CUBE support for Request for Assistance Interface NG911
I'm trying to pass a SIP INFO message on an NG911 call with "Content-Type: application/rfai-bridge-request+xml".  The CUBE replies with "Unsupported Media Type".  I have enabled the pass through configs I know to use.  Does anyone here have any experience with this?  Thanks much in advance.
CUBE trace:
Jan 21 23:34:02.609: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INFO sip:7209959303@10.4.15.240:5060 SIP/2.0
Via: SIP/2.0/UDP 10.4.0.10:5060;branch=z9hG4bK0c4d34d4;rport
To: <sip:7209959303@10.4.15.240>;tag=B5EE1854-CC4
Contact: <sip:911010501@10.4.0.10>
Call-ID: 5042F289-822B11E3-B1B5D48C-90210556@10.4.15.240
CSeq: 102 INFO
User-Agent: Asterisk PBX
Max-Forwards: 70
Content-Length: 123
<?xml version="1.0" encoding="UTF-8"?>
<bridge-request >
    <modify-bridge action="drop-last-leg"/>
</bridge-request>
Sent:
SIP/2.0 415 Unsupported Media Type
Date: Tue, 21 Jan 2014 23:34:02 GMT
Server: Cisco-SIPGateway/IOS-15.2.2.T
CSeq: 102 INFO
Content-Length: 0
Snip of CUBE configs:
voice service voip
ip address trusted list
  ipv4 10.4.0.10
  ipv4 10.182.27.228
address-hiding
allow-connections sip to sip
sip
  asserted-id pai
  privacy pstn
  midcall-signaling passthru
  privacy-policy passthru
  pass-thru headers unsupp
  pass-thru content unsupp
  pass-thru content sdp
  no call service stop
dial-peer voice 101 voip
description IP PSAP Connection to SBC
preference 1
destination-pattern 7209959303
session protocol sipv2
session target ipv4:10.182.27.228:5062
session transport udp
incoming called-number .
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
description IP PSAP Connection to IP PSAP
preference 1
destination-pattern 911
session target ipv4:10.4.0.10:5060
dtmf-relay rtp-nte
no vad
Everyone's tags (4)
Hi Tod,
Could you please send accross complete sip message starting from INVITE.
Manish
Thank you for the reply.  Here is the call sequence along with the full config:
Jan 23 20:11:09.177: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:911010501@10.182.27.210:5060 SIP/2.0
Via: SIP/2.0/UDP 10.182.27.228:5062;branch=z9hG4bK3pcko610a0hgeh0td0t1.1
From: ""<7209959303>;tag=SDgqjd501-900b8d0-0-13c4-50022-154933-70b92da5-154933
To: "PSAPCNG01"<911010501>;transport=UDP
Call-ID: SDgqjd501-f47b308d9b8f46e49f4a260547ffeeea-agdn1d0
CSeq: 1 INVITE
Max-Forwards: 69
Supported: replaces
Supported: geolocation
Contact: ;isFocus
Allow: INVITE, CANCEL, ACK, BYE, OPTIONS, REFER, SUBSCRIBE, NOTIFY
Allow-Events: refer, conference
User-Agent: microDATA xSwitch/v3.6.00004.3
P-Asserted-Identity: "" <7209959303>
Geolocation: <7209959303>
Flash-Indicator: Yes
Call-Info: <911010501>;purpose=Called-Number,<7209959303>;Service-Type=VoIP,<7209959303>;Flash-Indicator=Yes,<>efa1983b-b977-e311-812c-3640b5842edf@md-911.com>; purpose=Call-Identifier
Content-Type: application/sdp
Content-Length: 236
v=0
o=Dialogic_SIP_CCLIB 151180768 151180769 IN IP4 10.182.27.228
s=Dialogic_SIP_CCLIB
i=session information
c=IN IP4 10.182.27.228
t=0 0
m=audio 7494 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Jan 23 20:11:09.441: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 23 Jan 2014 20:11:09 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
Jan 23 20:11:09.449: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:911010501@10.4.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.4.15.240:5060;branch=z9hG4bK960C
To: <911010501>
Call-ID: 553F9810-83A111E3-9101D70E-AABE001F@10.4.15.240
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1427551293-2208371171-2432423694-2864578591
User-Agent: Cisco-SIPGateway/IOS-15.2.2.T
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1390507869
Contact: <7209959303>
Expires: 180
Max-Forwards: 68
P-Asserted-Identity: <7209959303>
Content-Disposition: session;handling=required
Content-Length: 235
v=0
c=IN IP4 10.4.15.240
t=0 0
m=audio 27172 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
Jan 23 20:11:09.453: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.4.15.240:5060;branch=z9hG4bK960C;received=10.4.15.240
To: <911010501>
CSeq: 101 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Contact: <911010501>
Content-Length: 0
Jan 23 20:11:10.449: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <911010501>;tag=as567a7109
CSeq: 101 INVITE
Supported: replaces
Content-Length: 0
Jan 23 20:11:10.465: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "PSAPCNG01"<911010501>;transport=UDP;tag=96086A0-2589
CSeq: 1 INVITE
Content-Length: 0
Jan 23 20:11:11.797: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 232
v=0
o=root 5400 5400 IN IP4 10.4.0.10
s=session
c=IN IP4 10.4.0.10
t=0 0
m=audio 11958 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Jan 23 20:11:11.801: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:911010501@10.4.0.10 SIP/2.0
Via: SIP/2.0/UDP 10.4.15.240:5060;branch=z9hG4bKADFE
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jan 23 20:11:11.805: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 236
v=0
s=session
c=IN IP4 10.182.27.210
t=0 0
