CUBE and BE3k
Hey guys,
First time with cube for me. Trying to configure cube with be3k to the service provider.
Please share some sample config for CUBE.
Varadarajan.R
Everyone's tags (6)
2 ACCEPTED SOLUTIONS
CUBE and BE3k
Hi Varadarajan,
you are missing few important configs like, binding media and signaling interfaces, inbound & outbound dialpeers to and from CUCM & ITSP.
Also check with your provider about the codec the support and how many digits the called number to be sent to ITSP. and configure translation rules if needed
Please have a look at the post from Deji (aokanlawon):
https://supportforums.cisco.com/message/4117173#4117173
it would help you to understand the CUBE config.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
CUBE and BE3k
what transport protocol does your ISP expect UDP or TCP?
Please spesify in your dialpeer that as well:
(config-dial-peer)#session transport ?
  system  defer to voice service voip session transport
  tcp     Transport Layer Protocol - TCP
  udp     Transport Layer Protocol - UDP
I see in your traces the following:
Here is tries via UDP:
Sent:
INVITE sip:14089217525@125.22.86.19:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.1.10:5060;branch=z9hG4bK1835
To: <14089217525>
Date: Thu, 09 Jan 2014 09:29:27 GMT
Call-ID: 5E8BDBBE-784711E3-852884E5-8465EDA2@172.16.1.10
Here it tries via TCP:
Received:
ACK sip:14089217525@172.16.1.10:5060 SIP/2.0
Via: SIP/2.0/TCP 172.16.1.2:5060;branch=z9hG4bK2cd43d97d3cc
From: <5501>;tag=36932~43a596bc-8a16-4858-b2e2-3b8931e63a9c-17094314
To: <14089217525>;tag=33AFCF40-2005
Date: Thu, 09 Jan 2014 09:39:41 GMT
Call-ID: f562f200-2ce16e5d-2c8d-20110ac@172.16.1.2
So it seems to me you are sending UDP and your ISP is answering in TCP.
Voice CCIE #37771
CUBE and BE3k
I have a fee basic config on the cube. i am getting the following error right now for debug
Router#
*Jan  8 17:06:02.012: //-1/8F7E58000000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=5501
   ----- ccCallInfo IE subfields -----
   cisco-ani=5501
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=14089217525
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Jan  8 17:06:02.012: //-1/8F7E58000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8A4912A4, Call Info(
   Calling Number=5501,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User,        Passed, Presentation=Allowed),
   Called Number=14089217525(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T        RUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS        E), Call Id=124
*Jan  8 17:06:02.012: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jan  8 17:06:02.012: :cc_get_feature_vsa malloc success
*Jan  8 17:06:02.012:  cc_get_feature_vsa count is 1
*Jan  8 17:06:02.012: :FEATURE_VSA attributes are: feature_name:0,feature_time:2        343578488,feature_id:18
*Jan  8 17:06:02.016: //124/8F7E58000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5501(TON=Unknown, NPI=Unknown, Screening=User, Passe        d, Presentation=Allowed),
   Called Number=14089217525(TON=Unknown, NPI=Unknown))
*Jan  8 17:06:02.016: //124/8F7E58000000/CCAPI/cc_process_call_setup_ind:
   Event=0x8B2E5360
*Jan  8 17:06:02.016: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 14089217525
*Jan  8 17:06:02.016: //124/8F7E58000000/CCAPI/ccCallSetContext:
   Context=0x882E3C6C
   >>>>CCAPI handed cid 124 with tag 0 to app "_ManagedAppProcess_Default"
*Jan  8 17:06:02.020: //124/8F7E58000000/CCAPI/ccCallProceeding:
*Jan  8 17:06:02.020: //124/8F7E58000000/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca        use=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Jan  8 17:06:02.028: //124/8F7E58000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8A4912A4, Tag=0x0, Call Id=124,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Jan  8 17:06:02.028: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan  8 17:06:02.028: :cc_free_feature_vsa freeing 8BB02B70
*Jan  8 17:06:02.028:  vsacount in free is 0
*Jan  8 17:06:02.028: //124/8F7E58000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x8B6E1180
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 5501
Called Number            : 14089217525
Source IP Address (Sig  ): 172.16.1.10
Destn SIP Req Addr:Port  : 172.16.1.2:5060
Destn SIP Resp Addr:Port : 172.16.1.2:42971
Destination Name         : 172.16.1.2
*Jan  8 17:06:02.028: //124/8F7E58000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.16.1.10
Source IP Port    (Media): 16418
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 1
Disconnect Cause (SIP)   : 404
CUBE and BE3k
Can we see your cube config and dial-peer as well?
Voice CCIE #37771
Re: CUBE and BE3k
Hi Hermanus,
Please find attached.
