Community Member
CUBE for multiple SIP trunking
Hi Experts
can i a  use common CUBE infra for multiple customer SIP trunking requirements. For eg i want to deploy only a single CUBE router on my side with different loopbacks which in turn connect to different customer CUBE devices
Everyone's tags (1)
1 ACCEPTED SOLUTION
Yes, as  explained in one of
Yes, as  explained in one of the posts that i mentioned
You will then need to use your sip bind commands at the dial-peer level. E.g
interface loopback1----------------------------------------Interface pointing to SIP provider 1
ip address 10.10.10.1 255.255.255.0
interface loopback2-----------------------------------------Interface pointing to SIP provider 2
ip address 20.20.20.1 255.255.255.0
dial-peer voice 10 voip
description “Primary path to SIP SP-1”
destination-pattern 91[2-9]..[2-9]......
session protocol sipv2
session target ipv4:10.10.10.2
voice-class sip options-keepalive
voice-class sip bind control source-interface loopback1
voice-class sip bind media source-interface loopback1
dial-peer voice 20 voip
description “Secondary path to SIP SP-2”
session target ipv4:20.20.20.2
preference 2
voice-class sip bind control source-interface loopback2
voice-class sip bind media source-interface loopback2
If your DDIs are provisioned differently on these providers, you will need to use sip profiles to authenticate before you will be allowed to place outbound calls through them.
Manish
Hi,Multiple SIP trunks
Multiple SIP trunks terminating on same CUBE is possible. Please check the following posts for details
https://supportforums.cisco.com/discussion/11734001/cisco-cube-multi-sip-trunks
https://supportforums.cisco.com/discussion/10556546/multiple-sip-trunks-single-cube
Manish
Community Member
Manishi do not have multiple
Manish
i do not have multiple SIP trunks . Here is a sample topology of what i plan to do
Will this work
preference 2
Manish
809
