Community Member
CUBE- one way audio intermittent for inbound calls
     Have a CUBE on 3800 with 15.14M(6) with SIP to SIP dial peers. Some external inbound callers at times can hear no audio streaming from IVR.
I run a traffic capture from the LAN side of the CUBE and I can hear the audio.
I run a traffic capture on the WAN side (towards caller) and i hear nothing,  BUT the rtp stream is active (50 pps G711a). When i replay this stream on Wireshark i hear silence exactly what the caller can hear...
G711a on both sides but no audio is heard on the WAN side exiting the CUBE towards telco
DIal peers matched= 31 In from itsp and 40 Out to CUCM
Setup:
ITSP--SIP Trunk-- MyCUBE--SIP Trunk--CUCM--IVR(CTI Ports and RPs)
        7900 Type A sccp Handsets
Config attached
personally I would make the following changes to each dial peer sticking to one dtmf relay form and add the following changes:
dial-peer voice 30 voip
description  Outgoing call leg from CUBE to ITSP
translation-profile outgoing StripZero
destination-pattern 0T
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
voice-class codec 1
dspfarm profile 6 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 24
associate application SCCP
allow-connections sip to sip
allow-connections sip to h323
allow-connections h323 to sip
redirect ip2ip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
Voice CCIE #37771
Community Member
HI,
itsp requires inband dtmf only and G711a
VIP Super Bronze
I can see that you are applying your sip bind statement on loopback5..
sip
  bind control source-interface Loopback5
  bind media source-interface Loopback5
The question is this.Can your ITSP connect to that interface?
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
hi,
Yes my itsp can connect and see that interface. Most calls work and only some fail. Intermittent. I have incuded a "show call active voice" for a "failed" incoming call from 0204002244 to 0498870440 . What happens here is silence to external caller coming in on dial peer 31 but there is an RTP stream being sent to him. Wireshark trace on WAN side proves silence within RTP stream exiting CUBE towards callers SBC at 10.193.202.100 from my cube at 10.66.41.1
GENERIC:
SetupTime=12:24:35.980 AEDT Thu Jan 30 2014
Index=1
PeerAddress=0204002244
PeerSubAddress=
PeerId=31
PeerIfIndex=192
LogicalIfIndex=0
ConnectTime=12:24:36.080 AEDT Thu Jan 30 2014
CallDuration=00:00:43 sec
CallState=4
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=2196
TransmitBytes=351360
ReceivePackets=2194
ReceiveBytes=351040
VOIP:
ConnectionId[0x1D4C7D6F 0x888411E3 0xA9FBFF95 0xBEE5C848]
IncomingConnectionId[0x1D4C7D6F 0x888411E3 0xA9FBFF95 0xBEE5C848]
CallID=5201
GlobalCallId=[0x1D4C7D6F 0x888411E3 0xA9FEFF95 0xBEE5C848]
CallReferenceId=0
CallServiceType=Unknown
RTP Loopback Call=FALSE
RemoteIPAddress=10.193.202.100
RemoteUDPPort=14804
RemoteSignallingIPAddress=10.193.202.100
RemoteSignallingPort=5060
RemoteMediaIPAddress=10.193.202.100
RemoteMediaPort=14804
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=sipv2
ProtocolCallId=BW122550354300114251347680@210.193.202.4
SessionTarget=10.193.202.100
SafEnabled=FALSE
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
TxPakNumber=0
TxSignalPak=0
TxComfortNoisePak=0
TxDuration=0
TxVoiceDuration=0
RxPakNumber=0
RxSignalPak=0
RxComfortNoisePak=0
RxDuration=0
RxVoiceDuration=0
RxOutOfSeq=0
RxLatePak=0
RxEarlyPak=0
RxBadProtocol=0
