs for ev:1
1191074: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/ccsip_api_request_answer: ACK handling retval: SIP_SUCCESS
1191075: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_request_answer returned: SIP_SUCCESS
1191076: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: stream->rtcp_session->type:2
1191077: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: check for HA checkpoint trigger case; state:7, flags:0xC04018, flags2:0x10010120, platform_flags2:0x4600, flags_ipip:0x400005, srcCcCallID:0x264C6C, destCcCallID:0x264C6B, confID:0x6ECB7
1191078: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start hold completet notifivation
1191079: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPIHoldCompleteNotificationRequest: sipSPIHoldCompleteNotificationRequest: Hold Type=Unknown
1191080: Dec 19 16:55:27.874: //2509932/28013998B3FF/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
1191081: Dec 19 16:55:27.874: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1191082: Dec 19 16:55:27.874: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
1191083: Dec 19 16:55:27.874: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1191084: Dec 19 16:55:27.874: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 10.96.3.1:4000, codec 5
1191085: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_SENT_MIDCALL_INVITE
1191086: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1191087: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1191088: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509931, channels 0x4F91F144 caps 0x4F2C9BDC
1191089: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509931, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1191090: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
1191091: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 16
1191092: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/codec_found:
1191093: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1191094: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1191095: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
1191096: Dec 19 16:55:27.878: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 12
1191851: Dec 19 16:55:31.210: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
1191852: Dec 19 16:55:31.210: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1191853: Dec 19 16:55:31.210: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1191854: Dec 19 16:55:31.210: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1191855: Dec 19 16:55:31.210: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1191856: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: not adding diversion headers for UAS re-INVITE
1191857: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: Associated container=0x4F7AA230 to Invite
1191858: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
1191859: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1191860: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F35088, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD58D8
1191861: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1191862: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1191863: Dec 19 16:55:31.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1191864: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F35088
1191865: Dec 19 16:55:31.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F35088, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1191866: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Info/sentInviteRequest: Sent Invite in state STATE_SEND_MIDCALL_INVITE_PENDING
1191867: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
1191868: Dec 19 16:55:31.214: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Setting re_invite_init_flag
1191869: Dec 19 16:55:31.234: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cdd37d2b4f3
Date: Thu, 19 Dec 2013 16:55:31 GMT
CSeq: 112 INVITE
Allow-Events: telephone-event
Content-Length: 0
1191870: Dec 19 16:55:31.234: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679FF16F9
Min-SE:  1800
CSeq: 112 INVITE
Max-Forwards: 70
Timestamp: 1387472131
Expires: 180
Content-Disposition: session;handling=required
Content-Length: 256
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1302 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 17172 RTP/AVP 0 101
a=inactive
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
1191871: Dec 19 16:55:31.234: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1191872: Dec 19 16:55:31.238: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1191873: Dec 19 16:55:31.238: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1191874: Dec 19 16:55:31.238: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1191875: Dec 19 16:55:31.238: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1191876: Dec 19 16:55:31.238: //2509944/5C225C000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK1679FE22D4
From: "Julie Urban" <>7143682300@printronix.sip.com>;tag=617154D8-C3B
To: <9492552601>;tag=SDq0to999-1731103686-1387472130854
Call-ID: 332AEF3F-680511E3-B40DAAE4-A8699C08@10.97.1.150
CSeq: 101 INVITE
Timestamp: 1387472129
Supported:
Contact: <9492552601>
RSeq: 98847123
Require: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Content-Length: 215
v=0
o=BroadWorks 86092293 1 IN IP4 208.29.69.22
s=-
c=IN IP4 208.29.69.22
t=0 0
m=audio 64466 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1191877: Dec 19 16:55:31.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1191878: Dec 19 16:55:31.242: //2509944/5C225C000001/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1191879: Dec 19 16:55:31.242: //2509944/5C225C000001/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 64466
1191880: Dec 19 16:55:31.242: //2509944/5C225C000001/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1191881: Dec 19 16:55:31.242: //2509944/5C225C000001/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1191882: Dec 19 16:55:31.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
1191883: Dec 19 16:55:31.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1191884: Dec 19 16:55:31.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1191885: Dec 19 16:55:31.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1191886: Dec 19 16:55:31.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1191887: Dec 19 16:55:31.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1191888: Dec 19 16:55:31.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1191889: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1191890: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1191891: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1191892: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1191893: Dec 19 16:55:31.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1191894: Dec 19 16:55:31.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1191895: Dec 19 16:55:31.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1191896: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1191897: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1191898: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1191899: Dec 19 16:55:31.246: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1191900: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1191901: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1191902: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=208.29.69.22, dest_port=64466
1191903: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1191904: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1191905: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
1191906: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1191907: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1191908: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509944 peer 2509943 flags 0x400005 state STATE_RECD_PROCEEDING
1191909: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1191910: Dec 19 16:55:31.246: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1191911: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1191912: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1191913: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509944, Peer CallID 2509943, sdp 0x48F354A8 channels 0x4F481FCC
1191914: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/copy_channels:
callId 2509944 size 468 ptr 0x48ED2540)
1191915: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1191916: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1191917: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509944
1191918: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1191919: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1191920: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1191921: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/codec_found:
1191922: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1191923: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1191924: Dec 19 16:55:31.250: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1191925: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1191926: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 208.29.69.22:64466
1191927: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1191928: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509944, dtmf = 6
1191929: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1191930: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1191931: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1191932: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509944 flags 0x10000100 state STATE_RECD_PROCEEDING
1191933: Dec 19 16:55:31.250: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: Reporting media in Substate SUBSTATE_PROCEEDING_PROCEEDING
1191934: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
1191935: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x440018, ccb->pld.flags_ipip 0x400005
1191936: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating the negotiated codec bytes
1191937: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: Post CAPS to peer.
1191938: Dec 19 16:55:31.254: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509943, srcCallID=2509944,
                         peer_ccb->call_info.currentLocalName=Julie Urban,
                         ccb->call_info.currentLocalName=,
1191939: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509943, current_seq_num=0x1B1F
1191940: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509943, current_seq_num=0x0
1191941: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1191942: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1191943: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1191944: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1191945: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1191946: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509944
1191947: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1191948: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1191949: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1191950: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1191951: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1191952: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
1191953: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
1191954: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
1191955: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
1191956: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
1191957: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1191958: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400403
1191959: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/sipSPISrtpTranscoder:
1191960: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1191961: Dec 19 16:55:31.254: //2509943/5C225C000001/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1191962: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1191963: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x440018, ccb->pld.flags_ipip 0x400005
1191964: Dec 19 16:55:31.254: //2509944/5C225C000001/SIP/Info/copy_channels:
callId 2509944 size 240 ptr 0x48F94F68)
1191965: Dec 19 16:55:31.258: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1191966: Dec 19 16:55:31.258: //2509943/5C225C000001/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509944 chans 0x48F94F68 event 165 flags 0x40001C 0x18000100 0x400403 data 0x48F94F68
1191967: Dec 19 16:55:31.258: //2509943/5C225C000001/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509944  chans 0x48F94F68 event 165 flags 0x40001C 0x18000100 0x400403 data 0x48F94F68
1191968: Dec 19 16:55:31.258: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1191969: Dec 19 16:55:31.258: //2509943/5C225C000001/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509944 chans 0x48F94F68 event 165 flags 0x40001C 0x18000100 0x400403 data 0x48F94F68 Media Trigger 0
1191970: Dec 19 16:55:31.258: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1191971: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_report_media_to_peer: SIP2SIP, posting channel_ind to peer.
1191972: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1191973: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Callid                 : 2509944
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Media Srce Addr/Port   : [10.97.1.150]:19422
          Media Dest Addr/Port   : [208.29.69.22]:64466
1191974: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1191975: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1191976: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1191977: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1191978: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1191979: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Error/ccsip_alert_parent_or_child: Unable to add unsupported hdrs to container
1191980: Dec 19 16:55:31.258: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1191981: Dec 19 16:55:31.258: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1191982: Dec 19 16:55:31.258: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
1191983: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
1191984: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/State/sipSPIChangeState: 0x4F480A30 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
1191985: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 2 event
1191986: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1191987: Dec 19 16:55:31.258: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1191988: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Info/sipSPISendPrack: Associated container=0x4F7A72C0 to Prack
1191989: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Transport/sipSPISendPrack: Sending PRACK to the transport layer
1191990: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1191991: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Transport/sipSPITransportSendMessage: msg=0x48ED2540, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD693C
1191992: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1191993: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1191994: Dec 19 16:55:31.262: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1191995: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48ED2540
1191996: Dec 19 16:55:31.262: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48ED2540, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1191997: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Info/sentPrack: Sent Prack Request, starting PrackTimer
1191998: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/State/sipSPIChangeState: 0x4F480A30 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
1191999: Dec 19 16:55:31.262: //2509944/5C225C000001/SIP/Info/HandleSIP1xxRinging: Transaction active. Facilities will be queued.
1192000: Dec 19 16:55:31.262: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1192001: Dec 19 16:55:31.262: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1192002: Dec 19 16:55:31.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 112 INVITE
Max-Forwards: 70
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "OPERATOR" <202300>
Remote-Party-ID: "OPERATOR" <202300>;party=calling;screen=yes;privacy=off
Content-Length: 184
v=0
o=CiscoSystemsCCM-SIP 496442 10 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
1192003: Dec 19 16:55:31.266: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1192004: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1192005: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1192006: Dec 19 16:55:31.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1192007: Dec 19 16:55:31.266: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1192008: Dec 19 16:55:31.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1192009: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Info/sact_local_resp_pending_new_message_request: Case of Mid-Call INVITE inSIP_STATE_MIDCALL_LOCAL_RESP_PENDING STATE
1192010: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1192011: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7A5320
1192012: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1192013: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1192014: Dec 19 16:55:31.266: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1192015: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1192016: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
1192017: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7A5320 to Invite Response 100
1192018: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48ED9938, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1192019: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1192020: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1192021: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48ED9938 to default port=5060
1192022: Dec 19 16:55:31.270: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1192023: Dec 19 16:55:31.270: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48ED9938
1192024: Dec 19 16:55:31.270: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48ED9938, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1192025: Dec 19 16:55:31.270: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1192026: Dec 19 16:55:31.270: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509943 ft: 1, inc 4, 208.29.69.22:64466, codec 5
1192027: Dec 19 16:55:31.270: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509943 state STATE_RECD_INVITE
1192693: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1192694: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1192695: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1192696: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1192697: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
1192698: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1192699: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
1192700: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1192701: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1192702: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1192703: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/codec_found:
1192704: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1192705: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1192706: Dec 19 16:55:31.514: //2509932/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1192707: Dec 19 16:55:31.518: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1192708: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1192709: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 0.0.0.0:4000
1192710: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1192711: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1192712: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1192713: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
1192714: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC06018, ccb->pld.flags_ipip 0x400005
1192715: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
1192716: Dec 19 16:55:31.518: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 240 ptr 0x4FA9FAA0)
1192717: Dec 19 16:55:31.518: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1192718: Dec 19 16:55:31.518: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509932 chans 0x4FA9FAA0 event 165 flags 0x8C0401C 0x10000100 0x400007 data 0x4FA9FAA0
1192719: Dec 19 16:55:31.518: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509932  chans 0x4FA9FAA0 event 165 flags 0x8C0401C 0x10000100 0x400007 data 0x4FA9FAA0
1192720: Dec 19 16:55:31.522: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1192721: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509932 chans 0x4FA9FAA0 event 165 flags 0x8C0401C 0x10000100 0x400007 data 0x4FA9FAA0 Media Trigger 0
1192722: Dec 19 16:55:31.522: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1192723: Dec 19 16:55:31.522: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: not sendig Video chan ind for DO Invite case
1192724: Dec 19 16:55:31.522: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1192725: Dec 19 16:55:31.522: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1192726: Dec 19 16:55:31.522: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1192727: Dec 19 16:55:31.522: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
1192728: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x19EB
1192729: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x19EB
1192730: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec:  Mid-call OFFER is pending
1192731: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1192732: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1192733: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1192734: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1192735: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1192736: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1192737: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1192738: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1192739: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1192740: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1192741: Dec 19 16:55:31.522: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1192742: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
1192743: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
1192744: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1192745: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1192746: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1192747: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400007
1192748: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
1192749: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1192750: Dec 19 16:55:31.526: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1192751: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1192752: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
1192753: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS_DELAYED_MEDIA
1192754: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1192755: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7AD670
1192756: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1192757: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1192758: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1192759: Dec 19 16:55:31.526: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1192760: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
1192761: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AD670 to Invite Response 100
1192762: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA52F78, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1192763: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1192764: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1192765: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FA52F78 to default port=5060
1192766: Dec 19 16:55:31.530: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1192767: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FA52F78
1192768: Dec 19 16:55:31.530: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA52F78, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1192769: Dec 19 16:55:31.530: //2509932/28013998B3FF/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.96.3.1:5060
1192770: Dec 19 16:55:31.530: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1192771: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 0.0.0.0:4000, codec 5
1192772: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_ACTIVE
1192773: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams:  Entry..
1192774: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/ccsipMidCallUpdateParams: Updating the preferred_codec_bytes..
1192775: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  config_codec
1192776: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 5 and codec bytes = 160
1192777: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data: Config_codec = 16 and codec bytes = 20
1192778: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  xcoder_codec = -1
1192779: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data: channelInfo_codec
1192780: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  preferred_codec
1192781: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 5 160
1192782: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data:   preferred_codec and codec bytes = 16 20
1192783: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data: OFFER_ALL, REINVITE_NEEDED, UNIVERSAL_XCODER = 0 0 0
1192784: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data: VCC_NEGOTIATED, XCODER_NEEDED_FOR_DTMF_SRTP, VCC_XCODER_USED, RE_ASSOCIATION_NEEDED, CONSUMED_4XX_RESPONSE = 0 0 0 0 0
1192785: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/show_vcc_data:  Low Density call..
