Community Member
CUBE + IOS Requirements
We're new to CUBE implementation and planning a UCM6.1(3) cluster integration to a SIP-SIP CUBE gateway. We're appear to be borderline on the IOS flash requirements for 12.4(15)T and I wanted to know if CUBE capabilities are built into the flash requirements of 64MB, or if it increases the minimum.
Also considering going to 12.4(20)T for the improvements to CUBE and voice quality and troubleshooting tools. This IOS requires 128MB flash, so I have the same general questions, and would like any recommendation people have had using either one of these IOS versions.
Thanks in advance,
Brian
1 ACCEPTED SOLUTION
Re: CUBE + IOS Requirements
If you're using SIP I highly recommend 12.4(20)T or later. There were a great deal of fixes between 12.4(15)T and 12.4(20)T.
-nick
VIP Super Bronze
I believe you can run CUBE ob 12. 4(15)T. Just make sure you haveIP/enterprise voice features. I have CUBE running in my lab and my IOS is not lower than 12.4(15)T
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
-nick
Community Member
I suspected 12.4(20)T was the route to go. Thanks!
Community Member
CUBE does not inherently impact your flash requirements. The size of the IOS image does though, so 12.4.20T is larger than 12.4.15T images. For CUBE functionality you need at least IP Voice, and for some of the more sophisticated features you need the IVS or AVS images. Make sure your flash is sized for these releases/images, then CUBE itself (its feature or configuration) does not add any further requirements.
Community Member
The first sentence was exactly what I was looking for. Coupled with the previous post on recommending 12.4(20)T I'm good to go.
Thanks!
Community Member
Thanks!
482