m=audio 23896 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Jan 23 20:11:12.309: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:911010501@10.182.27.210:5060 SIP/2.0
Via: SIP/2.0/UDP 10.182.27.228:5062;branch=z9hG4bK39jnah1048s1ais1d171.1
CSeq: 1 ACK
Max-Forwards: 69
Contact: ;isFocus
Content-Length: 0
Jan 23 20:11:29.133: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.4.0.10:5060;branch=z9hG4bK6dd746dc;rport
To: <7209959303>;tag=96082A4-12C1
CSeq: 102 INFO
Max-Forwards: 70
Content-Length: 121
Jan 23 20:11:29.137: //200940/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 23 Jan 2014 20:11:29 GMT
CSeq: 102 INFO
Content-Length: 0
Jan 23 20:11:32.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:7209959303@10.4.15.240:5060 SIP/2.0
Via: SIP/2.0/UDP 10.4.0.10:5060;branch=z9hG4bK5a4e761a;rport
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Jan 23 20:11:32.709: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:LTTMDBC1B2XSR2@10.182.27.228:5062;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.182.27.210:5060;branch=z9hG4bKB18
From: "PSAPCNG01"<911010501>;transport=UDP;tag=96086A0-2589
To: ""<7209959303>;tag=SDgqjd501-900b8d0-0-13c4-50022-154933-70b92da5-154933
Date: Thu, 23 Jan 2014 20:11:12 GMT
Max-Forwards: 70
Timestamp: 1390507892
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1013,OS=162080,PR=1043,OR=179396,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
Jan 23 20:11:32.709: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 23 Jan 2014 20:11:32 GMT
CSeq: 103 BYE
P-RTP-Stat: PS=1043,OS=166880,PR=1023,OR=175956,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
Jan 23 20:11:32.789: //200939/5516B43D90FB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Supported: replaces
Allow: INVITE, CANCEL, ACK, BYE, OPTIONS, INFO, REFER, NOTIFY
Content-Length: 0
ltn-n911-01#show run
Building configuration...
Current configuration : 5140 bytes
! No configuration change since last restart
version 15.2
hostname ltn-n911-01
boot-start-marker
boot-end-marker
enable secret 5 $1$22tF$jD2WpqZG0b/PM6U2hshzg1
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ none
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone MST -7 0
clock summer-time MDT recurring
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip cef
voice-card 0
voice service voip
  ipv4 10.4.0.10
  ipv4 10.182.27.228
address-hiding
sip
  asserted-id pai
  privacy pstn
license udi pid CISCO2921/K9 sn FTX1449AJS1
hw-module sm 1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description litf-mgsw-80# Fa0/3
ip address 204.131.174.209 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description mnl-priv-11 Serial4/0/0/20:0
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial0/0/0.111 point-to-point
ip address 10.182.27.210 255.255.255.252
ip nat outside
ip virtual-reassembly in
frame-relay interface-dlci 111
interface Serial0/0/0.120 point-to-point
ip address 10.182.27.214 255.255.255.252
frame-relay interface-dlci 120
interface GigabitEthernet1/0
ip unnumbered GigabitEthernet1/0.120
interface GigabitEthernet1/0.111
encapsulation dot1Q 111
ip address 10.4.15.240 255.255.0.0
ip nat inside
interface GigabitEthernet1/0.120
encapsulation dot1Q 120
ip address 10.240.59.2 255.255.255.224
vrrp 120 ip 10.240.59.1
vrrp 120 preempt delay minimum 120
vrrp 120 priority 150
interface GigabitEthernet1/1
description Internal switch interface connected to EtherSwitch Service Module
no ip address
interface Vlan1
no ip address
router bgp 65100
bgp router-id 10.112.100.2
bgp log-neighbor-changes
neighbor 10.182.27.209 remote-as 65000
address-family ipv4
  redistribute connected
  neighbor 10.182.27.209 activate
  neighbor 10.182.27.209 soft-reconfiguration inbound
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 198.36.133.0 255.255.255.0 204.131.174.254
ip route 198.36.134.0 255.255.255.0 204.131.174.254
ip route 198.36.135.0 255.255.255.0 204.131.174.254
ip route 204.131.174.0 255.255.255.0 204.131.174.254
logging facility local5
logging 204.131.174.70
logging 204.131.174.72
access-list 1 permit any
access-list 7 permit any
snmp-server location LTTNCOMLML2 RR024xxx
snmp-server enable traps entity-sensor threshold
snmp-server host 204.131.174.2 version 2c nmstest
snmp-server host 204.131.174.70 version 2c nmstest
tacacs-server host 204.131.174.70
tacacs-server host 204.131.174.2
tacacs-server timeout 2
tacacs-server directed-request
tacacs-server key 7 09445C0D4B021201182825012E21
control-plane
mgcp profile default
preference 1
dtmf-relay rtp-nte
no vad
preference 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
exec-timeout 0 0
logging synchronous
transport input all
scheduler allocate 20000 1000
end
ltn-n911-01#
Hi Tod,
When you enable pass-through , CUBE will not play any role in negotiation and all negotiation will happen end to end. So in you case it will be between "911010501@10.4.0.10" to "7209959303@10.182.27.228".
When "7209959303" sends first INVITE to CUBE , it clearly say it will allow only these headers.
INVITE 911010501@10.182.27.210
Which do not contains INFO header.
I would try by disabling these three first to get CUBE in action.
Manish
336
