CUBE and Transcoding
Hello all,
I wanted to configure a CUBE to do transcoding on the box so I put together this config from various docs on CCO:
interface GigabitEthernet0/1
ip address 10.212.1.7 255.255.255.0
duplex full
speed 100
no mop enabled
h323-gateway voip interface
voice-card 0
dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/1
sccp ccm 10.212.1.7 identifier 1 priority 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register XCODE123456
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
maximum sessions 10
associate application SCCP
telephony-service
ip source-address 10.212.1.7 port 2000
sdspfarm units 1
sdspfarm transcode sessions 10
sdspfarm tag 1 XCODE123456
network-locale GB
create cnf-files version-stamp 7960 Jul 07 2008 14:42:17
max-conferences 8 gain -6
transfer-system full-consult
The problem is that the transcoder is not registering. Here is the Show SCCP output:-
cube-1#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.212.1.7, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.212.1.7, Port Number: 2000
Priority: 1, Version: 3.1, Identifier: 1
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 20, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Any ideas?
2 ACCEPTED SOLUTIONS
Re: CUBE and Transcoding
To do the local registration of transcoding for CUBE/IP2IP gateway, you need to register to the local IP address using SCCP version 5 as previously advised. The other critical setting you need is to define a 'max-dn' and a 'max-ephone' under the telephony service, otherwise the registration won't work.
Here is a working config (IOS is 12.4.15T5). It may take around 60 seconds for the transcoder to register.
interface fastEthernet0/0
ip address 10.66.75.13 255.255.255.128
voice-card 0
dspfarm
sccp local fastEthernet0/0
sccp ccm 10.66.75.13 identifier 1 version 5.0.1
sccp
sccp ccm group 1
keepalive retries 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
maximum sessions 10
no shutdown
telephony-service
ip source-address 10.66.75.13 port 2000
sdspfarm units 1
sdspfarm transcode sessions 2
max-dn 2
max-ephone 1
create cnf
RTA-Test#sh sccp
Gateway IP Address: 10.66.75.13, Port Number: 2000
IP Precedence: 5
Call Manager: 10.66.75.13, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.66.75.13, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
RTA-Test#
VIP Super Bronze
Here is a working config that used version 4.0....Though this was used for conferencing, I believe the config is similar...
You need to use a version higher than 3.3...Below is the config
sccp local FastEthernet0/0
sccp ccm 10.66.75.79 identifier 1 version 4.0
sccp
sccp ccm group 1
associate profile 2 register confprof2
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
no shutdown <----- need to manually add the no shut after the profile has been created
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 3
sdspfarm unregister force
sdspfarm tag 2 confprof2
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
The version command is missing on your sccp config...Depending on the callmanager version you are using..if you are using ccm 6 use ver 5.0.1 or do version ? to see the versions supported by your voice gateway
example below:
sccp local GigabitEthernet0/0.33
sccp ccm 10.33.2.20 identifier 11 version 5.0.1
sccp ccm 10.33.2.21 identifier 10 version 5.0.1
sccp
I think you may have missed my point. I want to do transcoding on the box, in otherwords the transcoding service needs to register with the telephony-service on the box not with a CUCM5 or 6.
I've added this line:-
sccp ccm 10.212.1.7 identifier 1 priority 1 version 3.3
but transcoding is still down. Incidentially, I can't go any higher that 4.1 with the version command. I'm a 2821 running c2800nm-adventerprisek9_ivs-mz.124-19b.bin.
Bronze
Can you send debugs of the following? Hope it's not yet into production network.
"debug dspfarm" & "debug sccp" and then do "no dspfarm" & "dspfarm" to get registration details from beginning again.
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Thanks for the reply.
I am unable to perform a debug dspfarm - its not a valid command in this IOS. Attached is a debug sccp.
Let me know what you find?
voice-card 0
dspfarm
sccp
sccp ccm group 1
keepalive retries 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
maximum sessions 10
no shutdown
telephony-service
sdspfarm units 1
max-dn 2
max-ephone 1
create cnf
RTA-Test#sh sccp
IP Precedence: 5
RTA-Test#
VIP Super Bronze
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
telephony-service
sdspfarm units 3
Thanks all. I downgraded from 12.4-19b to 12.4-15(T5) and the keyword 5.0.1 appeared.
Thanks for your help, transcoders are now registered.
VIP Super Bronze
csg,
No rating for all the work the guys put in here for you!!!!
Of course you deserve a rating - the delay was my overjoyment in getting this working - thanks very much! :)
2945