Re: CUBE and BE3k
hostname Router
boot-start-marker
boot system flash:c880voice-universalk9-mz.153-3.M1.bin
boot-end-marker
aqm-register-fnf
enable password cisco
no aaa new-model
memory-size iomem 10
no ip domain lookup
ip cef
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  referto-passing
  asserted-id pai
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
voice class codec 1
codec preference 1 g729r8
voice class h323 1
voice class sip-profiles 1
license udi pid CISCO881G-G-K9 sn FGL1602G
license boot module c880-iad level advipservices
username admin privilege 15 password 0
username cisco privilege 15 password 0
controller Cellular 0
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 172.16.1.10 255.255.0.0
duplex auto
speed auto
interface Cellular0
no ip address
encapsulation ppp
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
         no ip http secure-server
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 1 mtp
codec g729r8
maximum sessions software 20
shutdown
dial-peer voice 2 voip
destination-pattern 9.T
session protocol sipv2
session target ipv4:125.22.XX.XX
voice-class sip early-offer forced
dtmf-relay rtp-nte
no vad
dial-peer voice 1 voip
session target ipv4:172.16.1.2
incoming called-number 55..
dtmf-relay h245-alphanumeric
CUBE and BE3k
Hi Varadarajan,
CUBE and BE3k
I have this right now. Still no luck.
voice service voip
ip address trusted list
  ipv4 125.22.86.19 255.255.255.255
  ipv4 172.0.0.0 255.0.0.0
sip
  header-passing
  error-passthru
  referto-passing
  asserted-id pai
  early-offer forced
voice class codec 1
voice class h323 1
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
interface Cellular0
no ip address
encapsulation ppp
interface Vlan1
no ip address
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.1
control-plane
codec g729r8
shutdown
dial-peer voice 200 voip
dtmf-relay rtp-nte
dial-peer voice 100 voip
destination-pattern 1408.......
voice-class sip bind control source-interface FastEthernet4
voice-class sip bind media source-interface FastEthernet4
dtmf-relay rtp-nte
CUBE and BE3k
could you please post 'debug ccsip message & debug voice ccapi inout' with calling party & called party details?
incoming calls are working?
Re: CUBE and BE3k
There is no incoming. just outgoing. calling: 5501 called 14089217525
Varadarajan.R
CUBE and BE3k
There is no inbound dial-peer from CUCM to CUBE and hence the call is matching default dial-peer 0.
the outbound dialpeer matched to 100 and the early offer invite message is sent from GW to your provider with G729 codec in the SDP.
however the provider is not responding to your invite and hence the invite message is sent for 6 more times without any success.
Perhaps the ITSP IP address: 125.22.86.19 you are sending the call to is either down or wrong.
Please talk to your provider and ask them why they are not responding the call.
Also confirm the codec the support and the calling & called number format.
CUBE and BE3k
Also what codec is your ISP expecting from you?
I see you have a voice class codec set for g729r8 but you do not use it on the voip dial peer and also it seems like the SIP trunk between you and the ISP is not up from the debug, there is also no codec negotation between you and the ISP.
Please sent what sureshsub2 has asked for.
Voice CCIE #37771
Re: CUBE and BE3k
i have set it now. ISP wants g729. I have attached the logs.
Varadarajan.R
CUBE and BE3k
Sent:
To: <14089217525>
Received:
Voice CCIE #37771
Re: CUBE and BE3k
Thanks a lot for the kind inputs Suresh and Hermanus. I will contact ISP and get back.
Varadarajan.R
Re: CUBE and BE3k
Hey,
I spoke to the ISP. We have the CUBE inside LAN. And the call has to go thru the firewall. Should we do something on the firewall as well ? Because ISP says your initiater IP should be the public address. Do we need to do something for this ?
Varadarajan.R
CUBE and BE3k
Yes you need to point your SIP traffic to the ISP SIP address.
So yes on the FW you will need to make changes to allow the SIP traffic and RTP traffic bi directional.
session target ipv4:(ISP IP address:5060)
session transport (UDP/TCP)
dtmf-relay rtp-nte
Voice CCIE #37771
CUBE and BE3k
you should bind the interface where your public ip is configured for media & signalling. make sure the TCP/UDP 5060 port is opened in the firewall.
http://www.cisco.com/en/US/docs/ios/12_2/12_2x/12_2xb/feature/guide/ftbind.html#wp1024644
CUBE and BE3k
Its working. Thanks a lot guys. The International carrier was rejecting UDP. They shifted to one more carrier. Earlier the ISP had allowed the wrong address of our end. We also had to disable early offer.
Varadarajan.R
VIP Super Bronze
CUBE and BE3k
Suresh and Hermanus (+5) for the great work on this forum..Suresh I love your contributions on SIP..Well done.
I wrote a blog on binding signall and media for CUBE..I am sure its nothing new to both of you, but just thought I should let you guys see it, just in case you find it useful..
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony/blog/2013/04/04/cube-sip-media-and-signalling-binding-to-an-interface
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
353
