CUBE Carrier Issue
Cutover a customer to a SIP trunk (CUBE) and everything is working fine. You can make outbound calls ok, inbound calls ok. BUT for some reason when a Verizon customer that is local to the area calls this number they will get a busy signal. All the other carriers work ok, Sprint, AT&T, Cricket etc. I tried calling from a remote Verizon area and it works fine...it seems to be only this Verizon carrier in that town. I did both a "debug voice cc inout" and "debug ccsip message". I can see the call hit the gateway fine and negotiate at g.729. The error I am getting from the CUBE router is "SIP/2.0 400 Bad Request - 'Malformed/Missing FROM: field".
Does anyone know what this means? I tried sending a call with 0000000 as the calling party but it rang through correctly. Below is the debug
v=0
o=CiscoSystemsSIP-GW-UserAgent 5572 7029 IN IP4 10.200.131.42
s=SIP Call
c=IN IP4 10.200.131.42
t=0 0
m=audio 17136 RTP/AVP 0 18
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
Jun 29 16:26:55: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 400 Bad Request - 'Malformed/Missing FROM: field'
Reason: Q.850;cause=100
Date: Mon, 29 Jun 2009 21:26:55 GMT
From: "IS TECH,SUPPORT" <sip:1234567890(CALLING PARTY)@10.200.131.42>;tag=48C96BD4-D5E
Allow-Events: presence
Content-Length: 0
To: <sip:1234567890(CALLED PARTY)@10.10.5.2>;tag=298619248
Call-ID: 6771D943-642A11DE-9969B8BB-EF9CC056@10.200.131.42
Via: SIP/2.0/UDP 10.200.131.42:5060;branch=z9hG4bK6B91408
CSeq: 101 INVITE
1 REPLY
Silver
Re: CUBE Carrier Issue
From: "IS TECH,SUPPORT" <1234567890>;tag=48C96BD4-D5E
Try to modify the name associated with “from” party so that it does not contain a comma. This would need to be done at the originating device.
174
