05-24-2014 10:26 AM - edited 03-16-2019 10:53 PM
voice service voip
allow-connections sip to sip
fax protocol cisco
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 1
rule 1 /^8/ /0056/
voice translation-rule 2
rule 1 /5../ /17772114zzz/
voice translation-rule 3
rule 1 /17772114zzz/ /500/
voice translation-profile IN
translate called 3
voice translation-profile OUT
translate calling 2
translate called 1
dial-peer voice 1 voip
description CALLCENTRIC
translation-profile incoming IN
translation-profile outgoing OUT
destination-pattern 8.T
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number 17772114zzz
dtmf-relay sip-notify rtp-nte
dial-peer voice 2 voip
description CUCM
destination-pattern 500
media flow-around
voice-class codec 1
session target ipv4:192.168.10.116
incoming called-number 8.T
sip-ua
credentials username 17772114zzz password 7 094F471B100928 realm callcentric.com
authentication username 17772114zzz password 7 121A0C051B0803 realm callcentric.com
no remote-party-id
registrar dns:callcentric.com expires 3600
sip-server dns:callcentric.com
host-registrar
Solved! Go to Solution.
05-25-2014 07:15 PM
Please configure the below sip profile to remove the Require Header and Apply this profile in the outgoing dial-peer 1.
voice class sip-profiles 1
response 200 sip-header Require REMOVE
if that doesn't work under dial-peers, you may try applying it globally.
voice service voip
sip
sip-profiles 1
//Suresh
Please rate all the helpful posts
05-24-2014 10:58 AM
you may need to create separate Inbound & outbound dial-peers for both incoming & outgoing direction, total of 4 dial-peers.
if the issue persists, could you please collect debug ccsip message & debug voice ccapi inout for a call?
//Suresh
05-24-2014 12:48 PM
Well, actually in the first time I ´ve got 4 dial-peers.
1 inbound from SIP Provider
1 outbound to SiP Provider
1 inbound from CUCM
1 outbound to CUCM
and the problem was the same.
Afterwards I simplify the configuration in 2 dial-peers like I showed in previous post but the same result.
I attached the debugs for an inbound call. Extension 500 (CIPC) rings, I press Answer button but the analog phone at the PSTN keeps listening ring back tone. Finally CIPS ends the call.
I tested this using CME in the router itself. It works perfect for inbound and outbound calls. Obviously in this case dial-peer to CUCM doesn´t exist.
Any ideas to solve this??
Thank you.
05-24-2014 01:11 PM
05-24-2014 03:17 PM
I also tested with a 3CX SIP softphone and the problem was the same. The call forward you see is actually because of a Single Number Reach Configuration, but the problem remains without that functionality. All call legs are using G711ulaw (optimize for low bandwidth disabled).
I have not tried with a physical phone but I use CIPC in a Call Manager Express environment with the same SIP Provider and works great.
I think it is a problem of signaling. When I end the call from the CIPC, el analog phone in the PSTN keeps with ring back tone. When I end the call from the analog phone, CIPS ends the call also. So the signaling to the PSTN is like not passing for an inbound call, but the signaling from the PSTN can pass ok for an inbound call.
Thank you.
05-24-2014 10:35 PM
I checked the attached debugs and seems the issue is with provider side who is not responding to the 200 OK message sent from CUBE.
>> Invite message sent to CUCM
*May 24 15:35:04.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:500@192.168.10.116:5060 SIP/2.0
Date: Sat, 24 May 2014 15:35:04 GMT
Call-Info: <sip:192.168.10.10:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
From: <sip:56222263788@callcentric.com>;tag=C18E38-10E6
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3483623425-3801027043-2167054572-2285343397
Timestamp: 1400945704
Content-Length: 274
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <sip:500@192.168.10.116>
Contact: <sip:56222263788@192.168.10.10:5060>
Expires: 180
Content-Disposition: session;handling=required
Content-Type: application/sdp
Call-ID: CFB9D89B-E28F11E3-8130A0EC-883792A5@192.168.10.10
Via: SIP/2.0/UDP 192.168.10.10:5060;branch=z9hG4bK15A52E
CSeq: 101 INVITE
Max-Forwards: 12
v=0
o=CiscoSystemsSIP-GW-UserAgent 6959 7987 IN IP4 192.168.10.10
s=SIP Call
c=IN IP4 204.11.192.39
t=0 0
m=audio 60992 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
>> 100 Trying received from CUCM
*May 24 15:35:04.563: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CUBE#19:35:19 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
>> 180 Ringing Received from CUCM
*May 24 15:35:04.579: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:500@192.168.10.116>;tag=286~ff02ad80-68cc-4826-be4d-e6d9992b00f8-16971568
Date: Sat, 24 May 2014 19:35:19 GMT
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Call-Info: <sip:192.168.10.116:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Mario Garay CIPT" <sip:500@192.168.10.116>
Remote-Party-ID: "Mario Garay CIPT" <sip:500@192.168.10.116>;party=called;screen=yes;privacy=off
Contact: <sip:500@192.168.10.116:5060>
Content-Length: 0
>> call is answered and received 200 OK for that.
