CUBE HA Behavior
Hi all,
I have just configured two isr 39xx as cube and both in HA following the configuration guide in the following link
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080b40d82.shtml
after configured everything works perfect, but customer want to use the second router DSP resources for transcoding while first router is active, my problem is that after i enable the HA with the redundancy inter-device the second isr dsp resources go unregistered, i wonder if this is the way it should work or if there is a possibility to utilize the second ISR DSP Resources while first router is active.
i was able to chech the sccp configurations and the sccp protocol up and running on the second ISR but still not getting registered.
thanks,
Everyone's tags (4)
CUBE HA Behavior
On the second router, how is your DSP resources configured. Have you created a loopback IP Address on that and tried to bind the DSP resources to the loopback instead of gig interface ?
CUBE HA Behavior
Hi, thanks for you answer, i have both routers binding sccp traffic to lan interface which of course is included in the hsrp configuration, i'll try a loopback to see what happens, thanks again!!
237
