Community Member
CUBE HA with NEXUS vPC
Hi all,
I want to get a pair of CUBE with HA (which required HSRP configuration), connected to a pair of Nexus 5596UP
The design and configuration for CUBE HA is described on the document at this link  http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html
Each Cisco CUBE I have has a link to each Nexus 5596UP so I was thinking on creating a L3 Etherchannel on the CUBE and a vPC on the Nexus with access to a VLAN in order to accomplish the HRSP needed on the CUBEs (take a look at my design).
Please let me know if you have done this design and configuration and how you did it.
I think you can post this
I think you can post this question on routing switching section as well , experts there have better suggestion related to port channel and hsrp.
Community Member
Thanks for the suggestion, I
Thanks for the suggestion, I have the same post on Datacenter Forum but will do Routing as well.
108
