CUBE H323 to H323 Advice
Hi There,
I wonder if someone could give me some advise on the best way to configure a CUBE which is currently not working as expected, I have a CUCM cluster v5.x and a pair of CUBEs (configured as H323 gateways) connected via H323 (non gatekeeper) trunk to a service provider.
The problem i have is that on outbound calls I can setup a call and can see Tx and Rx packet counts going up on the ip phones but have no audio.........
I believe the problem is to do with MTP and I will need to configure MTP resources locally on the CUBE and terminate the 2 legs of the calls on the CUBE as the service provider's prefered codec is G729 I don't believe local (CUBE) transcoding is required.
My question is firstly has anyone done anything like this and is willing to share configuration, and secondly does this seem to be the correct route of investigation or am I missing something and should be concenrating else where?
Thanks in advance
Ellis
Hall of Fame Super Silver
You should not be needing any MTPs for this type of setup. Can you elaborate on your topology and what type of circuit is the telco providing? Is it a SIP trunk?  Posting configuration would be helpful. Is your Region between the phone and CUBE configured to use G729?
How is routing performed, are you using NATing anywhere?
Chris
Re: CUBE H323 to H323 Advice
Hi Ellis,
Check that RTP addresses are correct on both legs in show call history voice command output. Also check the rx and tx bytes count on both legs if media flow-through is configured.
MTP is not needed. Below is my config for calls between H.323 device and SIP
SBC2#sh run | sec voice service voip
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
supplementary-service media-renegotiate
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback pass-through g711alaw
h323
  no call service stop
  bearercap-ie signaling-only standard
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  referto-passing
  source filter
  midcall-signaling passthru
  g729 annexb-all
SBC2#
dial-peer voice 2002 voip
permission orig
description #-- Incoming from Infinity
translation-profile incoming DP-FROM-INFINITY
huntstop
voice-class codec 1
incoming called-number ^DACCBA#.T
dtmf-relay rtp-nte digit-drop
dtmf-interworking rtp-nte
fax protocol pass-through g711alaw
no vad
dial-peer voice 2001 voip
permission orig
description #-- Incoming from GLDN
translation-profile incoming DP-FROM-GLDN
huntstop
voice-class codec 1
incoming called-number ^AACBAD#.T
no vad
dial-peer voice 201 voip
permission term
description #-- UA numbers pool 1
huntstop
preference 2
destination-pattern +3804422214[4,5][0-9]$
voice-class codec 1
session target ipv4:10.38.10.10
dtmf-relay h245-signal
dial-peer voice 38 voip
permission term
translation-profile outgoing TO-GLDN
huntstop
destination-pattern +38..........$
voice-class codec 38
session protocol sipv2
session target ipv4:89.162.254.10
dtmf-relay rtp-nte
no vad
Maxim
did you check the routing from the Gateway to the phones if it works in both directions ?
729