PlayDelayCurrent=0
PlayDelayMin=0
PlayDelayMax=0
PlayDelayClockOffset=0
PlayDelayJitter=0
PlayErrPredictive=0
PlayErrInterpolative=0
PlayErrSilence=0
PlayErrBufferOverFlow=0
PlayErrRetroactive=0
PlayErrTalkspurt=0
ClockAdjustDuration=0
EarlyPacketDuration=0
LateDiscardDuration=0
SilenceDiscardDuration=0
JBuffDecreaseDuration=0
JBuffIncreaseDuration=0
OutSignalLevel=0
InSignalLevel=0
LevelTxPowerMean=0
LevelRxPowerMean=0
LevelBgNoise=0
ERLLevel=0
ACOMLevel=0
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
SRTP = off
TextRelay = off
VAD = disabled
CoderTypeRate=g711alaw
CodecBytes=160
Media Setting=flow-through
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=0204002244
OriginalCallingOctet=0x0
OriginalCalledNumber=0498870440
OriginalCalledOctet=0x0
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x80
TranslatedCallingNumber=0204002244
TranslatedCallingOctet=0x0
TranslatedCalledNumber=0498870440
TranslatedCalledOctet=0x0
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x80
GwReceivedCalledNumber=0498870440
GwReceivedCalledOctet3=0x0
GwReceivedCallingNumber=0204002244
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x80
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallDetected=no
LongDurCallTimestamp=
LongDurcallDuration=
Username=0204002244
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=
PrecedenceLevel=0 (PRECEDENCE_LEVEL_NONE)
CPA Active Call Parameters
  CPA Event Status: DISABLE
GENERIC:
SetupTime=12:24:35.994 AEDT Thu Jan 30 2014
Index=1
PeerAddress=2440
PeerSubAddress=
PeerId=400
PeerIfIndex=202
LogicalIfIndex=0
ConnectTime=12:24:36.074 AEDT Thu Jan 30 2014
CallState=4
CallOrigin=1
ChargedUnits=0
InfoType=speech
ReceivePackets=4396
ReceiveBytes=703360
VOIP:
CallID=5202
CallReferenceId=0
RemoteIPAddress=10.66.22.20
RemoteUDPPort=31334
RemoteSignallingIPAddress=10.66.22.20
RemoteMediaIPAddress=10.66.21.20
RemoteMediaPort=31334
RoundTripDelay=0 ms
tx_DtmfRelay=rtp-nte
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=1D4DB657-888411E3-AA01FF95-BEE5C848@10.66.41.1
SessionTarget=10.66.22.20
SafEnabled=FALSE
OnTimeRvPlayout=0
TxPakNumber=0
TxSignalPak=0
TxComfortNoisePak=0
TxDuration=0
TxVoiceDuration=0
RxPakNumber=0
RxSignalPak=0
RxComfortNoisePak=0
RxDuration=0
RxVoiceDuration=0
RxOutOfSeq=0
RxLatePak=0
RxEarlyPak=0
RxBadProtocol=0
PlayDelayCurrent=0
PlayDelayMin=0
PlayDelayMax=0
PlayDelayJitter=0
PlayErrPredictive=0
PlayErrSilence=0
PlayErrTalkspurt=0
OutSignalLevel=0
InSignalLevel=0
LevelTxPowerMean=0
LevelRxPowerMean=0
LevelBgNoise=0
ERLLevel=0
ACOMLevel=0
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
SRTP = off
TextRelay = off
VAD = disabled
CodecBytes=160
AlertTimepoint=12:24:36.004 AEDT Thu Jan 30 2014
CallerName=
TranslatedCallingNumber=00204002244
TranslatedCalledNumber=2440
GwOutpulsedCalledNumber=2440
GwOutpulsedCalledOctet3=0x0
GwOutpulsedCallingNumber=00204002244
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x80
Username=0204002244
VIP Super Bronze
My suggestion will be to upgrade the IOS on the CUBE. Since this is intermittent..However I suggest that you enable debug ccsip messages and confrim that for those calls that you are getting silence on, the call path is the same. Ie ensure the the media parameters are the same...If it is the same, then upgrade IOS.
Community Member
Re: CUBE- one way audio intermittent for inbound calls
Yes I agree. Tried 15.1M2 and M7 only so far
822
