CUBE translation-rule replace called range with specific number
I have a translation rule where I'm attempting to replace a called range with a specific number:
voice translation-rule 998
rule 1 /\(\+4922126103[1-399]\)/ /+49221261030/
This works as expected on a single digit in the range:
test voice translation-rule 998 +49221261031
Matched with rule 1
Original number: +49221261031 Translated number: +49221261030
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
But if the number is more than one digit in the range, only the first digit is replaced:
test voice translation-rule 998 +492212610311
Matched with rule 1
Original number: +492212610311 Translated number: +492212610301
Any suggestions on how to get this to work?
Steve
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Use this instead:rule 1 /\(\
Use this instead:
rule 1 /\(\+4922126103[1-3]..\)/ /+49221261030/
Chris
What is the range as
What is the range as +4922126103[1-399] implies +49221261031 - +49221261033, +49221261039
the digits in bracket substitue one digit, so it is either 1 through 3, or 9 which you list twice.
Chris
Makes sense, but the docs don
Makes sense, but the docs don't say single digit, kind of confusing... "Indicates a range when not in the first/last position. Used with the'[' and ']'."
My intended range is 49 221 261 031 to 49 221 261 03399 (399 numbers) and rewrite them to 49 221 261 030
Maybe I'm using the wrong method, is there another way I could accomplish this?
Steve
Use this instead:
Chris
Was just playing with that as
Was just playing with that as well. Only seems to match if there are 2 digits after the 1-3 range:
test voice translation-rule 998 +49221261032
test voice translation-rule 998 +4922126103111
Matched with rule 1
Original number: +4922126103111 Translated number: +49221261030
I dont follow, how many
I dont follow, how many digits would you like to see after 1-3?  Your range was 199-399 hence [1-3].., where .. covers 00-99
Chris
Right you are.. got it,
Right you are.. got it, thanks.
204