1192786: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1192787: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1192788: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1192789: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Call hold using connection mute
1192790: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/sipSPIHoldMediaStream: Muting Stream 1
1192791: Dec 19 16:55:31.534: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1192792: Dec 19 16:55:31.534: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1192793: Dec 19 16:55:31.534: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1192794: Dec 19 16:55:31.534: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1192795: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1192796: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1192797: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4B945B30
1192798: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: Build a line num_elements=1
1192799: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1192800: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1192801: Dec 19 16:55:31.538: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1192802: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_build_audio_mline: NTE max_event 15
1192803: Dec 19 16:55:31.538: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1192804: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1192805: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1192806: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17172, raddr = 208.29.69.22, rport=64744, do_rtcp=TRUE
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = INACTIVE
        media_ip_addr = 0.0.0.0, vrf tableid = 0 media_addr_type = 1
1192807: Dec 19 16:55:31.538: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1192808: Dec 19 16:55:31.538: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1192809: Dec 19 16:55:31.538: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1192810: Dec 19 16:55:31.538: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1192811: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1192812: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1192813: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1192814: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4B945B30
1192815: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931: flags=146825244, flags2=268435712
1192816: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: CALL_HELD=0 Send Mid-call invite based on peer info
1192817: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=17172
1192818: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Error/sipSPIUpdateSrcSdpFixedPart:  owner_sessionid is already their OR src_sdp
                        is corrupted
1192819: Dec 19 16:55:31.542: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction INACTIVE for stream 1
1192820: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1192821: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1192822: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1192823: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1192824: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: Update QoS again before sending reInvite
1192825: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1192826: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 4 a-line(s) found for stream 1
1192827: Dec 19 16:55:31.542: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: No video stream when sending out reInvite.
1192828: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)
1192829: Dec 19 16:55:31.546: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1192830: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_reinvite_delayed_media_update_rtp: Transaction active. Facilities will be queued.
1192831: Dec 19 16:55:31.546: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1192832: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1192833: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4F7A4090
1192834: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_MID_DIALOG_SR_REQ
1192835: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2841
1192836: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLStoreSTContext: Session timer context stored
1192837: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1192838: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1192839: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
1192840: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
1192841: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1192842: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1192843: Dec 19 16:55:31.546: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1192844: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: not adding diversion headers for UAS re-INVITE
1192845: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Info/sipSPISendInvite: Associated container=0x4F7A4090 to Invite
1192846: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
1192847: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1192848: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48F3B860, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD58D8
1192849: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1192850: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1192851: Dec 19 16:55:31.550: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1192852: Dec 19 16:55:31.550: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48F3B860
1192853: Dec 19 16:55:31.550: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F3B860, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1192854: Dec 19 16:55:31.554: //2509931/28013998B3FF/SIP/Info/sentInviteRequest: Sent Invite in state STATE_SEND_MIDCALL_INVITE_PENDING
1192855: Dec 19 16:55:31.554: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
1192856: Dec 19 16:55:31.554: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Setting re_invite_init_flag
1192857: Dec 19 16:55:31.558: //2509932/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6cdf5e4a66e3
CSeq: 113 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
1192858: Dec 19 16:55:31.558: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A031B40
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0671168920-1745162723-3019877092-2825493512
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 113 INVITE
Max-Forwards: 70
Contact: <2587143682300>
Expires: 180
Content-Length: 0
1192859: Dec 19 16:55:31.558: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1192860: Dec 19 16:55:31.558: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1192861: Dec 19 16:55:31.558: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4A871A8C, addr=10.95.3.4, port=50827, local_addr=10.97.1.150, connid=3, transport=TCP
1192862: Dec 19 16:55:31.558: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:919492552601@10.97.1.150:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.95.3.4:5060;branch=z9hG4bK690a5114a7880
From: "Julie Urban" <7143682300>;tag=730887~918169ec-01b0-412c-a6fb-1b14e25860d5-48570817
To: <919492552601>;tag=61715C58-1370
Date: Thu, 19 Dec 2013 16:55:29 GMT
Call-ID: 5c225c00-2b312501-363fe-4035f0a@10.95.3.4
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
1192863: Dec 19 16:55:31.562: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1192864: Dec 19 16:55:31.562: //2509943/5C225C000001/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F491188
1192865: Dec 19 16:55:31.562: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.95.3.4,Port 50827, Transport 2, SentBy Port 5060
1192866: Dec 19 16:55:31.562: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1192867: Dec 19 16:55:31.562: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.95.3.4,Port 50827, Transport 2, SentBy Port 5060
1192868: Dec 19 16:55:31.562: //2509943/5C225C000001/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
1192869: Dec 19 16:55:31.562: //2509943/5C225C000001/SIP/State/sipSPIChangeState: 0x4F491188 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1192870: Dec 19 16:55:31.562: //2509943/5C225C000001/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4F491188
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : YES
Calling Number           : 7143682300
Called Number            : 919492552601
Source IP Address (Sig  ): 10.97.1.150
Destn SIP Req Addr:Port  : 10.95.3.4:5060
Destn SIP Resp Addr:Port : 10.95.3.4:50827
Destination Name         : 10.95.3.4
1192871: Dec 19 16:55:31.566: //2509943/5C225C000001/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.97.1.150
Source IP Port    (Media): 18442
Destn  IP Address (Media): 10.12.15.39
Destn  IP Port    (Media): 30782
Orig Destn IP Address:Port (Media): [ - ]:0
1192872: Dec 19 16:55:31.566: //2509943/5C225C000001/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1192873: Dec 19 16:55:31.566: //2509943/5C225C000001/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 10.12.15.39, RTCP Type 3
1192874: Dec 19 16:55:31.566: //2509943/5C225C000001/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1192875: Dec 19 16:55:31.566: //2509943/5C225C000001/SIP/Info/ccsip_api_update_allowed: UPDATE(2) allowed
1192876: Dec 19 16:55:31.566: //2509943/5C225C000001/SIP/Info/ccsip_offer_ans_handle_update_allowed:
1192877: Dec 19 16:55:31.798: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1192878: Dec 19 16:55:31.798: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1192879: Dec 19 16:55:31.798: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1192880: Dec 19 16:55:31.798: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1192881: Dec 19 16:55:31.802: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1192882: Dec 19 16:55:31.802: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
h: 232
v=0
o=CiscoSystemsSIP-GW-UserAgent 4483 1303 IN IP4 10.97.1.150
s=SIP Call
t=0 0
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
1193445: Dec 19 16:55:32.874: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1193446: Dec 19 16:55:32.878: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1193447: Dec 19 16:55:32.878: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1193448: Dec 19 16:55:32.878: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ce0753b945
Max-Forwards: 70
CSeq: 113 ACK
Content-Type: application/sdp
Content-Length: 233
v=0
o=CiscoSystemsCCM-SIP 496442 11 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 10.95.5.12
b=TIAS:64000
b=AS:64
t=0 0
m=audio 29444 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
1193449: Dec 19 16:55:32.878: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1193450: Dec 19 16:55:32.878: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1193451: Dec 19 16:55:32.878: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1193452: Dec 19 16:55:32.878: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1193453: Dec 19 16:55:32.878: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1193454: Dec 19 16:55:32.882: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1193455: Dec 19 16:55:33.698: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1193456: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1193457: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1193458: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4023275021@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ce14f13eeec
From: <202688>;tag=496403~918169ec-01b0-412c-a6fb-1b14e25860d5-31543662
To: <4023275021>;tag=61684DF4-1EDB
Date: Thu, 19 Dec 2013 16:51:07 GMT
Call-ID: D28C6700-680311E3-B375AAE4-A8699C08@10.97.1.150
Max-Forwards: 70
CSeq: 139 BYE
Reason: Q.850;cause=16
Content-Length: 0
1193459: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1193460: Dec 19 16:55:33.702: //2509756/D288BE10B36F/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F44F428
1193461: Dec 19 16:55:33.702: //2509756/D288BE10B36F/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1193462: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1193463: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1193464: Dec 19 16:55:33.702: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1193465: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2509756], src[4]
1193466: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1193467: Dec 19 16:55:33.706: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIScanThroughReasonHeader: Reason Header: Q.850 Cause: 16
1193468: Dec 19 16:55:33.706: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1193469: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for outgoing call
1193470: Dec 19 16:55:33.706: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1193471: Dec 19 16:55:33.706: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1193472: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1193473: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1193474: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1193475: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1193476: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1193477: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1193478: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
1193479: Dec 19 16:55:33.706: //2509756/D288BE10B36F/SIP/State/sipSPIChangeState: 0x4F44F428 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1193480: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1193481: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1193482: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1193483: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1193484: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1193485: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1193486: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FA4F390
1193487: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1193488: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1193489: Dec 19 16:55:33.714: //2509755/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1193490: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1193491: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1193492: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1193493: Dec 19 16:55:33.714: //2509756/D288BE10B36F/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4F9551BC
1193494: Dec 19 16:55:33.718: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1193495: Dec 19 16:55:33.718: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1193496: Dec 19 16:55:33.718: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1193497: Dec 19 16:55:33.722: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1193498: Dec 19 16:55:33.722: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1193499: Dec 19 16:55:33.722: //2509755/D288BE10B36F/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1193500: Dec 19 16:55:33.722: //2509755/D288BE10B36F/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1193501: Dec 19 16:55:33.722: //2509755/D288BE10B36F/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1193502: Dec 19 16:55:33.722: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1193503: Dec 19 16:55:33.722: //2509756/D288BE10B36F/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1193504: Dec 19 16:55:33.722: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1193505: Dec 19 16:55:33.726: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1193506: Dec 19 16:55:33.726: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1193507: Dec 19 16:55:33.726: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1193508: Dec 19 16:55:33.726: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1193509: Dec 19 16:55:33.726: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2587143682911@10.97.1.150:5060;dtg=printronixtg1 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKje8fr130dgvh012k50b1.1
From: "PRINTRONIX"<5202492879>;tag=SD8sqpe01-656706684-1387472133075-
To: "7143682911 7143682911"<2587143682911>
Call-ID: SD8sqpe01-98365867e8acde7ca0420eaad15fb189-v300g00
CSeq: 98848234 INVITE
Contact: <5202492879>
Supported: 100rel
Accept: application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 286
v=0
o=BroadWorks 86092401 1 IN IP4 208.29.69.22
s=-
t=0 0
m=audio 49914 RTP/AVP 0 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1193510: Dec 19 16:55:33.726: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1193511: Dec 19 16:55:33.726: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F465348) with key=[1850257] to table
1193512: Dec 19 16:55:33.726: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1193513: Dec 19 16:55:33.726: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1193514: Dec 19 16:55:33.730: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1193515: Dec 19 16:55:33.730: //-1/000000000000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1193516: Dec 19 16:55:33.730: //-1/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F465348 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
1193517: Dec 19 16:55:33.730: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1193518: Dec 19 16:55:33.730: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1193519: Dec 19 16:55:33.730: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1193520: Dec 19 16:55:33.730: //-1/35C264F5B40E/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1193521: Dec 19 16:55:33.734: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x482797C4) found for sip_user: 2587143682911
1193522: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1193523: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1193524: Dec 19 16:55:33.734: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1193525: Dec 19 16:55:33.734: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
1193526: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
1193527: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4F465348 key=SD8sqpe01-98365867e8acde7ca0420eaad15fb189-v300g002587143682911
1193528: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
1193529: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 2587143682911
1193530: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 5202492879
1193531: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name PRINTRONIX, number 5202492879, Calling oct3 0x00, oct_3a 0x80, Called number 2587143682911
1193532: Dec 19 16:55:33.734: //-1/35C264F5B40E/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:208.29.69.6:5060, Host:208.29.69.6
1193533: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 5202492879
1193534: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
1193535: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
1193536: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
1193537: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: Peer tag 2584 matched for incoming call
1193538: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1193539: Dec 19 16:55:33.738: //-1/35C264F5B40E/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1193540: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1193541: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
1193542: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
1193543: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
1193544: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
1193545: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
1193546: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1193547: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
1193548: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1193549: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
1193550: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1193551: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
1193552: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
1193553: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIContinueNewMsgInvite: Calling name PRINTRONIX, number 5202492879, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 2587143682911, oct3 0x00
1193554: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
1193555: Dec 19 16:55:33.742: //-1/35C264F5B40E/SIP/Info/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
1193556: Dec 19 16:55:33.746: //-1/35C264F5B40E/SIP/Info/sipSPIValidateRequestUri: Not Enabled
1193557: Dec 19 16:55:33.746: //-1/35C264F5B40E/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
1193558: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
1193559: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1193560: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7AC648
1193561: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1193562: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
1193563: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
1193564: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1193565: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1193566: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
1193567: Dec 19 16:55:33.746: //2509947/35C264F5B40E/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
1193568: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1193569: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 49914
SIP: (2509947) Attribute mid, level 1 instance 1 not found.
1193570: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1193571: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
1193572: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1193573: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1193574: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1193575: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1193576: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1193577: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1193578: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1193579: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1193580: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1193581: Dec 19 16:55:33.750: //2509947/35C264F5B40E/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1193582: Dec 19 16:55:33.750: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1193583: Dec 19 16:55:33.754: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1193584: Dec 19 16:55:33.754: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1193585: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1193586: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1193587: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1193588: Dec 19 16:55:33.754: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1193589: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1193590: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1193591: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=208.29.69.22, dest_port=49914
1193592: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1193593: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
1193594: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1193595: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1193596: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509947 peer 0 flags 0x201 state STATE_IDLE
1193597: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1193598: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1193599: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509947, Peer CallID 0, sdp 0x4FA8F838 channels 0x4F4668E4
1193600: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/copy_channels:
callId 2509947 size 0 ptr 0x4FB757E8)
1193601: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1193602: Dec 19 16:55:33.754: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1193603: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509947
1193604: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1193605: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1193606: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1193607: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/codec_found:
Codec to be matched: 5
1193608: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1193609: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1193610: Dec 19 16:55:33.758: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1193611: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1193612: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
1193613: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 208.29.69.22:49914
1193614: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 8 mline 1
1193615: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
1193616: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/codec_found:
Codec to be matched: 6
1193617: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/codec_found: No match for the codecs found..
