CUBE Transcoding methods when sending calls to CVP
Hello, The document titled "Cisco Unified Border Element for Contact Center Solutions" states that if xcoding is needed for agent phones that xcoding needs to be done on the CUBE. I have configured xcoding on the cube and this does work, but should I also be able to configure the CUBE itself to use an external DSPFarm as well? I have tried this unsuccessfully.
Please advise,
Re: CUBE Transcoding methods when sending calls to CVP
Hi Chuck,
The transcoding on CUBE is exactly (is) like the CME transcoding. You simply register your DSPs to CME much like you would to CUCM, except you point it towards the CME address. The only real point to take note of is that you should use the command:
sccp ccm id 1 version 4.0
hth,
nick
If you have enough DSP in your gateway send: "sho inv" and "sho run" you will be able to configure transcoding and conferancing profiles, if you only need transcoding do just that(gateway config 1st the Callmanager "Hardware" Conferancing).
sccp local GigabitEthernet0/1
sccp ccm 10.41.5.1 identifier 500 version 4.1
sccp
sccp ccm group 500
bind interface GigabitEthernet0/1
associate ccm 500 priority 1
associate profile 1 register OR-DSP
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 3
associate application SCCP
no shut
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
no shut
503
