02-14-2012 03:35 AM - edited 03-16-2019 09:34 AM
I have an issue when making a call into our new v7 CUC from the PSTN, which goes via our old v4 CUCM cluster (being replaced). The call travels over an ICT to our new v7 CUCM cluster, and then hits a Call Handler on the v7 CUC. The Call Handler is set to transfer after user input to specific DN's, and they are all set to "supervise transfer" within the transfer rules of the user in CUC, which should provide MOH while the call is connected, and if busy go to VM, I believe all this is done within CUC.
When a call is established from the PSTN and transferrred to the DN, there is no MOH heard by the caller but the call is established and speech is heard. If I change the transfer rule to "release to switch", ie pass back to CUCM, ringback is heard from the PSTN caller, but if the called number is busy it doesn't automatically go to VM without configuring the DN's forward parameters.
Can anyone explain why I do not hear MOH when making a call from the PSTN, but do if I make a call from the v4 IP phones.
Rod Fawns
02-14-2012 04:07 AM
I can think of three possibilities off the top of my head:
02-14-2012 04:31 AM
Hi Jonathan,
Checked all of these possibilities. We have no SIP, only SCCP, both ends of the ICT are configured with a MRGL, and they are not configured for Multicast.
Rod
