CUBE software and SRST
Is it possible to have CUBE (IP-IP GW) software and SRST on same router?
Re: CUBE software and SRST
Yes, you should be able to do this. Your dial peers could get a little confusing, but it should work.
hth,
nick
yes, it is posible without problem. keep in mind that you will have to have a clear idea about your dial-peers.
I second that. A will developed dialplan will be needed in this configuration and it is a good idea to have descriptions on everything. This way when you look back at the configuration a year later will know what everything is doing.
I'm tring to put SRST licence on C2811-VSEC-CUBE/K9 in Cico configurator, but I got an error that it is not possible (The Maximum number of Survivable Remote Site Telephony Licenses allowed on this platform is 0.).
Why is that so?
Vlaho
1079