1193618: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 18 mline 1
1193619: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
1193620: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8
1193621: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/codec_found:
Codec to be matched: 16
1193622: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/codec_found:  codecs[i] = 16 & codec = 16 are same..
1193623: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 16
SIP: (2509947) Attribute ptime, level 1 instance 1 not found.
1193624: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
1193625: Dec 19 16:55:33.758: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 ptime :0, codecbytes: 0
1193626: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 20
1193627: Dec 19 16:55:33.758: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1193628: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 16 ptype 18 time 0, bytes 20  as channel 1 mline 1 ss 1 208.29.69.22:49914
1193629: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1193630: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509947, dtmf = 6
1193631: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1193632: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 16
1193633: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1193634: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509947 flags 0x10000100 state STATE_IDLE
1193635: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
1193636: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x804000C, ccb->pld.flags_ipip 0x201
1193637: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/copy_channels:
callId 2509947 size 468 ptr 0x4FA770E0)
1193638: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
CCSIP: Unable to report channel ind
1193639: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/ccsip_update_srtp_caps:  7419: Posting Remote SRTP caps to other callleg.
1193640: Dec 19 16:55:33.762: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1194320: Dec 19 16:55:34.018: //2509932/28013998B3FF/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1194321: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 4000
SIP: Attribute mid, level 1 instance 1 not found.
1194322: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1194323: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1194324: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1194325: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1194326: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1194327: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1194328: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
1194329: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
1194330: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1194331: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1194332: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1194333: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1194334: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1194335: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
1194336: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
1194337: Dec 19 16:55:34.022: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1194338: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
1194339: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1194340: Dec 19 16:55:34.022: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1194341: Dec 19 16:55:34.026: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1194342: Dec 19 16:55:34.026: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1194343: Dec 19 16:55:34.026: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1194344: Dec 19 16:55:34.026: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1194345: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1194346: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1194347: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1194348: Dec 19 16:55:34.026: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1194349: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1194350: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1194351: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        stream_type=voice+dtmf (1), dest_ip_address=10.95.5.12, dest_port=4000
1194352: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1194353: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=29444 new=4000
1194354: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDONLY
        Present Local Media Direction = RECVONLY
        New Local Media Direction = RECVONLY
        retVal = 0
1194355: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=No RSVP_ADDR_CHANGE=Yes RSVP_MEDIA_CHANGE=No
1194356: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=No IPIP_MEDIA=Yes
1194357: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Media/sipSPIRSVPCompareSDP: Port Change Identified
1194358: Dec 19 16:55:34.026: //2509932/28013998B3FF/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1194359: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1194360: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1194361: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : No
1194362: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1194363: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1194364: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 peer 2509931 flags 0x404085 state STATE_SENT_MIDCALL_INVITE
1194365: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1194366: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1194367: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1194368: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1194369: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509932, Peer CallID 2509931, sdp 0x48E3AB20 channels 0x4F43AAA4
1194370: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/copy_channels:
callId 2509932 size 240 ptr 0x48F94F68)
1194371: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1194372: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1194373: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509932
1194374: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: Normal call scenario OR FAX -> VOICE scenario..
1194375: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:  ** FAX ** For non xcoder_attached case..
1194376: Dec 19 16:55:34.030: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough:
xmitFunc is set to voip_rtp_xmit for Call 2509932
1194377: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPIProcessFaxT38Passthrough: ** FAX ** Execute only for non-fax case..
1194378: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/ccsip_remote_codec_download_done:
callId 2509932 context 0x4FA5D5A0
1194379: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1194380: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1194381: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1194382: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/codec_found:
1194383: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1194384: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1194385: Dec 19 16:55:34.034: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1194386: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1194387: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 10.95.5.12:4000
1194388: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1194389: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509932, dtmf = 6
1194390: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1194391: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1194392: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1194393: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509932 flags 0x10000140 state STATE_SENT_MIDCALL_INVITE
1194394: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC04018, ccb->pld.flags_ipip 0x404085
1194395: Dec 19 16:55:34.034: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:
Repoort 200OK to reINVITE
1194396: Dec 19 16:55:34.038: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: Reset IS_FAX_TO_VOICE_SWITCH
1194397: Dec 19 16:55:34.038: //2509932/28013998B3FF/SIP/Info/copy_channels:
1194398: Dec 19 16:55:34.038: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 166)
1194399: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509932 chans 0x48F94F68 event 166 flags 0x8C0401C 0x10000160 0x400007 data 0x48F94F68
1194400: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_ACK: peer ID 2509932 chans 0x48F94F68 event 166 flags 0x8C0401C 0x10000160 0x400007 data 0x48F94F68
1194401: Dec 19 16:55:34.038: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1194402: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type =
                                         SIPSPI_EV_CC_NEW_MEDIA for CC_EV_H245_OPEN_CHANNEL_ACK!: peer ID 2509932 chans 0x48F94F68 event 166 flags 0x8C0401C 0x10000160 0x400007 data 0x48F94F68
1194403: Dec 19 16:55:34.038: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1194404: Dec 19 16:55:34.038: //2509932/28013998B3FF/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1194405: Dec 19 16:55:34.038: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer:  Updating the negotiated codec bytes
1194406: Dec 19 16:55:34.038: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1194407: Dec 19 16:55:34.038: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509931, srcCallID=2509932,
                         peer_ccb->call_info.currentLocalName=4254624012 4254624012,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=OPERATOR,
1194408: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509931, current_seq_num=0x5E4
1194409: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509931, current_seq_num=0x5E4
1194410: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1194411: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1194412: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1194413: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1194414: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1194415: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509932
1194416: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1194417: Dec 19 16:55:34.038: //2509931/28013998B3FF/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1194418: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1194419: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1194420: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1194421: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
1194422: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
1194423: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
1194424: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
1194425: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Media/sipSPISetStreamInfo: 0x4FD9F6E0 (gccb)
1194426: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1194427: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400007
1194428: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1194429: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1194430: Dec 19 16:55:34.042: //2509931/28013998B3FF/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1194431: Dec 19 16:55:34.042: //2509932/28013998B3FF/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1194432: Dec 19 16:55:34.042: //2509932/28013998B3FF/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_CHANGING (4)
          Stream address type    : 1
          Callid                 : 2509932
          Negotiated Codec       : g711ulaw, bytes :160
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:18742
          Media Dest Addr/Port   : [10.95.5.12]:4000
1194433: Dec 19 16:55:34.042: //2509932/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1194434: Dec 19 16:55:34.042: //2509932/28013998B3FF/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
1194435: Dec 19 16:55:34.042: //2509932/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:48DEF31C
1194436: Dec 19 16:55:34.042: //2509932/28013998B3FF/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509932) to the VOIP RTP library
1194437: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1194438: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1194439: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1194440: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 18742, raddr = 10.95.5.12, rport=4000, do_rtcp=TRUE
        src_callid = 2509932, dest_callid = 2509931, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr = 10.95.5.12, vrf tableid = 0 media_addr_type = 1
1194441: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1194442: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Info/sipSPICreateRtpSession: sess: 48F6B838 do_rtcp:1
1194443: Dec 19 16:55:34.046: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194444: Dec 19 16:55:34.046: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194445: Dec 19 16:55:34.046: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194446: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194447: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194448: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194449: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Media/sipSPICreateRtpSession: stun is disabled
1194450: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1194451: Dec 19 16:55:34.046: //2509932/28013998B3FF/SIP/Media/sipSPIGetNewLocalMediaDirection:
        Present Local Media Direction = SENDRECV
        retVal = 1
1194452: Dec 19 16:55:34.050: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction RECVONLY for stream 1
1194453: Dec 19 16:55:34.050: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194454: Dec 19 16:55:34.050: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194455: Dec 19 16:55:34.050: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194456: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194457: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194458: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194459: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48DEF31C
1194460: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509932)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
1194461: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/ccsip_api_response_answer: Modified QoS params INVITE
1194462: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/sact_sent_mid_invite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
1194463: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
1194464: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194465: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194466: Dec 19 16:55:34.050: //2509932/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1194467: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Info/sipSPISendAck: Associated container=0x4F7A97E0 to Ack
1194468: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1194469: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1194470: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x48E95E64, addr=10.96.3.1, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD7968
1194471: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1194472: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1194473: Dec 19 16:55:34.054: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1194474: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48E95E64
1194475: Dec 19 16:55:34.054: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48E95E64, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1194476: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1194477: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1194478: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
1194479: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4F439508
TCP Sockets Used         : NO
Calling Number           : 4254624012
Called Number            : 7950
Destn SIP Req Addr:Port  : 10.96.3.1:5060
Destn SIP Resp Addr:Port : 10.96.3.1:5060
Destination Name         : 10.96.3.1
1194480: Dec 19 16:55:34.054: //2509932/28013998B3FF/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 18742
Destn  IP Address (Media): 10.95.5.12
Destn  IP Port    (Media): 4000
1194481: Dec 19 16:55:34.054: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
1194482: Dec 19 16:55:34.054: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2509931 ft: 1, inc 4, 10.95.5.12:4000, codec 5
1194483: Dec 19 16:55:34.054: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 2509931 state STATE_MIDCALL_LOCAL_RESP_PENDING
1194484: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
1194485: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
1194486: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509931, channels 0x48F94F68 caps 0x4F3DE0B0
1194487: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509931, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1194488: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
1194489: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/codec_found:
1194490: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1194491: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
1194492: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
1194493: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 12
1194494: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Reset IS_FAX_TO_VOICE_SWITCH
1194495: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x400007
1194496: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
1194497: Dec 19 16:55:34.058: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1194498: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
1194499: Dec 19 16:55:34.058: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDONLY for stream 1
1194500: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17172
1194501: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1194502: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1194503: Dec 19 16:55:34.058: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1194504: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1194505: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1194506: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17172, raddr = 208.29.69.22, rport=64744, do_rtcp=TRUE
        src_callid = 2509931, dest_callid = 2509932, stream type = voice+dtmf, stream direction = SENDONLY
        media_ip_addr = 208.29.69.22, vrf tableid = 0 media_addr_type = 1
1194507: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1194508: Dec 19 16:55:34.062: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194509: Dec 19 16:55:34.062: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194510: Dec 19 16:55:34.062: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194511: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1194512: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194513: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194514: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48E46E5C
1194515: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1194516: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
1194517: Dec 19 16:55:34.062: //2509931/28013998B3FF/SIP/Info/sipSPIUpdateStreamQoSAttributes: 5 a-line(s) found for stream 1
1194680: Dec 19 16:55:40.398: //2509919/D9D7C47BB3E0/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F48B9C0 key=SD06vfe01-1efbcd87b52dc0c85995cfab8d7dd352-v300g00616F0BA8-22D1
1194681: Dec 19 16:55:40.398: //2509919/D9D7C47BB3E0/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1194682: Dec 19 16:55:40.402: //2509919/D9D7C47BB3E0/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1194683: Dec 19 16:55:40.402: //2509919/D9D7C47BB3E0/SIP/Info/ccsip_offer_ans_delete:
1194684: Dec 19 16:55:40.402: //2509919/D9D7C47BB3E0/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F48B9C0
1194685: Dec 19 16:55:42.406: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1194686: Dec 19 16:55:42.406: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1194687: Dec 19 16:55:42.406: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1194688: Dec 19 16:55:42.406: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4254624012@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ce2731fe4df
From: <7950>;tag=496442~918169ec-01b0-412c-a6fb-1b14e25860d5-31543764
To: "4254624012 4254624012" <4254624012>;tag=61710BFC-1326
Date: Thu, 19 Dec 2013 16:55:34 GMT
Call-ID: 280D6E80-680511E3-B405AAE4-A8699C08@10.97.1.150
User-Agent: Cisco-CUCM8.6
Max-Forwards: 70
CSeq: 114 BYE
Content-Length: 0
1194689: Dec 19 16:55:42.406: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1194690: Dec 19 16:55:42.406: //2509932/28013998B3FF/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F439508
1194691: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1194692: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1194693: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1194694: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1194695: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2509932], src[4]
1194696: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1194697: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIScanThroughReasonHeader: Reason Header: Q.850 Cause: 16
1194698: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1194699: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for outgoing call
1194700: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1194701: Dec 19 16:55:42.410: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1194702: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1194703: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1194704: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1194705: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1194706: Dec 19 16:55:42.410: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1194707: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1194708: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
1194709: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1194710: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194711: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194712: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194713: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1194714: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194715: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194716: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48E46E5C
1194717: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1194718: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194719: Dec 19 16:55:42.414: //2509931/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194720: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1194721: Dec 19 16:55:42.414: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1194722: Dec 19 16:55:42.418: //2509932/28013998B3FF/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1194723: Dec 19 16:55:42.418: //2509932/28013998B3FF/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48DEF31C
1194724: Dec 19 16:55:42.418: //2509931/28013998B3FF/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1194725: Dec 19 16:55:42.418: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1194726: Dec 19 16:55:42.418: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1194727: Dec 19 16:55:42.418: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1194728: Dec 19 16:55:42.418: //2509932/28013998B3FF/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1194729: Dec 19 16:55:42.418: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1194730: Dec 19 16:55:42.418: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1194731: Dec 19 16:55:42.418: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1194732: Dec 19 16:55:42.418: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1194733: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1194734: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1194735: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194736: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194737: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1194738: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1194739: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Info/sipSPISendBye: Associated container=0x4F7AEFE0 to Bye
1194740: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
1194741: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1194742: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4F92E39C, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD6EEC
1194743: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1194744: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1194745: Dec 19 16:55:42.422: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1194746: Dec 19 16:55:42.422: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4F92E39C
1194747: Dec 19 16:55:42.426: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4F92E39C, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1194748: Dec 19 16:55:42.426: //2509931/28013998B3FF/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
1194749: Dec 19 16:55:42.426: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1194750: Dec 19 16:55:42.426: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1194751: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1194752: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194753: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194754: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Info/sipSPISendByeResponse: Associated container=0x4F7ABEB8 to Bye Response
1194755: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
1194756: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FAFDC98, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD734C
1194757: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1194758: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1194759: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FAFDC98 to default port=5060
1194760: Dec 19 16:55:42.426: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1194761: Dec 19 16:55:42.426: //2509932/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FAFDC98
1194762: Dec 19 16:55:42.430: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FAFDC98, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1194763: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
1194764: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 0 DiscTime:-1984000620 ConnTime -1984003776
1194765: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:48DEF31C
1194766: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F439508 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1194767: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
State of The Call        : STATE_DEAD
Source IP Address (Sig  ): 10.97.1.150
1194768: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.97.1.150
Orig Destn IP Address:Port (Media): [ - ]:0
1194769: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
1194770: Dec 19 16:55:42.430: //2509932/28013998B3FF/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C6C
1194771: Dec 19 16:55:42.434: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4254624012@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A09623
From: "7143682300 7143682300"<2587143682300>;tag=61710C34-1664
To: "4254624012 4254624012"<4254624012>;tag=SD4tbnd01-1447779698-1387472110587-
Call-ID: SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g00
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1387472142
CSeq: 114 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1078,OS=172480,PR=0,OR=0,PL=0,JI=0,LA=0,DU=31
Content-Length: 0
1194772: Dec 19 16:55:42.434: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 19 Dec 2013 16:55:42 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 114 BYE
P-RTP-Stat: PS=0,OS=0,PR=1081,OR=172960,PL=0,JI=0,LA=0,DU=31
Content-Length: 0
1194773: Dec 19 16:55:43.238: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1194774: Dec 19 16:55:43.242: //2509931/28013998B3FF/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1194775: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Info/sipSPISendBye: Associated container=0x4F7AEFE0 to Bye
1194776: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
1194777: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1194778: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: msg=0x4FAFDC98, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1194779: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1194780: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1194781: Dec 19 16:55:43.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1194782: Dec 19 16:55:43.246: //2509931/28013998B3FF/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FAFDC98
1194783: Dec 19 16:55:43.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FAFDC98, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1194784: Dec 19 16:55:43.246: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1194785: Dec 19 16:55:43.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1194786: Dec 19 16:55:43.246: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1194787: Dec 19 16:55:43.250: //2509931/28013998B3FF/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK167A09623 from via branch list
1194788: Dec 19 16:55:43.250: //2509931/28013998B3FF/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F449C60
1194789: Dec 19 16:55:43.250: //2509931/28013998B3FF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 114 BYE
Content-Length: 0
1194790: Dec 19 16:55:43.250: //2509931/28013998B3FF/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
1194791: Dec 19 16:55:43.250: //2509931/28013998B3FF/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 0 DiscTime:-1984000538 ConnTime -1984003764
1194792: Dec 19 16:55:43.250: //2509931/28013998B3FF/SIP/Media/sipSPIDestroyRtpSession: stream:48E46E5C
1194793: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1194794: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4F449C60
Called Number            : 2587143682300
Destn SIP Req Addr:Port  : 208.29.69.6:5060
Destn SIP Resp Addr:Port : 208.29.69.6:5060
Destination Name         : 208.29.69.6
1194795: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17172
Destn  IP Address (Media): 208.29.69.22
Destn  IP Port    (Media): 64744
1194796: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Call/sipSPICallInfo:
1194797: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C6B
1194798: Dec 19 16:55:43.254: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850247] removed.
