CUBE not passing back SIP authentication
All,
I am attempting to setup CUBE and the piece I cannot figure out is how to get CUBE to passback the authentication from the registrar server.  The IP Phone is sending the initial register, it's received by CUBE and sent to the registrar.  The registrar responds 401 with a challenge that includes the WWW-Authenticate: Digest, but the CUBE sends the 401 to the phone without the WWW-Authenticate.  How do I get that piece working?
Register request from IP Phone:
Jun 15 14:58:06.500 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.1.255.2:5070 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.3;branch=z9hG4bK95b58c109A1CBBA9
From: "ACD 3" <sip:8643350812@10.1.255.2>;tag=EC921466-5483BB0F
To: <sip:8643350812@10.1.255.2>
CSeq: 2 REGISTER
Call-ID: 16211dfb-a136331c-e71d9d5@10.0.0.3
Contact: <sip:8643350812@10.0.0.3>;methods="INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER"
User-Agent: PolycomSoundPointIP-SPIP_331-UA/3.1.3.0507
Accept-Language: en
Max-Forwards: 70
Expires: 3600
Content-Length: 0
CUBE Initial response to phone:
Jun 15 14:58:06.512 EDT: //1312/E04C16F58310/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <sip:8643350812@10.1.255.2>;tag=61DB070-1D9D
Date: Fri, 15 Jun 2012 18:58:06 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 2 REGISTER
Content-Length: 0
CUBE Register request to Registrar:
Jun 15 14:58:06.516 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.2.1.9:5070 SIP/2.0
Via: SIP/2.0/UDP 10.1.255.2:5070;branch=z9hG4bK2391BB8
To: <sip:8643350812@10.2.1.9>
Call-ID: E055DAA6-B65211E1-83129221-D5A7E229
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1339786686
CSeq: 2 REGISTER
Contact: <sip:8643350812@10.1.255.2:5070>
Expires:  3600
Supported: path
Content-Length: 0
Registrar Response w/ challenge:
Jun 15 14:58:06.528 EDT: //1316/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:8643350812@10.2.1.9>;tag=SDr15rb99-590850185-1339786686522
CSeq: 2 REGISTER
WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXh3hmefjuTemqn4BW",realm="BroadWorks",algorithm=MD5
Content-Length: 0
CUBE 401 to Phone w/o Authentication requirements:
Jun 15 14:58:06.536 EDT: //1312/E04C16F58310/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 2 REGISTER
Content-Length: 0
Everyone's tags (5)
Use the following command on your dial-peers:
dial-peer voice 1001 voip
voice-class sip pass-thr headers
And if you are using IOS above 15.1(3), you can use add those commands as well
Router(config)# voice service voip
Router(conf-voi-serv)# sip
Router(conf-serv-sip)# registration passthrough
"If you this post useful, please rate it"
Thanks for the reply.  I am using 15.1(4) and have those commands entered, doesn't appear to help.
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
sip
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  header-passing sip-sip
  registrar server
  listen-port non-secure  5070
By default, the dial-peers should be using the global config settings so shouldn't need the 'sip pass-thru' commands, although I tried that well without success.
Try to remove authentication command under sip-ua menu.
You can study the "Configuring Support for SIP Registration Proxy on Cisco UBE" at this link:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip.html
Regards.
Did you ever get this to work? We are facing the exact same problem.
A 'debug ccsip all' shows some line regarding the SBC believing to operate in 'P2P' mode.
According to the documentation Daniele refered to this means a setup where the SBC handles the authentication by himself?
Unfortunally the examples in the same documentation is not very accurate (non-unique dial-peers, settings defined globally and on DP etc.). It also fails to explain which scenario the configuration example is ment to cover.
No we did not.  The current CUBE model doesn't support Subscribe or Notify pass-through.  Cisco is implementing line side features through a product called Nano CUBE, but I've never worked on it.
5040
