CUBE SIP header
My setup is CUCM to CUBE to SIP trunk
When i place a call from CUCM im missing a field in my debug
The field DIVERSION is not present
When im looking at debugs form other deployment i do see that field.
What need to be done on CUCM to create that DIVERSION field in the SIP invites ?
Below Debugs without the Diversion field and 2nd debug is the other deployment that has the field.
*Mar  3 19:12:00.817: //129882/FF4D14000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:41655512346@siptrunking.bell.ca:6179 SIP/2.0
Via: SIP/2.0/UDP 172.99.99.99:6179;branch=z9hG4bK10DC150A
From: "Jon Do" <sip:4161112222@cube.enterprise.com;user=phone>;tag=63111EB4-2317
To: <sip:4163334444@172.33.22.11>
Date: Mon, 03 Mar 2014 19:12:00 GMT
Call-ID: 187770F2-A23E1113-8300A51A-DECF6548@cube.enterprise.com
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4285549972-0000065536-0009000027-0141118188
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Timestamp: 1393553920
Contact: <sip:5142225555;tgrp=tor_01_4165145232;trunk-context=siptrunking.bell.ca@172.88.99.99:6179>
Expires: 60
Allow-Events: telephone-event
Authorization: Digest username="xxxxx...
Max-Forwards: 68
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
*Oct 14 00:25:06.327: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17023100500@192.168.1.1:5060 SIP/2.0
Date: Sat, 10 Jul 2010 20:09:26 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: “MARK RAMSAY  ” <sip:4802317040@192.168.1.254>;tag=9fc21ef0-b4f8-4240-a30e-86b6cfa8e8f7-27463414
Allow-Events: presence
P-Asserted-Identity: “RAMSAY MARK  ” <sip:4802317040@192.168.1.254>
Supported: timer,resource-priority,replaces
Supported: Geolocation
Min-SE:  1800
Diversion: “9948″ <sip:9948@192.168.1.254>;reason=unconditional;privacy=off;screen=yes
Remote-Party-ID: “RAMSAY MARK  ” <sip:4802317044@192.168.1.254>;party=calling;screen=yes;privacy=off
Content-Length: 214
User-Agent: Cisco-CUCM7.1
To: <sip:17023100500@192.168.1.1>
Contact: <sip:4802317040@192.168.1.254:5060>
Expires: 180
Call-ID: 8aa2480-c381d376-c6-fe01a8c0@192.168.1.254
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK1b172bdcdc9
CSeq: 101 INVITE
Max-Forwards: 7
Everyone's tags (2)
1 REPLY
CUBE SIP header
The second debug with diversion header shows that the call from 4802317044 has been diverted to 17023100500 due to the reason 'call forward all' enabled on the phone 9948.
If the first one is again the diverted call without diversion header, then check the SIP trunk configuration and there should be a check box to include diversion header.
//Suresh Please rate all the useful posts.
140