1194799: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
1194800: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F449C60 key=SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g002587143682300
1194801: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
1194802: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F449C60 key=SD4tbnd01-aacf5f07a807f1abf06e816141516281-v300g0061710C34-1664
1194803: Dec 19 16:55:43.254: //2509931/28013998B3FF/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1194804: Dec 19 16:55:43.258: //2509931/28013998B3FF/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1194805: Dec 19 16:55:43.258: //2509931/28013998B3FF/SIP/Info/ccsip_offer_ans_delete:
1194806: Dec 19 16:55:43.258: //2509931/28013998B3FF/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F449C60
1194807: Dec 19 16:55:43.258: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1850247]
1194808: Dec 19 16:55:43.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Timestamp: 1387472143
CSeq: 114 BYE
Content-Length: 0
1194809: Dec 19 16:55:44.078: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1194810: Dec 19 16:55:44.078: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1194811: Dec 19 16:55:44.078: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1194812: Dec 19 16:55:44.078: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1194813: Dec 19 16:55:44.078: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 114 BYE
Content-Length: 0
1194814: Dec 19 16:55:44.078: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
1194815: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1194816: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1194817: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1194818: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:5202492879@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 10.96.3.1:5060;branch=z9hG4bKc6ce367082af2
From: <202911>;tag=496448~918169ec-01b0-412c-a6fb-1b14e25860d5-31543776
To: "PRINTRONIX" <5202492879>;tag=617166D8-36B
Date: Thu, 19 Dec 2013 16:55:33 GMT
Call-ID: 35EAAD38-680511E3-B414AAE4-A8699C08@10.97.1.150
Max-Forwards: 70
Supported: timer,resource-priority,replaces
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 UPDATE
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: <7400>
Remote-Party-ID: <7400>;party=calling;screen=yes;privacy=off
Contact: <5202492879>;isFocus
Content-Length: 0
1194819: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1194820: Dec 19 16:55:50.098: //2509948/35C264F5B40E/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4F454BF0
1194821: Dec 19 16:55:50.098: //2509948/35C264F5B40E/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
1194822: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1194823: Dec 19 16:55:50.098: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1194824: Dec 19 16:55:50.102: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1194825: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
1194826: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/ccsipEarlyDialogUpdateParams:  Entry..
1194827: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/ccsip_api_request_offer: prev_send_sdp_buf is not allocated
1194828: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1194829: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1194830: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1194831: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1194832: Dec 19 16:55:50.102: //2509948/35C264F5B40E/SIP/Error/ccsip_api_request_offer: Unable to add passthru hdrs to
                               container
1194833: Dec 19 16:55:50.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F449C60) with key=[1850259] to table
1194834: Dec 19 16:55:50.102: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1194835: Dec 19 16:55:50.102: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1194836: Dec 19 16:55:50.102: //-1/000000000000/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: , current remote number: 7400
1194837: Dec 19 16:55:50.102: //-1/000000000000/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
1194838: Dec 19 16:55:50.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850259] removed.
1194839: Dec 19 16:55:50.106: //-1/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1194840: Dec 19 16:55:50.106: //-1/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1194841: Dec 19 16:55:50.106: //-1/000000000000/SIP/Info/ccsip_offer_ans_delete:
1194842: Dec 19 16:55:50.106: //-1/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F449C60
1194843: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1194844: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:109, resp_code:0, container:4F7A3F88
1194845: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1194846: Dec 19 16:55:50.106: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1194847: Dec 19 16:55:50.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleNewEarlyDialogOffer: ccsip_api_request_offer return val:SIP_SUCCESS
1194848: Dec 19 16:55:50.106: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1194849: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/act_handle_app_media_event: method = 109 state = 4
1194850: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
1194851: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1194852: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:200, container:4F7A6240
1194853: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1194854: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1194855: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194856: Dec 19 16:55:50.106: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194857: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Info/sipSPISendUpdateResponse: Associated container=0x4F7A6240 to Update Response
1194858: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Transport/sipSPISendUpdateResponse: Sending UPDATE Response to the transport layer
1194859: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x4FAFDC98, addr=10.96.3.1, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1194860: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1194861: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1194862: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FAFDC98 to default port=5060
1194863: Dec 19 16:55:50.110: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1194864: Dec 19 16:55:50.110: //2509948/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FAFDC98
1194865: Dec 19 16:55:50.110: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FAFDC98, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1194866: Dec 19 16:55:50.110: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg: ccb NULL, unable to update the callinfo ui parameters
1194867: Dec 19 16:55:50.110: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
1194868: Dec 19 16:55:50.266: //2509948/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 19 Dec 2013 16:55:50 GMT
CSeq: 101 UPDATE
Allow-Events: telephone-event
Content-Length: 0
1194869: Dec 19 16:55:50.266: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
1194870: Dec 19 16:55:50.266: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPreProcessCallerIDMediaEvent: Updated Connected Party Name:  Updated Connected Party Number: 7400 Updated Connected Party Oct3a: 0xFFFFFF81
1194871: Dec 19 16:55:50.266: //2509947/35C264F5B40E/SIP/Info/act_handle_app_media_event: method = 109 state = 14
1194872: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_OFFER
1194873: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
1194874: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sact_app_media_event_send_request: Transaction active. CCAPI events will be queued.
1194875: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1194876: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:0, container:4F7ACFE8
1194877: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1194878: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 6 event
1194879: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1194880: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
SIP: (2509947) Group (a= group line) attribute, level 65535 instance 1 not found.
1194881: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1194882: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509947
1194883: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Info/sipSPISendUpdate: Associated container=0x4F7ACFE8 to Update
1194884: Dec 19 16:55:50.270: //2509947/35C264F5B40E/SIP/Transport/sipSPISendUpdate: Sending UPDATE to the transport layer
1194885: Dec 19 16:55:50.274: //2509947/35C264F5B40E/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1194886: Dec 19 16:55:50.274: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x4FAFDC98, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD774C
1194887: Dec 19 16:55:50.274: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1194888: Dec 19 16:55:50.274: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1194889: Dec 19 16:55:50.274: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1194890: Dec 19 16:55:50.274: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FAFDC98
1194891: Dec 19 16:55:50.274: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FAFDC98, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1194892: Dec 19 16:55:50.274: //2509947/35C264F5B40E/SIP/Info/sentUpdate: Sent Update Request, starting UpdateTimer
1194893: Dec 19 16:55:50.290: //2509947/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:5202492879@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A0A1CB0
From: "7143682911 7143682911"<2587143682911>;tag=61716760-955
To: "PRINTRONIX"<5202492879>;tag=SD8sqpe01-656706684-1387472133075-
Call-ID: SD8sqpe01-98365867e8acde7ca0420eaad15fb189-v300g00
Max-Forwards: 70
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Timestamp: 1387472150
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 UPDATE
Contact: <2587143682911>
Min-SE:  1800
Content-Length: 0
1194894: Dec 19 16:55:50.290: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1194895: Dec 19 16:55:50.290: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1194896: Dec 19 16:55:50.290: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1194897: Dec 19 16:55:50.290: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1194898: Dec 19 16:55:50.294: //2509948/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A07197E
To: <202911>;tag=496448~918169ec-01b0-412c-a6fb-1b14e25860d5-31543776
CSeq: 101 INVITE
Allow-Events: presence
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
P-Asserted-Identity: "VoiceMail" <7400>
Remote-Party-ID: "VoiceMail" <7400>;party=called;screen=yes;privacy=off
Contact: <202911>;isFocus
Content-Type: application/sdp
Content-Length: 231
v=0
o=CiscoSystemsCCM-SIP 496448 1 IN IP4 10.96.3.1
s=SIP Call
c=IN IP4 10.96.3.2
b=TIAS:64000
b=AS:64
t=0 0
m=audio 17406 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
1194899: Dec 19 16:55:50.294: //2509948/35C264F5B40E/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1194900: Dec 19 16:55:50.294: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1194901: Dec 19 16:55:50.294: //2509948/35C264F5B40E/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
1194902: Dec 19 16:55:50.294: //2509948/35C264F5B40E/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
1194903: Dec 19 16:55:50.294: //2509947/35C264F5B40E/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 2509947/2509948
1194904: Dec 19 16:55:50.294: //2509947/35C264F5B40E/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=2509947, new streamcallid=2509947
1194905: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
1194906: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1194907: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:4F7A6240
1194908: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: uas
1194909: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
1194910: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLProcessLegByLegPeerEvent: session expires received in response so starting session timer
1194911: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLStartSessionTimer: Started Session Expiry Timer with duration:1768000
1194912: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
1194913: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 1800;refresher:uas peer refresher:none, flags:801, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
1194914: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1194915: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1194916: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1194917: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1194918: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1194919: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/ccsip_api_call_connect_media:  Unable to add headers into container
1194920: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
1194921: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1194922: Dec 19 16:55:50.298: //2509948/35C264F5B40E/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 17406
SIP: Attribute mid, level 1 instance 1 not found.
1194923: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1194924: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1194925: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
1194926: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1194927: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1194928: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1194929: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1194930: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1194931: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1194932: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1194933: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
1194934: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
1194935: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1194936: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
1194937: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1194938: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1194939: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1194940: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1194941: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1194942: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1194943: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1194944: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1194945: Dec 19 16:55:50.302: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1194946: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1194947: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1194948: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=10.96.3.2, dest_port=17406
1194949: Dec 19 16:55:50.302: //2509948/35C264F5B40E/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1194950: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1194951: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
1194952: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1194953: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1194954: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509948 peer 2509947 flags 0x400005 state STATE_RECD_PROCEEDING
1194955: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1194956: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1194957: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1194958: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1194959: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509948, Peer CallID 2509947, sdp 0x4F9D931C channels 0x4F45618C
1194960: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/copy_channels:
callId 2509948 size 468 ptr 0x4FC8AED8)
1194961: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1194962: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1194963: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509948
1194964: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1194965: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1194966: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1194967: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/codec_found:
Codec to be matched: 5
1194968: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1194969: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1194970: Dec 19 16:55:50.306: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1194971: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1194972: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 10.96.3.2:17406
1194973: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1194974: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509948, dtmf = 6
1194975: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1194976: Dec 19 16:55:50.306: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1194977: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
1194978: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509948 flags 0x10000100 state STATE_RECD_PROCEEDING
1194979: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: Reporting media in Substate SUBSTATE_PROCEEDING_PROCEEDING
1194980: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
1194981: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC00018, ccb->pld.flags_ipip 0x400005
1194982: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating the negotiated codec bytes
1194983: Dec 19 16:55:50.310: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: Post CAPS to peer.
