Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CUBE SIP trunk Capacity
I'm having an issue where a CUBE/CUCM SIp trunk wont accept more than 50 calls.  The provider is configured for 100 calls and insists that they are not accidentally throttling down to 50 anywhere.  But I don't see anything in the router or CallManager that is doing this either.  Has anyone ever ran into this kind of issue?
Thanks in Advance,
J
1 REPLY
Hi.Check if in CUCM has been
Hi.
Check if in CUCM has been defined a location limiting the audio bandwidth.
System-->Location
In positive case, verify if that location has been added to a Device pool.
If you have a trace or a debug output go when call exceeding value of 50 is rejected, please attach here
Carlo
Please rate all helpful posts "The more you help the more you learn"
80