*May 24 15:35:08.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires: 1800;refresher=uas
Require: timer
P-Asserted-Identity: "Mario Garay" <sip:500@192.168.10.116>
Remote-Party-ID: "Mario Garay" <sip:500@192.168.10.116>;party=called;screen=yes;privacy=off
Content-Length: 160
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 192.168.10.116
s=SIP Call
c=IN IP4 192.168.10.116
t=0 0
m=audio 24742 RTP/AVP 0
a=ptime:20
>> CUBE acknowledged the same
*May 24 15:35:08.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:500@192.168.10.116:5060 SIP/2.0
Content-Length: 0
Via: SIP/2.0/UDP 192.168.10.10:5060;branch=z9hG4bK15DD01
CSeq: 101 ACK
Max-Forwards: 70
>> when the CIPC answers the calls, CUCM sent 200 OK message to CUBE and it acknowledged it by sending ACK back to CUCM.
>> now CUBE forwarded the 200 OK message to ITSP but no response from ITSP side.
>> CUBE retried sending the 200 OK message for 4 more times but no response.
>> 1st 200 OK sent to ITSP
*May 24 15:35:08.787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
From: <sip:56222263788@66.193.176.35:5060>;tag=as516768f4
Supported: replaces
Supported: sdp-anat
Content-Length: 250
Require: timer
To: <sip:56225814887@ss.callcentric.com>;tag=C18EC8-55A
Contact: <sip:17772114441@192.168.10.10:5060>
Call-ID: 32559519-3609948918-834417@msw2.telengy.net
Via: SIP/2.0/UDP 204.11.192.39:5080;branch=z9hG4bK-5ed830c214e955b748004295dd4666b7;change=ta
CSeq: 1 INVITE
Server: Cisco-SIPGateway/IOS-12.x
v=0
o=CiscoSystemsSIP-GW-UserAgent 8260 1252 IN IP4 192.168.10.10
s=SIP Call
c=IN IP4 192.168.10.10
t=0 0
m=audio 29258 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
>> 2nd 200 OK sent to ITSP
*May 24 15:35:09.307: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Content-Length: 250
Require: timer
CSeq: 1 INVITE
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
>> 3rd 200 OK sent to ITSP
*May 24 15:35:10.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Content-Length: 250
Require: timer
CSeq: 1 INVITE
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
>> 4th 200 OK sent to ITSP
*May 24 15:35:12.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Content-Length: 250
Require: timer
CSeq: 1 INVITE
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
>> 5th 200 OK sent to ITSP
*May 24 15:35:16.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Content-Length: 250
Require: timer
CSeq: 1 INVITE
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
>> BYE received from CUCM side
*May 24 15:35:12.787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:56222263788@192.168.10.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.116:5060;branch=z9hG4bK98239541cb
From: <sip:500@192.168.10.116>;tag=286~ff02ad80-68cc-4826-be4d-e6d9992b00f8-16971568
To: <sip:56222263788@callcentric.com>;tag=C18E38-10E6
Date: Sat, 24 May 2014 19:35:23 GMT
User-Agent: Cisco-CUCM8.5
Max-Forwards: 70
CSeq: 101 BYE
Content-Length: 0
>> CUBE acknowledge the BYE message
*May 24 15:35:12.863: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Reason: Q.850;cause=16
Date: Sat, 24 May 2014 15:35:12 GMT
Content-Length: 0
CSeq: 101 BYE
>> ITSP sent BYE message to CUBE
*May 24 15:35:16.723: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:17772114441@192.168.10.10:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.39:5080;branch=z9hG4bK-87824e3b093ab808a215b8725b00d465;change=ta
f: <sip:56222263788@66.193.176.35:5060>;tag=as516768f4
t: <sip:56225814887@ss.callcentric.com>;tag=C18EC8-55A
i: 32559519-3609948918-834417@msw2.telengy.net
CSeq: 2 BYE
Max-Forwards: 13
l: 0
>> I request you to talk to your provider on this issue.
//Suresh
05-25-2014 12:58 PM
OK, I am reviewing your analysis. I will notice Callcentric about the problem.
Thank you so much for the analysis.
05-25-2014 05:50 PM
Hello, that is the ITSP Callcentric responded about:
SIP/2.0 200 OK
Date: Sun, 25 May 2014 19:24:54 GMT
From: <sip:5101100061612@66.193.176.35:5060>;tag=as34df9acb
Supported: replaces
Supported: sdp-anat
Content-Length: 250
Require: timer
To: <sip:56225814887@ss.callcentric.com>;tag=240030-716
Call-ID: 32826171-3610049108-400787@msw2.telengy.net
Via: SIP/2.0/UDP 204.11.192.22:5080;branch=z9hG4bK-d68ba020764b2d5f23e1ab8142c1636b;change=ta
CSeq: 1 INVITE
v=0
o=CiscoSystemsSIP-GW-UserAgent 9525 7588 IN IP4 192.168.10.10
s=SIP Call
t=0 0
m=audio 23304 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Basically what's occurring above is that while our test call attempt is sent towards your Cisco SIP gateway, and your SIP gateway is receiving it; it isn't established properly, specifically as your gateway seems to be sending the header "Require: timer" which isn't necessary (we believe this is the reason why calls are not being established properly). If possible, can you configure your gateway to remove this particular header?
Is there any command to remove that option at the gateway?
Thanks.
05-25-2014 07:15 PM
voice service voip
sip
sip-profiles 1
//Suresh
05-26-2014 10:14 AM
Solved. It works with the SIP Profile.
Many Thanks.
For CallCentric SIP Trunk, a SIP Profile is a must.