1194984: Dec 19 16:55:50.310: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=2509947, srcCallID=2509948,
                         peer_ccb->call_info.currentLocalName=PRINTRONIX,
                         peer_ccb->call_info.currentRemoteName=,
                         ccb->call_info.currentLocalName=,
1194985: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=2509947, current_seq_num=0x12C2
1194986: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=2509947, current_seq_num=0x0
1194987: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
1194988: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
1194989: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
1194990: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
1194991: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
1194992: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509948
1194993: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
1194994: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1194995: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
1194996: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
1194997: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
1194998: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
1194999: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
1195000: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
1195001: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
1195002: Dec 19 16:55:50.310: //2509947/35C264F5B40E/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
1195003: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
1195004: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400403
1195005: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1195006: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
1195007: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
1195008: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
1195009: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC00018, ccb->pld.flags_ipip 0x400005
1195010: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/copy_channels:
callId 2509948 size 240 ptr 0x48ECF1C4)
1195011: Dec 19 16:55:50.314: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
1195012: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509948 chans 0x48ECF1C4 event 165 flags 0x8C4001C 0x10000100 0x400403 data 0x48ECF1C4
1195013: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2509948  chans 0x48ECF1C4 event 165 flags 0x8C4001C 0x10000100 0x400403 data 0x48ECF1C4
1195014: Dec 19 16:55:50.314: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
1195015: Dec 19 16:55:50.314: //2509947/35C264F5B40E/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2509948 chans 0x48ECF1C4 event 165 flags 0x8C4001C 0x10000100 0x400403 data 0x48ECF1C4 Media Trigger 0
1195016: Dec 19 16:55:50.314: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1195017: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_report_media_to_peer: SIP2SIP, posting channel_ind to peer.
1195018: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/ccsip_update_srtp_caps:  7396: Not Sending NULL SRTP CAPS to SIP LEG
1195019: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Stream address type    : 1
          Callid                 : 2509948
          Negotiated Codec       : g711ulaw, bytes :160
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:19526
          Media Dest Addr/Port   : [10.96.3.2]:17406
1195020: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1195021: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
1195022: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
1195023: Dec 19 16:55:50.314: //2509948/35C264F5B40E/SIP/Info/sipSPIQoSRevertBW: Entry
1195024: Dec 19 16:55:50.314: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1195025: Dec 19 16:55:50.314: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1195026: Dec 19 16:55:50.314: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
1195027: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPIShrlCall: Check peer: 2581 for Shared-Line call, callid: 2509948
1195028: Dec 19 16:55:50.318: //2509947/35C264F5B40E/SIP/Info/sipSPIShrlCall: Check peer: 2584 for Shared-Line call, callid: 2509947
1195029: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPIOptionsPing: Session Timer negotiated, not doing Options Ping
1195030: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
1195031: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
1195032: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195033: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195034: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Info/sipSPISendAck: Associated container=0x4F7A2CA0 to Ack
1195035: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
1195036: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1195037: Dec 19 16:55:50.318: //2509948/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x48F16FAC, addr=10.96.3.1, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD7968
1195076: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
1195077: Dec 19 16:55:50.326: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1195078: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 16690
1195079: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
1195080: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1195081: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 15
1195082: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1195083: Dec 19 16:55:50.326: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1195084: Dec 19 16:55:50.326: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1195085: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/ccsip_query_force_association: REINVITE_NEEDED is FALSE. return FALSE
1195086: Dec 19 16:55:50.330: //2509948/35C264F5B40E/SIP/Info/ccsip_query_force_association: REINVITE_NEEDED is FALSE. return FALSE
1195087: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/ccsip_bridge: confID = 453818, srcCallID = 2509947, dstCallID = 2509948
1195088: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: 2509947/2509948, new src/dest ccCallids: 2509947/2509948
1195089: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=2509947, new streamcallid=2509947
1195090: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
1195091: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1140113100, ccb xmitFunc = 1140113100
1195092: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/ccsip_spi_check_call_locally_held: CCSIP: call is locally noton-hold
1195093: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509947) to the VOIP RTP library
1195094: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1195095: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1195096: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1195097: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 16690, raddr = 208.29.69.22, rport=49914, do_rtcp=TRUE
        src_callid = 2509947, dest_callid = 2509948, stream type = voice+dtmf, stream direction = SENDRECV
1195098: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1195099: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/sipSPICreateRtpSession: sess: 4900E4D8 do_rtcp:1
1195100: Dec 19 16:55:50.330: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1195101: Dec 19 16:55:50.330: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195102: Dec 19 16:55:50.330: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195103: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1195104: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195105: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195106: Dec 19 16:55:50.330: //2509947/35C264F5B40E/SIP/Media/sipSPICreateRtpSession: stun is disabled
1195107: Dec 19 16:55:50.334: //2509947/35C264F5B40E/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1195108: Dec 19 16:55:50.334: //2509947/35C264F5B40E/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDRECV
        Present Local Media Direction = SENDRECV
        New Local Media Direction = SENDRECV
        retVal = 0
1195109: Dec 19 16:55:50.334: //2509947/35C264F5B40E/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509947)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
1195110: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/ccsip_bridge: confID = 453818, srcCallID = 2509948, dstCallID = 2509947
1195111: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 2509948/2509947
1195112: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=2509948, new streamcallid=2509948
1195113: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
1195114: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1140113100, ccb xmitFunc = 1140113100
1195115: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/ccsip_spi_check_call_locally_held: CCSIP: call is locally noton-hold
1195116: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509948) to the VOIP RTP library
1195117: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1195118: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1195119: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1195120: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 19526, raddr = 10.96.3.2, rport=17406, do_rtcp=TRUE
        src_callid = 2509948, dest_callid = 2509947, stream type = voice+dtmf, stream direction = SENDRECV
        media_ip_addr = 10.96.3.2, vrf tableid = 0 media_addr_type = 1
1195121: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1195122: Dec 19 16:55:50.334: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1195123: Dec 19 16:55:50.334: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195124: Dec 19 16:55:50.334: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195125: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1195126: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195127: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195128: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48E46E5C
1195129: Dec 19 16:55:50.334: //2509948/35C264F5B40E/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1195130: Dec 19 16:55:50.338: //2509948/35C264F5B40E/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
1195131: Dec 19 16:55:50.338: //2509948/35C264F5B40E/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509948)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
1195132: Dec 19 16:55:50.370: //2509948/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:202911@10.96.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A0BB77
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
1195133: Dec 19 16:55:50.374: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195134: Dec 19 16:55:50.374: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195135: Dec 19 16:55:50.374: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195136: Dec 19 16:55:50.374: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195137: Dec 19 16:55:50.374: //2509947/35C264F5B40E/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK167A0A1CB0 from via branch list
1195138: Dec 19 16:55:50.374: //2509947/35C264F5B40E/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F465348
1195139: Dec 19 16:55:50.374: //2509947/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 UPDATE
Supported:
Content-Length: 0
1195140: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
1195141: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Info/ccsip_api_response_answer: ccsip_api_response_answer.
1195142: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Info/ccsip_api_response_answer: Received a response to an UPDATE without SDP
1195143: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1195144: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:109, resp_code:200, container:4F7AC280
1195145: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring early dialog update for session timer processing
1195146: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Info/act_recdinvite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
1195147: Dec 19 16:55:50.378: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_call_connect: CCSIP_CALL_CONNECT: ccb ptr 4F465348
1195148: Dec 19 16:55:50.378: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_call_connect: CCSIP_CALL_CONNECT: app_diaplay_name[] app_display_num[202911]
1195149: Dec 19 16:55:50.378: //2509947/35C264F5B40E/SIP/Info/ccsip_call_connect: CCSIP_CALL_CONNECT : KPML_CONFIGURED[FALSE] collect_digits[2587143682911] calledNumber[2587143682911] display_name[] display_num[202911]
1195150: Dec 19 16:55:50.378: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
1195151: Dec 19 16:55:50.382: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
1195152: Dec 19 16:55:50.382: //2509947/35C264F5B40E/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
1195153: Dec 19 16:55:50.382: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
1195154: Dec 19 16:55:50.382: //2509947/35C264F5B40E/SIP/Info/sipSPIQoSRevertBW: Entry
1195155: Dec 19 16:55:50.382: //2509947/35C264F5B40E/SIP/Info/preprocessConnect: Write sdp_info into msg_body
1195156: Dec 19 16:55:50.382: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1195157: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:4F7AC280
1195158: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
1195159: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
1195160: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLTurnOffSessionTimer: Session timer turned off
1195161: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:140, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
1195162: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
1195163: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195164: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195165: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
1195166: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509947
1195167: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPISendInviteResponse: Transaction active. Facilities will be queued.
1195168: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1195169: Dec 19 16:55:50.386: //2509947/35C264F5B40E/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AC280 to Invite Response 200
1195170: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
1195171: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA71FD4, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD6B68
1195172: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195173: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195174: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FA71FD4 to default port=5060
1195175: Dec 19 16:55:50.390: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195176: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FA71FD4
1195177: Dec 19 16:55:50.390: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA71FD4, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195178: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
1195179: Dec 19 16:55:50.390: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
1195180: Dec 19 16:55:50.390: //2509947/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F465348 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE)  to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
1195181: Dec 19 16:55:50.406: //2509947/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKje8fr130dgvh012k50b1.1
From: "PRINTRONIX"<5202492879>;tag=SD8sqpe01-656706684-1387472133075-
To: "7143682911 7143682911"<2587143682911>;tag=61716760-955
Date: Thu, 19 Dec 2013 16:55:34 GMT
CSeq: 98848234 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 803 1107 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 16690 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
1195182: Dec 19 16:55:51.258: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195183: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 2509947
1195184: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Info/sipSPISendInviteResponse: Transaction active. Facilities will be queued.
