CUBE PVDM / DSP Usage
In the context of a CUBE, I know that transcoding and DTMF signaling changes wil invoke DSP resources.  I also assume that stream splitting for call recording applications will also use DSP's.
Are there any other CUBE configurations that will require DSP's?
Thanks.
Everyone's tags (3)
Hall of Fame Super Silver
I believe you covered it, transcoding, transrating, MTP and another one if you decide to use it would be hardware conferencing.
HTH,
Chris
To be clear - media forking
To be clear - media forking for recording does, or does not require DSPs?
I can't find anything that says it does, but also nothing that says it doesn't.
What does the DSP calculator
What does the DSP calculator say?
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
584
