CUBE DTMF Issues
I am having issues with DTMF on a CUBE running SIP.  I see the send and recv DTMF events in the debugs but CVP/VXML is not recognizing them.
Here is the Call Flow.
Note:  The VXML Gateway is co-resident with the CUBE
AT&T --> ACME Packet --> CISCO CUBE --> CVP/VXML
When calling our test number I get the VXML prompts, but it does not respond to the DTMF digits.  I am no DTMF master by any means, but I did see this in the SDP information in the SIP debug.
From the AT&T/ACME side they are advertising payload type 100.
This is on the CUBE.  INVITE from the ACME device
Received:
INVITE sip:000004153571057@10.251.125.7:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.251.125.10:5060;branch=z9hG4bKp17a1n20d8t0lhsit6a0.1
MIME-Version: 1.0
Supported: 100rel, timer
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Accept: application/sdp
Accept: application/isup
Accept: application/dtmf
Accept: application/dtmf-relay
Accept: multipart/mixed
Privacy: none
P-Asserted-Identity: sip:6515877753@10.251.125.10
From: sip:6515877753@10.251.125.10:12377;tag=91897815896212_c1b05.1.2.1328540005065.0_612_1942
To: sip:8884575821@10.251.125.7:5060
Call-ID: 9780393124487073 - FROM ACME@135.44.230.14
Max-Forwards: 65
CSeq: 2 INVITE
Content-Type: application/sdp
Content-Length: 321
Contact: <sip:10.251.125.10:5060;transport=tcp>
Min-SE: 1800
v=0
o=Sonus_UAC 1104153114 27014 IN IP4 10.251.125.10
s=SIP Media Capabilities
c=IN IP4 10.251.125.10
t=0 0
m=audio 16480 RTP/AVP 18 0 110 100
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:110 G726-32/8000
a=rtpmap:100 telephone-event/8000
a=fmtp:100 0-15
a=sendrecv
a=maxptime:30
All of the internal invites from the CUBE, CVP and VXML show payload type of 101
v=0
o=CiscoSystemsSIP-GW-UserAgent 6907 75 IN IP4 10.251.125.7
s=SIP Call
c=IN IP4 10.251.125.7
t=0 0
m=audio 30856 RTP/AVP 18 0 101
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Attached is the show run from the CUBE and debugs from a call.
Everyone's tags (3)
CUBE DTMF Issues
hi Ryan ,
The CUBE is using 101 payload type as this is  default for NTE ( which you have set specifically
under the dial-peers with command "dtmf-relay rtp-nte")
As  dynamic payload interworking is enabled by default on the CUBE. In this  mode, CUBE will perform the interworking from 100 to 101 and vice  versa.
Use the command "asymmetric payload full"  in your configuration, CUBE will be on pass thru mode i.e. dynamic  payload types are passed across from one call leg to other leg and no payload-type interworking is done at CUBE.
You can read more about this in this link :
http://www.cisco.com/en/US/docs/ios/ios_xe/voice_cube_-_ent/configuration/guide/vb_10022_xe.pdf
Hope this helps!
Karthik
CUBE DTMF Issues
Thanks for the Reply Karthik.
I implemented the commands, but that did not work for me.
I did find the issue though.  They were missing the Call.user.microapp.input_type variable set to D in the ICM script.  I added that in and its working now.
CUBE DTMF Issues
That fixed my DTMF issue, thanks!
2556
