CUBAC contact Details sync with Telephone Number in LDAP
I am currently running CUBAC 8.6 and I am wondering if this scenario would be possible.  I am currently syncing users on CUBAC via LDAP and I see the users and their correct extension.
Customer is requesting that the operator see the telephone number that is in the telephone number field in Active Directory which is their 10 Digit DID.  this is so that she can have an easy way to look up this DID from the console directly.  Is there any way to populate this field over to the Operator Console?
I did attempt at using the directory rule, where telephone number attribute seems to be an option, but I never was able to see anything populate the contact details once the operator logs in.
Directory rules are ways of filtering so you do not import certain contacts.
In order to acheive this you would need CUEAC, this allows you to add field mappings unlike CUBAC.
622