1195185: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1195186: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AC280 to Invite Response 200
1195187: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
1195188: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x4FA71FD4, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1195189: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195190: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195191: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FA71FD4 to default port=5060
1195192: Dec 19 16:55:51.262: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195193: Dec 19 16:55:51.262: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FA71FD4
1195194: Dec 19 16:55:51.262: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FA71FD4, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195195: Dec 19 16:55:51.262: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195196: Dec 19 16:55:51.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195197: Dec 19 16:55:51.266: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:2587143682911@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bK5k7krq1048u171ujh7r0.1
CSeq: 98848234 ACK
Max-Forwards: 68
Content-Length: 0
1195198: Dec 19 16:55:51.266: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195199: Dec 19 16:55:51.266: //2509947/35C264F5B40E/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F465348
1195200: Dec 19 16:55:51.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195201: Dec 19 16:55:51.266: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195202: Dec 19 16:55:51.266: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195203: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
1195204: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F465348 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
1195205: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4F465348
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 5202492879
Called Number            : 2587143682911
Source IP Address (Sig  ): 10.97.1.150
1195206: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.97.1.150
Source IP Port    (Media): 16690
Destn  IP Port    (Media): 49914
Orig Destn IP Address:Port (Media): [ - ]:0
1195207: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
1195208: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 208.29.69.22, RTCP Type 3
1195209: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195210: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Info/ccsip_api_update_allowed: UPDATE(2) allowed
1195211: Dec 19 16:55:51.270: //2509947/35C264F5B40E/SIP/Info/ccsip_offer_ans_handle_update_allowed:
1195212: Dec 19 16:55:51.286: //2509947/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Supported: timer
Content-Length: 243
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
1195213: Dec 19 16:55:52.082: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195214: Dec 19 16:55:52.082: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195215: Dec 19 16:55:52.082: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195216: Dec 19 16:55:52.082: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 98848234 ACK
Max-Forwards: 68
Content-Length: 0
1195217: Dec 19 16:55:52.082: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195218: Dec 19 16:55:52.086: //2509947/35C264F5B40E/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F465348
1195219: Dec 19 16:55:52.086: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195220: Dec 19 16:55:52.086: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195221: Dec 19 16:55:52.086: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195222: Dec 19 16:55:54.462: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195223: Dec 19 16:55:54.462: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195224: Dec 19 16:55:54.466: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195225: Dec 19 16:55:54.466: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:2587143682911@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bK5k7krq1048u171ujh7r0cd50pr4m3.1
CSeq: 98848236 BYE
Max-Forwards: 68
Content-Length: 0
1195226: Dec 19 16:55:54.466: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195227: Dec 19 16:55:54.466: //2509947/35C264F5B40E/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F465348
1195228: Dec 19 16:55:54.466: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195229: Dec 19 16:55:54.466: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195230: Dec 19 16:55:54.466: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195231: Dec 19 16:55:54.466: //2509947/35C264F5B40E/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2509947], src[2]
1195232: Dec 19 16:55:54.466: //2509947/35C264F5B40E/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195233: Dec 19 16:55:54.470: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1195234: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for incoming call
1195235: Dec 19 16:55:54.470: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1195236: Dec 19 16:55:54.470: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1195237: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195238: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195239: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1195240: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1195241: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1195242: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1195243: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
1195244: Dec 19 16:55:54.470: //2509947/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F465348 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1195245: Dec 19 16:55:54.470: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1195246: Dec 19 16:55:54.470: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195247: Dec 19 16:55:54.474: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195248: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1195249: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195250: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195251: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FA83058
1195252: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1195253: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195254: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195255: Dec 19 16:55:54.474: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1195256: Dec 19 16:55:54.474: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195257: Dec 19 16:55:54.474: //2509948/35C264F5B40E/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195258: Dec 19 16:55:54.474: //2509948/35C264F5B40E/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48E46E5C
1195259: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1195260: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195261: Dec 19 16:55:54.474: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195262: Dec 19 16:55:54.478: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1195263: Dec 19 16:55:54.478: //2509948/35C264F5B40E/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1195264: Dec 19 16:55:54.478: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195265: Dec 19 16:55:54.478: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195266: Dec 19 16:55:54.478: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1195267: Dec 19 16:55:54.478: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1195268: Dec 19 16:55:54.478: //2509947/35C264F5B40E/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1195269: Dec 19 16:55:54.478: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195270: Dec 19 16:55:54.478: //2509947/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195271: Dec 19 16:55:54.478: //2509947/35C264F5B40E/SIP/Info/sipSPISendByeResponse: Associated container=0x4F7AC648 to Bye Response
1195272: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
1195273: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x4FEDCD64, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD734C
1195274: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195275: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195276: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FEDCD64 to default port=5060
1195277: Dec 19 16:55:54.482: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195278: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FEDCD64
1195279: Dec 19 16:55:54.482: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FEDCD64, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195280: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
1195281: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:-1983999415 ConnTime -1983999824
1195282: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/Media/sipSPIDestroyRtpSession: stream:4FA83058
1195283: Dec 19 16:55:54.482: //2509947/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F465348 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1195284: Dec 19 16:55:54.486: //2509947/35C264F5B40E/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Destn SIP Req Addr:Port  : 208.29.69.6:5060
Destn SIP Resp Addr:Port : 208.29.69.6:5060
Destination Name         : 208.29.69.6
1195285: Dec 19 16:55:54.486: //2509947/35C264F5B40E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Destn  IP Address (Media): 208.29.69.22
1195286: Dec 19 16:55:54.486: //2509947/35C264F5B40E/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
1195287: Dec 19 16:55:54.486: //2509947/35C264F5B40E/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C7B
1195288: Dec 19 16:55:54.486: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1195289: Dec 19 16:55:54.486: //2509948/35C264F5B40E/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195290: Dec 19 16:55:54.486: //2509948/35C264F5B40E/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1195291: Dec 19 16:55:54.486: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195292: Dec 19 16:55:54.486: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195293: Dec 19 16:55:54.486: //2509948/35C264F5B40E/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195294: Dec 19 16:55:54.486: //2509948/35C264F5B40E/SIP/Info/sipSPISendBye: Associated container=0x4F7A2F08 to Bye
1195295: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
1195296: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1195297: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: msg=0x4F92E39C, addr=10.96.3.1, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD6EEC
1195298: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195299: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195300: Dec 19 16:55:54.490: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1195301: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4F92E39C
1195302: Dec 19 16:55:54.490: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4F92E39C, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1195303: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
1195304: Dec 19 16:55:54.490: //2509948/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1195305: Dec 19 16:55:54.490: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 19 Dec 2013 16:55:54 GMT
CSeq: 98848236 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=207,OS=33120,PR=195,OR=31200,PL=0,JI=0,LA=0,DU=4
Content-Length: 0
1195306: Dec 19 16:55:54.494: //2509948/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:202911@10.96.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A0C62F
Call-ID: 35EAAD38-680511E3-B414AAE4-A8699C08@10.97.1.150
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
P-Asserted-Identity: "PRINTRONIX" <5202492879>
Timestamp: 1387472154
CSeq: 102 BYE
P-RTP-Stat: PS=195,OS=31200,PR=215,OR=34400,PL=0,JI=0,LA=0,DU=4
Content-Length: 0
1195307: Dec 19 16:55:54.494: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1195308: Dec 19 16:55:54.498: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195309: Dec 19 16:55:54.498: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195310: Dec 19 16:55:54.498: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195311: Dec 19 16:55:54.498: //2509948/35C264F5B40E/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK167A0C62F from via branch list
1195312: Dec 19 16:55:54.498: //2509948/35C264F5B40E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
1195313: Dec 19 16:55:54.498: //2509948/35C264F5B40E/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
1195314: Dec 19 16:55:54.498: //2509948/35C264F5B40E/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:-1983999413 ConnTime -1983999831
1195315: Dec 19 16:55:54.498: //2509948/35C264F5B40E/SIP/Media/sipSPIDestroyRtpSession: stream:48E46E5C
1195316: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1195317: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4F454BF0
Called Number            : 202911
Destn SIP Req Addr:Port  : 10.96.3.1:5060
Destn SIP Resp Addr:Port : 10.96.3.1:5060
Destination Name         : 10.96.3.1
1195318: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 19526
Destn  IP Address (Media): 10.96.3.2
Destn  IP Port    (Media): 17406
1195319: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Call/sipSPICallInfo:
1195320: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C7C
1195321: Dec 19 16:55:54.502: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850258] removed.
1195322: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
1195323: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F454BF0 key=35EAAD38-680511E3-B414AAE4-A8699C08@10.97.1.150
1195324: Dec 19 16:55:54.502: //2509948/35C264F5B40E/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1195325: Dec 19 16:55:54.506: //2509948/35C264F5B40E/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1195326: Dec 19 16:55:54.506: //2509948/35C264F5B40E/SIP/Info/ccsip_offer_ans_delete:
1195327: Dec 19 16:55:54.506: //2509948/35C264F5B40E/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F454BF0
1195328: Dec 19 16:55:54.506: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1850258]
1195329: Dec 19 16:55:57.946: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850245] removed.
1195330: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
1195331: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F496950 key=SD0dsrd01-c64e5874f3025ec1c90ef3402f710bc6-v300g002587143682911
1195332: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
1195333: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F496950 key=SD0dsrd01-c64e5874f3025ec1c90ef3402f710bc6-v300g006170EB04-F37
1195334: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1195335: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
1195336: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1195337: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/ccsip_offer_ans_delete:
1195338: Dec 19 16:55:57.946: //2509929/22FDA3CEB3F8/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F496950
1195339: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195340: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195341: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195342: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2587143682869@10.97.1.150:5060;dtg=printronixtg1 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKe3ejt230doag11e0m2d0.1
From: "4254624012 4254624012"<4254624012>;tag=SD84tbf01-779751661-1387472159016-
To: "7143682869 7143682869"<2587143682869>
Call-ID: SD84tbf01-e99cb98551dfedebb42bd944b75cf559-v300g00
CSeq: 98861205 INVITE
Contact: <4254624012>
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept: application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 68
Content-Type: application/sdp
Content-Length: 286
v=0
o=BroadWorks 86093090 1 IN IP4 208.29.69.22
s=-
c=IN IP4 208.29.69.22
t=0 0
m=audio 49960 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
1195343: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195344: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F496950) with key=[1850260] to table
1195345: Dec 19 16:55:59.082: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1195346: Dec 19 16:55:59.082: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1195347: Dec 19 16:55:59.082: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195348: Dec 19 16:55:59.086: //-1/000000000000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1195349: Dec 19 16:55:59.086: //-1/44DF7A05B415/SIP/State/sipSPIChangeState: 0x4F496950 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
1195350: Dec 19 16:55:59.086: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195351: Dec 19 16:55:59.086: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195352: Dec 19 16:55:59.086: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195353: Dec 19 16:55:59.086: //-1/44DF7A05B415/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1195354: Dec 19 16:55:59.086: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x482797C4) found for sip_user: 2587143682869
1195355: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1195356: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1195357: Dec 19 16:55:59.090: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1195358: Dec 19 16:55:59.090: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
1195359: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
1195360: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4F496950 key=SD84tbf01-e99cb98551dfedebb42bd944b75cf559-v300g002587143682869
1195361: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
1195362: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 2587143682869
1195363: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 4254624012
1195364: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name 4254624012 4254624012, number 4254624012, Calling oct3 0x00, oct_3a 0x80, Called number 2587143682869
1195365: Dec 19 16:55:59.090: //-1/44DF7A05B415/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:208.29.69.6:5060, Host:208.29.69.6
1195366: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 4254624012
1195367: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
1195368: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
1195369: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
1195370: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Peer tag 2584 matched for incoming call
1195371: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1195372: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1195373: Dec 19 16:55:59.094: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1195374: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
1195375: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
1195376: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
1195377: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
1195378: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
1195379: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1195380: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
1195381: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1195382: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
1195383: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1195384: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
1195385: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
1195386: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIContinueNewMsgInvite: Calling name 4254624012 4254624012, number 4254624012, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 2587143682869, oct3 0x00
1195387: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
1195388: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
1195389: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIValidateRequestUri: Not Enabled
1195390: Dec 19 16:55:59.098: //-1/44DF7A05B415/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
1195391: Dec 19 16:55:59.098: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
1195392: Dec 19 16:55:59.098: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1195393: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4F7ABB48
1195394: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1195395: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
1195396: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
1195397: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
1195398: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1195399: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
1195400: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
1195401: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1195402: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 49960
SIP: (2509950) Attribute mid, level 1 instance 1 not found.
1195403: Dec 19 16:55:59.102: //2509950/44DF7A05B415/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1195404: Dec 19 16:55:59.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
1195405: Dec 19 16:55:59.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1195406: Dec 19 16:55:59.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
1195407: Dec 19 16:55:59.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
1195408: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1195409: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1195410: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
1195411: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1195412: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1195413: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1195414: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1195415: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1195416: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
1195417: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1195418: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
1195419: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1195420: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
1195421: Dec 19 16:55:59.106: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1195422: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1195423: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1195424: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=208.29.69.22, dest_port=49960
1195425: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
1195426: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
1195427: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1195428: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1195429: Dec 19 16:55:59.106: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509950 peer 0 flags 0x201 state STATE_IDLE
1195430: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
1195431: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
1195432: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2509950, Peer CallID 0, sdp 0x48ED26E4 channels 0x4F497EEC
1195433: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/copy_channels:
callId 2509950 size 0 ptr 0x4B255B88)
1195434: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB t38 version 0 ipip_caps version 0
1195435: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CCB fax rate 2 ipip_caps rate 14400
1195436: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 2509950
1195437: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
1195438: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1195439: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1195440: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/codec_found:
Codec to be matched: 5
1195441: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1195442: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1195443: Dec 19 16:55:59.110: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1195444: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
1195445: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
1195446: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 1 208.29.69.22:49960
1195447: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 8 mline 1
1195448: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
1195449: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/codec_found:
Codec to be matched: 6
1195450: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/codec_found: No match for the codecs found..
1195451: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 18 mline 1
1195452: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
1195453: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8
1195454: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/codec_found:
Codec to be matched: 16
1195455: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/codec_found:  codecs[i] = 16 & codec = 16 are same..
1195456: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 16
SIP: (2509950) Attribute ptime, level 1 instance 1 not found.
1195457: Dec 19 16:55:59.110: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
1195458: Dec 19 16:55:59.114: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 ptime :0, codecbytes: 0
1195459: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 20
1195460: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
1195461: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 16 ptype 18 time 0, bytes 20  as channel 1 mline 1 ss 1 208.29.69.22:49960
1195462: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
1195463: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 2509950, dtmf = 6
1195464: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
1195465: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 16
1195466: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
1195467: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2509950 flags 0x10000100 state STATE_IDLE
1195468: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
1195469: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x804000C, ccb->pld.flags_ipip 0x201
1195470: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/copy_channels:
callId 2509950 size 468 ptr 0x4FEE093C)
1195471: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer:
CCSIP: Unable to report channel ind
1195472: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/ccsip_update_srtp_caps:  7419: Posting Remote SRTP caps to other callleg.
