02-15-2018 01:44 AM - edited 03-17-2019 12:12 PM
Hi All,
We are configuring our new SIP Trunk to a Provider. Everything is configure and external calls were working fine but at some point external calls are getting fast busy and only incoming calls are working.
Topology: CUCM-SIP Trunk-CUBE-Sip Trunk - ISTP
Call test: Calling-9521(mask 222679500) Called 0917775245 (0 is striped)
Any ideas what can be causing it...
Please note attached collected debugs calls from and show runs.
Solved! Go to Solution.
02-15-2018 02:48 AM
Hook up with your provider, they are not liking your invite, seeing it has always worked and now it doesnt tells me something has changed on their end.they should be able to tell you want is wrong about your invite
02-15-2018 06:09 AM
02-15-2018 02:48 AM
02-15-2018 05:14 AM
Hi Dennis, Thanks for your replay.
I just got in contact with the Provider and they insist they didn't changed anything from their side and saying they´re not able anything coming from our side when call is placed.
Very strange.
Any ideas....?
02-15-2018 11:13 AM
Thanks so much for your support.
They managed to get it working. I don´t know what they did but calls are working fine now without any action from my side.
Cheers,
02-15-2018 06:09 AM
02-15-2018 11:11 AM
You´re Nipun.
I put some pressure and they managed to get it working. I don´t know what they did but calls are working fine now without any action from my side.
Thanks for your support,
02-15-2018 11:40 AM
02-16-2018 02:07 AM
good work mate. I my 20 years of IT experience: if something breaks it most likely because some one changed something,
