ā12-14-2013 06:00 PM - edited ā03-16-2019 08:52 PM
Could someone help me figure out the difference between using "Destination URI" vs the "Incoming URI" command to match a dialpeer?
Which would take precedence if there are two dialpeers, one with destination uri and other with Incoming URI but they both match the same INVITE?
Kamran
Solved! Go to Solution.
ā12-14-2013 07:55 PM
Incoming URI would match as it has superceeded incoming called-number as the most most preferred match criteria.
Destination URI is used for outgoing call leg matching; however, it would be interesting to know if it can work on incoming as a fourth-tier matching criteria (behind URI, incoming called-number, and answer address) as destination-pattern does. The command reference guide doesn't specify and it's not directly related to your question anyways. I'm off on an acedemic tangent now.
Please remember to rate helpful responses and identify helpful or correct answers.
ā12-15-2013 07:36 AM
Hi Jonathan,
Thanks a lot, the world makes sense now
I tested that but as far as I can see, the destination URI does not work on the incoming dial-peer selection....but ill test more extensively later.
On another note on the same tangent destination uri looks a bit useless to me. Reason:
most deployments I have seen are where the CUBE has address hiding between two separate sip domains. invites from both sides coming with the INVITE header as the CUBE interface. Since its two domains, easiest would have been to match the HOST part of the "TO" field and choose the outbound dial-peer. 2 dialpeers for all outbound connections - simples! not so much:
Inbound uri is powerful enough for us to select the "TO" fieldhost instead of choose the inbound dial-peer. But the destination uri dial-peer on the other hand can only look at the "INVITE" header which is useless since it will always be the CUBE. IF we have to use the user part of the INVITE header, we might as well use the destination-patter. So we are forced to use the destination pattern or some prefix from CUCM to have simpler dial-peers...
Or is would you know of a better way to do this?
Thanks!
ā12-16-2013 06:26 AM
It may not be relevent to your config but I wouldn't call it useless. Some customers use CUBE for B2B or other Internet-based calling. An example of this would be CUBE in the DMZ configured to route TO:*@businesspartner.example. There are many different use cases for CUBE beyond PSTN connectivity.
Use incoming URI for inbound dial-peer and destination-pattern for outgoing dial-peer matching.
ā01-17-2014 02:11 AM
p.s just wanted to update here that routing using destination uri-to matching will be available starting IOS 15.4.1T or IOS-XE 3.11. Exactly what we need!:
p1-CUBE-POD1(config)#dial-peer voice 1 voip
p1-CUBE-POD1(config-dial-peer)#destination ?
calling Match destination calling number
dpg Configure voice class dpg
e164-pattern-map Configure voice class to match destination e164-pattern-map
provision-policy Configure voice class dial-peer provision-policy
route-string Match destination route-string
uri Configure voice class to match destination URI
uri-diversion voice class uri to match sip diversion header
uri-from voice class uri to match sip from header
uri-referred-by voice class uri to match sip referred-by header
uri-to voice class uri to match sip to header
uri-via voice class uri to match sip via header
p1-CUBE-POD1(config-dial-peer)#destination uri
p1-CUBE-POD1(config-dial-peer)#destination uri-to