1195473: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
1195474: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Stream address type    : 1
          Callid                 : 2509950
          Negotiated Codec       : g711ulaw, bytes :160
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [10.97.1.150]:0
          Media Dest Addr/Port   : [208.29.69.22]:49960
1195475: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 6
Preferred and Negotiated NTE payloads: 101 101
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated V150.1 Modem Passthrough: 0 0
Preferred and Negotiated V150.1 Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
1195476: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1195477: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1195478: Dec 19 16:55:59.114: //2509950/44DF7A05B415/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
1195479: Dec 19 16:55:59.118: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17348 for stream 1
1195480: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17348
1195481: Dec 19 16:55:59.118: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1195482: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17348
1195483: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1195484: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
1195485: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
1195486: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = SD84tbf01-e99cb98551dfedebb42bd944b75cf559-v300g00
1195487: Dec 19 16:55:59.118: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
1195488: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
1195489: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1195490: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1195491: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1195492: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1195493: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
1195494: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/ccsip_api_call_setup_ind: Set Protocol information
1195495: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195496: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195497: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
1195498: Dec 19 16:55:59.118: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_store_channel_info: dtmf negotiation done, storing negotiated dtmf = 6,
1195499: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Info/sipSPIShrlCall: Check peer: 2584 for Shared-Line call, callid: 2509950
1195500: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Info/ccsip_set_bearer_capability:
   Bearer Capability: Speech (0x00)
1195501: Dec 19 16:55:59.122: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1195502: Dec 19 16:55:59.122: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1195503: Dec 19 16:55:59.122: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
1195504: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
1195505: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 264C7E to table
1195506: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1195507: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4F7AE8A8
1195508: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1195509: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AE8A8 to Invite Response 100
1195510: Dec 19 16:55:59.122: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: msg=0x4F92E39C, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1195511: Dec 19 16:55:59.126: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195512: Dec 19 16:55:59.126: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195513: Dec 19 16:55:59.126: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4F92E39C to default port=5060
1195514: Dec 19 16:55:59.126: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195515: Dec 19 16:55:59.126: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4F92E39C
1195516: Dec 19 16:55:59.126: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4F92E39C, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195517: Dec 19 16:55:59.126: //2509950/44DF7A05B415/SIP/State/sipSPIChangeState: 0x4F496950 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
1195518: Dec 19 16:55:59.126: //2509950/44DF7A05B415/SIP/Info/sipSPIProcessContactInfo: Previous Hop 208.29.69.6:5060
1195519: Dec 19 16:55:59.130: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
1195520: Dec 19 16:55:59.134: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4F454BF0) with key=[1850261] to table
1195521: Dec 19 16:55:59.134: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
1195522: Dec 19 16:55:59.134: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1195523: Dec 19 16:55:59.134: //2509951/000000000000/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
1195524: Dec 19 16:55:59.134: //2509951/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
1195525: Dec 19 16:55:59.134: //2509951/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
1195526: Dec 19 16:55:59.134: //2509951/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 0, codec 5 channel 49960, ip 208.29.69.22:49960  params 0x4F7E899C caps 0x4FD266F8
1195527: Dec 19 16:55:59.134: //2509951/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 1, codec 16 channel 49960, ip 208.29.69.22:49960  params 0x4F7E899C caps 0x4FD266F8
1195528: Dec 19 16:55:59.134: //2509951/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
1195529: Dec 19 16:55:59.134: //2509951/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
1195530: Dec 19 16:55:59.134: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 10.96.3.1 target_port : 5060
1195531: Dec 19 16:55:59.134: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
1195532: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [2] in dial-peer [2581]
1195533: Dec 19 16:55:59.138: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 171)
1195534: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2509951 chans 0x490E2848 event 171 flags 0x844001C 0x10000100 0x601 data 0x490E2848
1195535: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 2509951 chans 0x490E2848 event 171 flags 0x844001C 0x10000100 0x603 data 0x490E2848, type = 1
1195536: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/ccsip_event_handler: Current mode is SIP-TDM
1195537: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
1195538: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SET_MODE
1195539: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLMain:
1195540: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/ccsip_event_handler:
Changing the flow mode due to SET_MODE
1195541: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/sipSPIHandleMediaFlowModeChange:
1195542: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/sipSPIHandleMediaFlowModeChange: current media flow mode is 1, desired media flow mode is 1
1195543: Dec 19 16:55:59.138: //2509950/44DF7A05B415/SIP/Info/sipSPIHandleMediaFlowModeChange: current flow mode is same as desired flow mode
1195544: Dec 19 16:55:59.138: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
1195545: Dec 19 16:55:59.138: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
1195546: Dec 19 16:55:59.138: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
1195547: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 264C7F to table
1195548: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
1195549: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1195550: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
1195551: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
1195552: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
1195553: Dec 19 16:55:59.138: //2509951/44DF7A05B415/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
1195554: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
1195555: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
1195556: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1195557: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2509950
1195558: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1195559: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
1195560: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1195561: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
1195562: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
1195563: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
1195564: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
1195565: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: Valid peer channels available!!
1195566: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: No video caps posted by peer
1195567: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2509951, channels 0x4F91EE60 caps 0x4FD266F8
1195568: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 2509951, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 14400
1195569: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIDtmfTranscoder: Return upon SCCP version 0
1195570: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
1195571: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder:  Entry..
1195572: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: AudioLevelAdjustment do not need xcoder
1195573: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_codec_byte_transrating: codec class not supported in xrating scenario, return FALSE
1195574: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPICodecTranscoder: No body else needs xcoder. OFFER_ALL is intact
1195575: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_vcc_CheckVoiceClassCodecConfiguration: Either one of the call leg supports Voice Class Codec..
1195576: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Check between Equalset & Subset..
1195577: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/codec_found:
1195578: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1195579: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found.. continue for next codec..
1195580: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/codec_found:
1195581: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/codec_found:  codecs[i] = 16 & codec = 16 are same..
1195582: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: Match found.. continue for next codec..
1195583: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_vcc_CheckCodecSetType: This is Equal set
1195584: Dec 19 16:55:59.142: //2509951/44DF7A05B415/SIP/Info/sipSPICodecTranscoder: Static codec or Equalset or Subset w/o offer-all. For DO call, offer-all is NO-OP..
1195585: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/codec_found:
1195586: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
1195587: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/codec_found:
1195588: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/codec_found:  codecs[i] = 16 & codec = 16 are same..
1195589: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 2
1195590: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sipSPICheckAndReserveTranscoder: Xcoder is not needed
1195591: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sipSPISrtpTranscoder:
1195592: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_setOptionTagInfo: Option Tag Rel1xx value is 0
1195593: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1195594: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1195595: Dec 19 16:55:59.146: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17010 for stream 1
1195596: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
1195597: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sipSPIAddSDPPayloadAttributes:
max_event 15
1195598: Dec 19 16:55:59.146: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1195599: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
1195600: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
1195601: Dec 19 16:55:59.146: //2509951/44DF7A05B415/SIP/Media/sipSPIProcessRtpSessions: No active streams.
1195602: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
1195603: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
1195604: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
1195605: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
1195606: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Using globally configured pai header
1195607: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Using Oct3a info identity = pai header
1195608: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Using Oct3a info privacy = system header
1195609: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
1195610: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
1195611: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_set_diversion_header: No diversion header recvd from container
1195612: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1195613: Dec 19 16:55:59.150: //2509951/44DF7A05B415/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
1195614: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.97.1.150
1195615: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
1195616: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4F454BF0 key=44E9DA76-680511E3-B41BAAE4-A8699C08@10.97.1.150
1195617: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 44E9DA76-680511E3-B41BAAE4-A8699C08@10.97.1.150
1195618: Dec 19 16:55:59.154: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.96.3.1,Port 5060, Transport 1, SentBy Port 5060
1195619: Dec 19 16:55:59.154: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195620: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1195621: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4F7A9D08
1195622: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
1195623: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
1195624: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLMain:
1195625: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
1195626: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195627: Dec 19 16:55:59.154: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195628: Dec 19 16:55:59.154: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (2509951) Group (a= group line) attribute, level 65535 instance 1 not found.
1195629: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
1195630: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Info/sipSPISendInvite: Associated container=0x4F7A9D08 to Invite
1195631: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
1195632: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1195633: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: msg=0x4FAFDC98, addr=10.96.3.1, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD58D8
1195634: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195635: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195636: Dec 19 16:55:59.158: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.96.3.1, rport:5060 with laddr:10.97.1.150
1195637: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FAFDC98
1195638: Dec 19 16:55:59.158: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FAFDC98, addr=10.96.3.1, port=5060, local_addr=10.97.1.150, connId=5 for UDP
1195639: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
1195640: Dec 19 16:55:59.158: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
1195641: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
1195642: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2509951) to the VOIP RTP library
1195643: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1195644: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.97.1.150
1195645: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1195646: Dec 19 16:55:59.158: //2509951/44DF7A05B415/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.97.1.150, lport = 17010, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 2509951, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1
1195647: Dec 19 16:55:59.162: //2509951/44DF7A05B415/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1195648: Dec 19 16:55:59.162: //2509951/44DF7A05B415/SIP/Info/sipSPICreateRtpSession: sess: 4F952BB0 do_rtcp:0
1195649: Dec 19 16:55:59.162: //2509950/44DF7A05B415/SIP/Info/ccsip_update_peer_caps: Stream is NULL
1195650: Dec 19 16:55:59.162: //2509950/44DF7A05B415/SIP/Info/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
1195651: Dec 19 16:55:59.162: //2509951/44DF7A05B415/SIP/Info/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
1195652: Dec 19 16:55:59.162: //2509951/44DF7A05B415/SIP/Media/sipSPICreateRtpSession: stun is disabled
1195653: Dec 19 16:55:59.162: //2509951/44DF7A05B415/SIP/State/sipSPIChangeStreamState: Stream (callid =  2509951)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
1195654: Dec 19 16:55:59.162: //2509950/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 19 Dec 2013 16:55:59 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
1195655: Dec 19 16:55:59.166: //2509951/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:202869@10.96.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A0D1F8B
From: "4254624012 4254624012" <4254624012>;tag=6171C920-16D
To: <202869>
Call-ID: 44E9DA76-680511E3-B41BAAE4-A8699C08@10.97.1.150
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1155496453-1745162723-3021318884-2825493512
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1387472159
Expires: 180
Max-Forwards: 67
P-Asserted-Identity: "4254624012 4254624012" <4254624012>
Content-Disposition: session;handling=required
Content-Length: 277
v=0
o=CiscoSystemsSIP-GW-UserAgent 844 666 IN IP4 10.97.1.150
s=SIP Call
c=IN IP4 10.97.1.150
t=0 0
m=audio 17010 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
1195656: Dec 19 16:55:59.170: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1195657: Dec 19 16:55:59.170: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195658: Dec 19 16:55:59.170: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195659: Dec 19 16:55:59.170: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195660: Dec 19 16:55:59.170: //2509951/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <202869>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
1195661: Dec 19 16:55:59.170: //2509951/44DF7A05B415/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1195662: Dec 19 16:55:59.170: //2509951/44DF7A05B415/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
1195663: Dec 19 16:55:59.402: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [10.96.3.1]:5060, local_address:[10.97.1.150]
1195664: Dec 19 16:55:59.402: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195665: Dec 19 16:55:59.402: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195666: Dec 19 16:55:59.402: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195667: Dec 19 16:55:59.402: //2509951/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <202869>;tag=496451~918169ec-01b0-412c-a6fb-1b14e25860d5-31543781
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Allan Choo" <202869>
Remote-Party-ID: "Allan Choo" <202869>;party=called;screen=yes;privacy=off
Contact: <202869>
Content-Length: 0
1195668: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
1195669: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
1195670: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/ccsip_offer_ans_handle_update_allowed:
1195671: Dec 19 16:55:59.406: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1195672: Dec 19 16:55:59.406: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
1195673: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
1195674: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1195675: Dec 19 16:55:59.406: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1195676: Dec 19 16:55:59.406: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1195677: Dec 19 16:55:59.406: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
1195678: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1195679: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1195680: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1195681: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1195682: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Error/ccsip_alert_parent_or_child: Unable to add unsupported
                                      hdrs to container
1195683: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
1195684: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/State/sipSPIChangeState: 0x4F454BF0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
1195685: Dec 19 16:55:59.406: //2509951/44DF7A05B415/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
1195686: Dec 19 16:55:59.426: //2509950/44DF7A05B415/SIP/Info/ccsip_call_alert: CCSIP_CALL_ALERT: app_diaplay_name[] app_display_num[202869]
1195687: Dec 19 16:55:59.430: //2509950/44DF7A05B415/SIP/Info/ccsip_call_alert: CCSIP_CALL_ALERT : KPML_CONFIGURED[FALSE] collect_digits[2587143682869] calledNumber[2587143682869] display_name[] display_num[202869]
1195688: Dec 19 16:55:59.430: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
1195689: Dec 19 16:55:59.434: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 5
1195690: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
1195691: Dec 19 16:55:59.434: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIStoreTunnelData: Container /RawMessage Absent
1195692: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
1195693: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
1195694: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4F496950 key=SD84tbf01-e99cb98551dfedebb42bd944b75cf559-v300g006171CA38-1856
1195695: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
1195696: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:4F7AB8E0
1195697: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
1195698: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 9 event
1195699: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195700: Dec 19 16:55:59.434: //2509950/44DF7A05B415/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195701: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AB8E0 to Invite Response 180
1195702: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
1195703: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: msg=0x48EC7540, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x41BD6750
1195704: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195705: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195706: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48EC7540 to default port=5060
1195707: Dec 19 16:55:59.438: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195708: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48EC7540
1195709: Dec 19 16:55:59.438: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48EC7540, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195710: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Info/sentInviteResponse18x: Sent a 18x Response
1195711: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/Info/sentInviteResponse18x: Transaction active. Facilities will be queued.
1195712: Dec 19 16:55:59.438: //2509950/44DF7A05B415/SIP/State/sipSPIChangeState: 0x4F496950 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_SENT_ALERTING, SUBSTATE_NONE)
1195713: Dec 19 16:55:59.450: //2509950/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "7143682869 7143682869"<2587143682869>;tag=6171CA38-1856
Require: 100rel
RSeq: 6906
Contact: <202869>
Content-Length: 0
1195714: Dec 19 16:56:00.190: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195715: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C74
1195716: Dec 19 16:56:00.190: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850253] removed.
1195717: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
1195718: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F42E578 key=SDcjfhc01-482c4ba20541fe1256cd4849b8e13905-v300g00
1195719: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
1195720: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1195721: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1195722: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/ccsip_offer_ans_delete:
1195723: Dec 19 16:56:00.190: //2509940/32264F9AB406/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F42E578
1195724: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Info/sipSPIResendInviteResponse: resending 180 response due to no PRACK
1195725: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Info/sipSPISendInviteResponse: Associated container=0x4F7AB8E0 to Invite Response 180
1195726: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
1195727: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: msg=0x4FC8E374, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1195728: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195729: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195730: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FC8E374 to default port=5060term mon
1195731: Dec 19 16:56:00.194: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195732: Dec 19 16:56:00.194: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FC8E374
1195733: Dec 19 16:56:00.194: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FC8E374, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195734: Dec 19 16:56:00.194: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195735: Dec 19 16:56:00.194: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195736: Dec 19 16:56:00.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:202869@10.97.1.150:5060 SIP/2.0
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKqbas4e00505gc12j37o1.1
CSeq: 98861206 PRACK
RAck: 6906 98861205 INVITE
Max-Forwards: 68
Content-Length: 0
1195737: Dec 19 16:56:00.198: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195738: Dec 19 16:56:00.198: //2509950/44DF7A05B415/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F496950
1195739: Dec 19 16:56:00.198: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195740: Dec 19 16:56:00.198: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195741: Dec 19 16:56:00.198: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195742: Dec 19 16:56:00.198: //2509950/44DF7A05B415/SIP/Info/act_recdinvite_new_message_request: Transaction Complete. Lock on Facilities released.
