CUBE to transcode NSE based T.38 to protocol based T.38 ?
Is it possible to transcode NSE based T.38 to protocol based T.38 whit a CUBE ?
I would like to have NSE based T.38 between CUCM6.1 and CUBE. And protocol based T.38 between CUBE and my SIP trunk provider.
If this is possible, can I do it in software ? or will it require some DSP ?
Thanx for your help,
Best Regards,
Bastien BERTOUT.
CUBE does not do fax protocol internetworking .  No IOS feature has this capability,
including CUBE.
CUBE does support fax calls using SIP to H.323 interworking. But the fax
method is the same on both sides of the call.
Hope this helps!
Karthik
Thanx for your answer !
269
