CUBE Routinging with ISDN backup question.
Hi All,
Does anyone have any ideas on the following?
There are two CUBEs with a SIP trunk on each, the second is an SRST gateway with ISDN.
The CUBEs are configured in CUCM as SIP trunks.
Is there a way to try each CUBE (SIP trunk) first the the second CUBE’s ISDN?
Just wondering if there is a way without using MGCP on the ISDN.
If not MGCP it is!
Gus
1 REPLY
VIP Super Bronze
Sure but it depends how the CUBE responds to CUCM during the failure. For example, if you're using Options Ping and CUBE is hard-down, CUCM will see the SIP trunk as down and skip it automatically. If CUBE responds, the SIP response code will decide how CUCM responds. For example, a 500 series error would likely continue searching down the hunt list/line group. If you get a 404 not found, it will depend what the Stop Routing on Unallocated Number Flag service parameter is (True/False). Similarly, a 488 busy would depend on the Stop Routing on User Busy Flag service parameter.
Please remember to rate helpful responses and identify helpful or correct answers.
155