1195743: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Transport/sipSPISendPrackResponse: Sending PRACK Response to the transport layer
1195744: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: msg=0x48F16FAC, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1195745: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195746: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195747: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48F16FAC to default port=5060
1195748: Dec 19 16:56:00.202: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195749: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48F16FAC
1195750: Dec 19 16:56:00.202: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F16FAC, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195751: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
1195752: Dec 19 16:56:00.202: //2509950/44DF7A05B415/SIP/Info/ccsip_offer_ans_handle_update_allowed:
1195753: Dec 19 16:56:00.210: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195754: Dec 19 16:56:00.210: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195755: Dec 19 16:56:00.210: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4A871A8C, addr=10.95.3.4, port=50827, local_addr=10.97.1.150, connid=3, transport=TCP
1195756: Dec 19 16:56:00.210: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:919492552601@10.97.1.150:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.95.3.4:5060;branch=z9hG4bK690a614679b5e
From: "Julie Urban" <7143682300>;tag=730887~918169ec-01b0-412c-a6fb-1b14e25860d5-48570817
To: <919492552601>;tag=61715C58-1370
Date: Thu, 19 Dec 2013 16:55:29 GMT
Call-ID: 5c225c00-2b312501-363fe-4035f0a@10.95.3.4
User-Agent: Cisco-CUCM8.6
Max-Forwards: 70
P-Asserted-Identity: "Julie Urban" <7143682300>
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
1195757: Dec 19 16:56:00.210: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195758: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F491188
1195759: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.95.3.4,Port 50827, Transport 2, SentBy Port 5060
1195760: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195761: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.95.3.4,Port 50827, Transport 2, SentBy Port 5060
1195762: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2509943], src[2]
1195763: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195764: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIScanThroughReasonHeader: Reason Header: Q.850 Cause: 16
1195765: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1195766: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for incoming call
1195767: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
1195768: Dec 19 16:56:00.214: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
1195769: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195770: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195771: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1195772: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1195773: Dec 19 16:56:00.214: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
1195774: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1195775: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
1195776: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/State/sipSPIChangeState: 0x4F491188 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1195777: Dec 19 16:56:00.218: //2509944/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1195778: Dec 19 16:56:00.218: //2509944/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195779: Dec 19 16:56:00.218: //2509944/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195780: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1195781: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195782: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195783: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4FAB13C4
1195784: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
1195785: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195786: Dec 19 16:56:00.218: //2509943/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195787: Dec 19 16:56:00.218: //2509944/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
1195788: Dec 19 16:56:00.218: //2509944/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nte
1195789: Dec 19 16:56:00.218: //2509944/5C225C000001/SIP/Info/updateGccbTxRxValues: No interworking required for nse
1195790: Dec 19 16:56:00.222: //2509944/5C225C000001/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48F44A60
1195791: Dec 19 16:56:00.222: //2509950/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 208.29.69.6:5060;branch=z9hG4bKe3ejt230doag11e0m2d0.1
From: "4254624012 4254624012"<4254624012>;tag=SD84tbf01-779751661-1387472159016-
Call-ID: SD84tbf01-e99cb98551dfedebb42bd944b75cf559-v300g00
CSeq: 98861205 INVITE
Require: 100rel
RSeq: 6906
Contact: <202869>
Content-Length: 0
1195792: Dec 19 16:56:00.226: //2509950/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 19 Dec 2013 16:56:00 GMT
Content-Length: 0
1195793: Dec 19 16:56:00.226: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195794: Dec 19 16:56:00.226: //2509943/5C225C000001/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1195795: Dec 19 16:56:00.226: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195796: Dec 19 16:56:00.226: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195797: Dec 19 16:56:00.226: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1195798: Dec 19 16:56:00.230: //2509944/5C225C000001/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
1195799: Dec 19 16:56:00.230: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1195800: Dec 19 16:56:00.230: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1195801: Dec 19 16:56:00.230: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1195802: Dec 19 16:56:00.230: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195803: Dec 19 16:56:00.230: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195804: Dec 19 16:56:00.230: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 68
Content-Length: 0
1195805: Dec 19 16:56:00.230: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195806: Dec 19 16:56:00.230: //2509950/44DF7A05B415/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4F496950
1195807: Dec 19 16:56:00.234: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195808: Dec 19 16:56:00.234: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
1195809: Dec 19 16:56:00.234: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 208.29.69.6,Port 5060, Transport 1, SentBy Port 5060
1195810: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Info/act_recdinvite_new_message_request: Transaction Complete. Lock on Facilities released.
1195811: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Transport/sipSPISendPrackResponse: Sending PRACK Response to the transport layer
1195812: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: msg=0x4FC8E374, addr=208.29.69.6, port=5060, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=1, switch=0, callBack=0x0
1195813: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195814: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195815: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4FC8E374 to default port=5060
1195816: Dec 19 16:56:00.234: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195817: Dec 19 16:56:00.234: //2509950/44DF7A05B415/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4FC8E374
1195818: Dec 19 16:56:00.234: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FC8E374, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195819: Dec 19 16:56:00.238: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1195820: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1195821: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195822: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195823: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Info/sipSPISendByeResponse: Associated container=0x4F7ADF08 to Bye Response
1195824: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
1195825: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Transport/sipSPITransportSendMessage: msg=0x48F16FAC, addr=10.95.3.4, port=50827, sentBy_port=5060, local_addr=10.97.1.150, is_req=0, transport=2, switch=0, callBack=0x41BD734C
1195826: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195827: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195828: Dec 19 16:56:00.238: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48F16FAC, addr=10.95.3.4, port=50827, local_addr=10.97.1.150, connId=3 for TCP
1195829: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
1195830: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:-1983998839 ConnTime -1984001715
1195831: Dec 19 16:56:00.238: //2509943/5C225C000001/SIP/Media/sipSPIDestroyRtpSession: stream:4FAB13C4
1195832: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/State/sipSPIChangeState: 0x4F491188 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1195833: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4F491188
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 7143682300
Called Number            : 919492552601
Source IP Address (Sig  ): 10.97.1.150
Destn SIP Req Addr:Port  : 10.95.3.4:5060
Destn SIP Resp Addr:Port : 10.95.3.4:50827
Destination Name         : 10.95.3.4
1195834: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.97.1.150
Source IP Port    (Media): 18442
Destn  IP Address (Media): 10.12.15.39
Destn  IP Port    (Media): 30782
Orig Destn IP Address:Port (Media): [ - ]:0
1195835: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
1195836: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C77
1195837: Dec 19 16:56:00.242: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850255] removed.
1195838: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
1195839: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F491188 key=5c225c00-2b312501-363fe-4035f0a@10.95.3.4919492552601
1195840: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
1195841: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F491188 key=5c225c00-2b312501-363fe-4035f0a@10.95.3.461715C58-1370
1195842: Dec 19 16:56:00.242: //2509943/5C225C000001/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1195843: Dec 19 16:56:00.246: //2509943/5C225C000001/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1195844: Dec 19 16:56:00.246: //2509943/5C225C000001/SIP/Info/ccsip_offer_ans_delete:
1195845: Dec 19 16:56:00.246: //2509943/5C225C000001/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F491188
1195846: Dec 19 16:56:00.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1850255]
1195847: Dec 19 16:56:00.246: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: gcb has cleanedup, Done with send operations for this context
1195848: Dec 19 16:56:00.246: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1850255]
1195849: Dec 19 16:56:00.246: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
1195850: Dec 19 16:56:00.246: //2509944/5C225C000001/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195851: Dec 19 16:56:00.246: //2509944/5C225C000001/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
1195852: Dec 19 16:56:00.246: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195853: Dec 19 16:56:00.246: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer:  Could not get any elements from TD Container
1195854: Dec 19 16:56:00.246: //2509944/5C225C000001/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
1195855: Dec 19 16:56:00.246: //2509944/5C225C000001/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195856: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Info/sipSPISendBye: Associated container=0x4F7A3900 to Bye
1195857: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
1195858: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1195859: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Transport/sipSPITransportSendMessage: msg=0x48EC7540, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x41BD6EEC
1195860: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195861: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195862: Dec 19 16:56:00.250: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195863: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48EC7540
1195864: Dec 19 16:56:00.250: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48EC7540, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195865: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
1195866: Dec 19 16:56:00.250: //2509944/5C225C000001/SIP/State/sipSPIChangeState: 0x4F480A30 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
1195867: Dec 19 16:56:00.250: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 BYE
P-RTP-Stat: PS=1447,OS=231520,PR=1461,OR=226740,PL=0,JI=0,LA=0,DU=28
Content-Length: 0
1195868: Dec 19 16:56:00.254: //2509950/44DF7A05B415/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Content-Length: 0
1195869: Dec 19 16:56:00.254: //2509944/5C225C000001/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:9492552601@208.29.69.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.97.1.150:5060;branch=z9hG4bK167A0E118
To: <9492552601>;tag=SDq0to999-1731103686-1387472130854
Call-ID: 332AEF3F-680511E3-B40DAAE4-A8699C08@10.97.1.150
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1387472160
CSeq: 103 BYE
P-RTP-Stat: PS=1461,OS=226740,PR=1515,OR=242400,PL=0,JI=0,LA=0,DU=28
Content-Length: 0
1195870: Dec 19 16:56:01.078: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195871: Dec 19 16:56:01.078: //2509944/5C225C000001/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
1195872: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Info/sipSPISendBye: Associated container=0x4F7A3900 to Bye
1195873: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
1195874: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
1195875: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Transport/sipSPITransportSendMessage: msg=0x4FC8E374, addr=208.29.69.6, port=5060, sentBy_port=0, local_addr=10.97.1.150, is_req=1, transport=1, switch=0, callBack=0x0
1195876: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1195877: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1195878: Dec 19 16:56:01.082: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:208.29.69.6, rport:5060 with laddr:10.97.1.150
1195879: Dec 19 16:56:01.082: //2509944/5C225C000001/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4FC8E374
1195880: Dec 19 16:56:01.082: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4FC8E374, addr=208.29.69.6, port=5060, local_addr=10.97.1.150, connId=3 for UDP
1195881: Dec 19 16:56:01.082: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1195882: Dec 19 16:56:01.082: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1195883: Dec 19 16:56:01.082: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1195884: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK167A0E118 from via branch list
1195885: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
1195886: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
1195887: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:-1983998754 ConnTime -1984001717
1195888: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Media/sipSPIDestroyRtpSession: stream:48F44A60
1195889: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/State/sipSPIChangeState: 0x4F480A30 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
1195890: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4F480A30
TCP Sockets Used         : NO
Called Number            : 9492552601
Destn SIP Req Addr:Port  : 208.29.69.6:5060
Destn SIP Resp Addr:Port : 208.29.69.6:5060
Destination Name         : 208.29.69.6
1195891: Dec 19 16:56:01.086: //2509944/5C225C000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711ulaw
Source IP Port    (Media): 19422
Destn  IP Address (Media): 208.29.69.22
Destn  IP Port    (Media): 64466
1195892: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Call/sipSPICallInfo:
1195893: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C78
1195894: Dec 19 16:56:01.090: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850256] removed.
1195895: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
1195896: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F480A30 key=332AEF3F-680511E3-B40DAAE4-A8699C08@10.97.1.150
1195897: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1195898: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1195899: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/ccsip_offer_ans_delete:
1195900: Dec 19 16:56:01.090: //2509944/5C225C000001/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4F480A30
1195901: Dec 19 16:56:01.090: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1850256]
1195902: Dec 19 16:56:01.130: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Timestamp: 1387472161
CSeq: 103 BYE
Content-Length: 0
1195903: Dec 19 16:56:01.614: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [208.29.69.6]:5060, local_address:[10.97.1.150]
1195904: Dec 19 16:56:01.614: //2509942/3310B0F5B407/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 264C76
1195905: Dec 19 16:56:01.614: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850254] removed.
1195906: Dec 19 16:56:01.614: //2509942/3310B0F5B407/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Requesterm mon
1196229: Dec 19 16:56:05.874: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1850183] removed.
1196230: Dec 19 16:56:05.874: //2509756/D288BE10B36F/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
1196231: Dec 19 16:56:05.874: //2509756/D288BE10B36F/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4F44F428 key=D28C6700-680311E3-B375AAE4-A8699C08@10.97.1.150
1196232: Dec 19 16:56:05.874: //2509756/D288BE10B36F/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be frinal no monitor
1196233: Dec 19 16:56:05.874: //2509756/D288BE10B36F/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1196234: Dec 19 16:56:05.874: //2509756/D288BE10B36F/SIP/Info/ccsip_offer_ans_delete:
1196235: Dec 19 16:56:05.874: //2509756/D288BE10B36F/SIP/Info/sipSPIUfreeOneCCB: Freeinal no monitor
COLO-2811-VG#un all
All possible debugging has been turned off
COLO-2811-VG#
Re: CUBAC 8.6.2.11 one way audio with specific carrier
Hi Alan,
From the logs it seems SDP size is keep on changing in call-leg , which cause Midcall reinvite packets.
1184646: Dec 19 16:55:11.154: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 244, curr send SDP size =256
1184649: Dec 19 16:55:11.154: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)
1184663: Dec 19 16:55:11.158: //2509931/28013998B3FF/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
1184675: Dec 19 16:55:11.162: //2509931/28013998B3FF/SIP/State/sipSPIChangeState: 0x4F449C60 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
1185827: Dec 19 16:55:14.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 256, curr send SDP size =244
1188165: Dec 19 16:55:24.286: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 244, curr send SDP size =256
1190161: Dec 19 16:55:26.682: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 291, curr send SDP size= 192
I dont know why this is this happeing , unless some SIP expert from this forum put thier view on this discussion.
Manish
Rate all the helpful post.
